Project: 2497 (Run 4, Clone 13, Gen 0)- EUE@76%
brityank
Post by brityank »
EUE on LINCS Error:
[13:10:32] + Sent 0 of 1 completed units to the server
[13:10:32] + Closed connections
[13:10:32]
[13:10:32] + Processing work unit
[13:10:32] Core required: FahCore_78.exe
[13:10:32] Core found.
[13:10:32] Working on queue slot 00 [April 10 13:10:32 UTC]
[13:10:32] + Working ...
[13:10:32] - Calling '.\FahCore_78.exe -dir work/ -suffix 00 -checkpoint 15 -verbose -lifeline 4056 -version 620'
[13:10:32]
[13:10:32] *------------------------------*
[13:10:32] Folding@Home Gromacs Core
[13:10:32] Version 1.90 (March 8, 2006)
[13:10:32]
[13:10:32] Preparing to commence simulation
[13:10:32] - Looking at optimizations...
[13:10:32] - Created dyn
[13:10:32] - Files status OK
[13:10:35] - Expanded 2215206 -> 15100993 (decompressed 681.6 percent)
[13:10:35] - Starting from initial work packet
[13:10:35]
[13:10:35] Project: 2497 (Run 4, Clone 13, Gen 0)
[13:10:35]
[13:10:35] Assembly optimizations on if available.
[13:10:35] Entering M.D.
[13:10:43] Protein: system
[13:10:43]
[13:10:43] Writing local files
[13:10:45] Extra SSE boost OK.
[13:10:46] Writing local files
[13:10:46] Completed 0 out of 250000 steps  (0%)
[13:26:36] Timered checkpoint triggered.
[15:18:09] Completed 190000 out of 250000 steps  (76%)
[15:34:10] Timered checkpoint triggered.
[15:37:15] Quit 101 - Fatal error:
[15:37:15] Step 191282, time 382.564 (ps)  LINCS WARNING
[15:37:15] relative constraint deviation after LINCS:
[15:37:15] max 6827359036765780400000000.000000 (between atoms 18540 and 18541) rms 72276815756989450000000.000000
[15:37:15]
[15:37:15] Simulation instability has been encountered. The run has entered a
[15:37:15]   state from which no further progress can be made.
[15:37:15] This may be the correct result of the simulation, however if you
[15:37:15]   often see other project units terminating early like this
[15:37:15]   too, you may wish to check the stability of your computer (issues
[15:37:15]   such as high temperature, overclocking, etc.).
[15:37:15] Going to send back what have done.
[15:37:15] logfile size: 36795
[15:37:15] - Writing 37527 bytes of core data to disk...
[15:37:15]   ... Done.
[15:37:16]
[15:37:16] Folding@home Core Shutdown: EARLY_UNIT_END
[15:37:18] CoreStatus = 72 (114)
[15:37:18] Sending work to server
[15:37:18] Project: 2497 (Run 4, Clone 13, Gen 0)
[15:37:18] - Read packet limit of 540015616... Set to 524286976.
[15:37:18] + Attempting to send results [April 12 15:37:18 UTC]
[15:37:18] - Reading file work/wuresults_00.dat from core
[15:37:18]   (Read 37527 bytes from disk)
[15:37:18] Connecting to http://171.65.103.160:80/
[15:37:20] Posted data.
[15:37:20] Initial: 0000; - Uploaded at ~18 kB/s
[15:37:20] - Averaged speed for that direction ~38 kB/s
[15:37:20] + Results successfully sent
[15:37:20] Thank you for your contribution to Folding@Home.
Picked up [15:41:14] Project: 2484 (Run 221, Clone 29, Gen 15)
Fold on! 8-)
... ... Free Republic Folders - A Tribute to Ronald Reagan ... ...
Re: Project: 2497 (Run 4, Clone 13, Gen 0)- EUE@76%
There are 7 reports for partial credit for this WU in the DB ... I've marked it as bad.
brityank
Post by brityank »
Thanks, toTOW 8-)
