2484 (Run 180, Clone 29, Gen 9)
Monterone
Post by Monterone »
I have completed the WU without any problems, but there were problems uploading the results. Later I tried it some times manually with the option "-send all". On one attempt it seemed to be successfull:
                          http://folding.stanford.edu
Launch directory: C:\Users\admin\Desktop\FAH\FAH1
Executable: Folding@home-Win32-x86.exe
Arguments: -send all
[07:56:47] - Ask before connecting: No
[07:56:47] - User name: Monterone (Team 0)
[07:56:47] - User ID: 5DC9D37024338A59
[07:56:47] - Machine ID: 1
[07:56:47]
[07:56:47] Loaded queue successfully.
[07:56:47] Attempting to return result(s) to server...
[07:56:47] Project: 2484 (Run 180, Clone 29, Gen 9)
[07:56:47] - Read packet limit of 540015616... Set to 524286976.
[07:56:47] + Attempting to send results [April 10 07:56:47 UTC]
[07:57:01] - Couldn't send HTTP request to server
[07:57:01] + Could not connect to Work Server (results)
[07:57:01]     (171.65.103.162:8080)
[07:57:01] + Retrying using alternative port
[07:57:02] - Couldn't send HTTP request to server
[07:57:02] + Could not connect to Work Server (results)
[07:57:02]     (171.65.103.162:80)
[07:57:02] - Error: Could not transmit unit 00 (completed April 9) to work server.
[07:57:02] - Read packet limit of 540015616... Set to 524286976.
[07:57:02] + Attempting to send results [April 10 07:57:02 UTC]
[07:58:01] - Server does not have record of this unit. Will try again later.
[07:58:01]   Could not transmit unit 00 to Collection server; keeping in queue.
[07:58:01] Project: 2484 (Run 180, Clone 29, Gen 9)
[07:58:01] - Read packet limit of 540015616... Set to 524286976.
[07:58:01] + Attempting to send results [April 10 07:58:01 UTC]
[07:59:01] + Results successfully sent
[07:59:01] Thank you for your contribution to Folding@Home.
[07:59:01] + Number of Units Completed: 139
[07:59:01] - Failed to send all units to server
Folding@Home Client Shutdown.
But it doesn't show up in my stats! And the lines "Results successfully sent" and "Failed to send all units to server" confuse me a bit... Another run with "-send all" showed, that there are no results to send in queue. Did it return successfull???
Best regards
Monterone
Re: 2484 (Run 180, Clone 29, Gen 9)
There's no data for Project: 2484 (Run 180, Clone 29, Gen 9) in the DB ...
Next time, use the -verbosity 9 switch to get more details printed in the log.
