Project: 2677 (Run 38, Clone 72, Gen 2) - no record of unit
goodyca
Post by goodyca »
The subject work unit was completed Mar 28 15:47:13 UTC. The client has not been able to connect to server 171.64.65.56 a total of 3 times. It was able to connect to the CS 171.67.108.25 on March 28 20:56:11 UTC. However, after uploading the results to the CS, the error came back that the CS had no record of this unit.
Is there a problem with the CS 171.67.108.25 ?
[20:56:10] + Attempting to send results [March 28 20:56:10 UTC]
[20:56:10] - Reading file work/wuresults_05.dat from core
[20:56:10]   (Read 49207494 bytes from disk)
[20:56:10] Connecting to http://171.64.65.56:8080/
[20:56:10] - Couldn't send HTTP request to server
[20:56:10]   (Got status 503)
[20:56:10] + Could not connect to Work Server (results)
[20:56:10]     (171.64.65.56:8080)
[20:56:10] + Retrying using alternative port
[20:56:10] Connecting to http://171.64.65.56:80/
[20:56:11] - Couldn't send HTTP request to server
[20:56:11]   (Got status 503)
[20:56:11] + Could not connect to Work Server (results)
[20:56:11]     (171.64.65.56:80)
[20:56:11] - Error: Could not transmit unit 05 (completed March 28) to work server.
[20:56:11] - 3 failed uploads of this unit.
[20:56:11] + Attempting to send results [March 28 20:56:11 UTC]
[20:56:11] - Reading file work/wuresults_05.dat from core
[20:56:11]   (Read 49207494 bytes from disk)
[20:56:11] Connecting to http://171.67.108.25:8080/
[21:11:18] Posted data.
[21:11:18] Initial: 0000; - Uploaded at ~52 kB/s
[21:11:18] - Averaged speed for that direction ~52 kB/s
[21:11:18] - Server does not have record of this unit. Will try again later.
[21:11:18]   Could not transmit unit 05 to Collection server; keeping in queue.
Re: Project: 2677 (Run 38, Clone 72, Gen 2) - no record of unit
http://fahwiki.net/index.php/Common_Err ... _this_unit
171.64.65.56 (the work server) has been overloaded for the past days ... netload 150 (which generates the error 503). There is already a thread about this server in the "issue with specific server" forum : viewtopic.php?f=18&t=9240
ColonelCain
Post by ColonelCain »
Ah dang... have that WU about 1/2 done on one of my VMware rigs..
