Project: 2676 (Run 3, Clone 196, Gen 2) - no record of unit
goodyca
Post by goodyca »
The subject work unit was completed Mar 27 01:44:34 UTC. The client has not been able to connect to server 171.67.108.24 a total of 15 times. It was able to connect to the CS 171.67.108.25 on March 28 20:48:10 UTC. However, after uploading the results to the CS, the error came back that the CS had no record of this unit.
The due date for the unit is Mar 29 07:10:40 UTC. If successful upload does not occur by the due date, are the results deleted and unit reassigned ?
[20:48:09] Trying to send all finished work units
[20:48:09] Project: 2676 (Run 3, Clone 196, Gen 2)
[20:48:09] + Attempting to send results [March 28 20:48:09 UTC]
[20:48:09] - Reading file work/wuresults_03.dat from core
[20:48:09]   (Read 26036354 bytes from disk)
[20:48:09] Connecting to http://171.67.108.24:8080/
[20:48:10] - Couldn't send HTTP request to server
[20:48:10]   (Got status 503)
[20:48:10] + Could not connect to Work Server (results)
[20:48:10]     (171.67.108.24:8080)
[20:48:10] + Retrying using alternative port
[20:48:10] Connecting to http://171.67.108.24:80/
[20:48:10]     (171.67.108.24:80)
[20:48:10] - Error: Could not transmit unit 03 (completed March 27) to work server.
[20:48:10] - 15 failed uploads of this unit.
[20:48:10] + Attempting to send results [March 28 20:48:10 UTC]
[20:48:10] - Reading file work/wuresults_03.dat from core
[20:48:10]   (Read 26036354 bytes from disk)
[20:48:10] Connecting to http://171.67.108.25:8080/
[20:56:10] Posted data.
[20:56:10] Initial: 0000; - Uploaded at ~52 kB/s
[20:56:10] - Averaged speed for that direction ~52 kB/s
[20:56:10] - Server does not have record of this unit. Will try again later.
[20:56:10]   Could not transmit unit 03 to Collection server; keeping in queue.
Re: Project: 2676 (Run 3, Clone 196, Gen 2) - no record of unit
http://fahwiki.net/index.php/Common_Err ... _this_unit
171.67.108.24 (the work server) has been overloaded for the past days ... netload 300 (which generates the error 503). There is already a thread about this server in the "issue with specific server" forum : viewtopic.php?f=18&t=9209
kasson
Pande Group Member
Post by kasson »
We've identified the issue with the collection server (it's running a different version of the code from the work server) and are working to resolve it. Thanks for the report.
goodyca wrote:The due date for the unit is Mar 29 07:10:40 UTC. If successful upload does not occur by the due date, are the results deleted and unit reassigned ?
Yes, that's what happens.
In general, the WU is reassigned when the Preferred Deadline passes and deleted when the Final Deadline passes. In the case of many SMP projects, the two deadlines are often (but not always) set to the same value. For Project 2676 they are both 3.0 days.
