Project: 2653 (Run 13, Clone 32, Gen 141)
Mactin
Post by Mactin »
Project: 2653 (Run 13, Clone 32, Gen 141) has not been credited (after 3 stats updates cycles).
User name: Martin_Q6600_SMP2 (Team 96377)
User ID: 62EBC8E873299FD9
Machine ID: 2
Could a mod please check it out ?
Thanks/Merci
[16:25:03] + No unsent completed units remaining.
[16:25:03] - Preparing to get new work unit...
[16:25:03] + Attempting to get work packet
[16:25:03] - Will indicate memory of 1240 MB
[16:25:03] - Connecting to assignment server
[16:25:03] Connecting to http://assign.stanford.edu:8080/
[16:25:04] Posted data.
[16:25:04] Initial: 40AB; - Successful: assigned to (171.64.65.64).
[16:25:04] + News From Folding@Home: Welcome to Folding@Home
[16:25:04] Loaded queue successfully.
[16:25:04] Connecting to http://171.64.65.64:8080/
[16:25:07] Posted data.
[16:25:07] Initial: 0000; - Receiving payload (expected size: 2425989)
[16:25:10] - Downloaded at ~789 kB/s
[16:25:10] - Averaged speed for that direction ~535 kB/s
[16:25:10] + Received work.
[16:25:11] Trying to send all finished work units
[16:25:11] + No unsent completed units remaining.
[16:25:11] + Closed connections
[16:25:16]
[16:25:16] + Processing work unit
[16:25:16] Work type a1 not eligible for variable processors
[16:25:16] Core required: FahCore_a1.exe
[16:25:16] Core found.
[16:25:16] Using generic mpiexec calls
[16:25:16] Working on queue slot 04 [March 24 16:25:16 UTC]
[16:25:16] + Working ...
[16:25:16] - Calling 'mpiexec -np 4 -channel auto -host 127.0.0.1 FahCore_a1.exe -dir work/ -suffix 04 -checkpoint 15 -forceasm -verbose -lifeline 5244 -version 623'
[16:25:16]
[16:25:16] *------------------------------*
[16:25:16] Folding@Home Gromacs SMP Core
[16:25:16] Version 1.74 (March 10, 2007)
[16:25:16]
[16:25:16] Preparing to commence simulation
[16:25:16] - Ensuring status. Please wait.
[16:25:33] - Assembly optimizations manually forced on.
[16:25:33] - Not checking prior termination.
[16:25:37] - Expanded 2425477 -> 12890333 (decompressed 531.4 percent)
[16:25:37] - Starting from initial work packet
[16:25:37]
[16:25:37] Project: 2653 (Run 13, Clone 32, Gen 141)
[16:25:37]
[16:25:39] Assembly optimizations on if available.
[16:25:39] Entering M.D.
[16:25:45] Rejecting checkpoint
[16:25:46] Protein: Protein in POPC
[16:25:46] Writing local files
[16:25:48] Extra SSE boost OK.
[16:25:48] Writing local files
[16:25:48] Completed 0 out of 500000 steps  (0 percent)
[16:40:49] Timered checkpoint triggered.
[16:41:47] Writing local files
[16:41:47] Completed 5000 out of 500000 steps  (1 percent)
[16:56:48] Timered checkpoint triggered.
[16:58:45] Writing local files
[16:58:45] Completed 10000 out of 500000 steps  (2 percent)
[17:13:46] Timered checkpoint triggered.
[17:15:44] Writing local files
[17:15:44] Completed 15000 out of 500000 steps  (3 percent)
[18:50:26] Timered checkpoint triggered.
[18:51:46] Writing local files
[18:51:46] Completed 490000 out of 500000 steps  (98 percent)
[19:06:46] Timered checkpoint triggered.
[19:08:08] Writing local files
[19:08:08] Completed 495000 out of 500000 steps  (99 percent)
[19:23:09] Timered checkpoint triggered.
[19:24:29] Writing local files
[19:24:29] Completed 500000 out of 500000 steps  (100 percent)
[19:24:29] Writing final coordinates.
[19:24:29] Past main M.D. loop
[19:24:29] Will end MPI now
[19:25:30]
[19:25:30] Finished Work Unit:
[19:25:30] - Reading up to 3721632 from "work/wudata_04.arc": Read 3721632
[19:25:30] - Reading up to 1775416 from "work/wudata_04.xtc": Read 1775416
[19:25:30] goefile size: 0
[19:25:30] logfile size: 33705
[19:25:30] Leaving Run
[19:25:34] - Writing 5535153 bytes of core data to disk...
[19:25:34]   ... Done.
[19:25:34] - Failed to delete work/wudata_04.sas
[19:25:34] - Failed to delete work/wudata_04.goe
[19:25:34] Warning:  check for stray files
[19:25:34] - Shutting down core
[19:27:34]
[19:27:34] Folding@home Core Shutdown: FINISHED_UNIT
[19:27:34]
[19:27:38] CoreStatus = 64 (100)
[19:27:38] Unit 4 finished with 47 percent of time to deadline remaining.
[19:27:38] Updated performance fraction: 0.524058
[19:27:38] Sending work to server
[19:27:38] Project: 2653 (Run 13, Clone 32, Gen 141)
[19:27:38] + Attempting to send results [March 26 19:27:38 UTC]
[19:27:38] - Reading file work/wuresults_04.dat from core
[19:27:38]   (Read 5535153 bytes from disk)
[19:27:38] Connecting to http://171.64.65.64:8080/
[19:28:35] Posted data.
[19:28:36] Initial: 0000; - Uploaded at ~93 kB/s
[19:28:36] - Averaged speed for that direction ~86 kB/s
[19:28:36] + Results successfully sent
[19:28:36] Thank you for your contribution to Folding@Home.
[19:28:36] + Number of Units Completed: 132
[19:28:40] - Warning: Could not delete all work unit files (4): Core returned invalid code
[19:28:40] Trying to send all finished work units
[19:28:40] + No unsent completed units remaining.
[19:28:40] - Preparing to get new work unit...
Re: Project: 2653 (Run 13, Clone 32, Gen 141)
Hi Martin_Q6600_SMP2 (team 96377),
Your WU (P2653 R13 C32 G141) was added to the stats database on 2009-03-26 12:14:45 for 0 points of credit.
For some unknown reason, the server can't credit this WU :( ... I think it's not the first time I see this strange situation :?
I'm not sure it's helpful, but somebody else did complete that WU successfully.
Mactin
Post by Mactin »
The only thing I know, is that I completed it sucessfully and did not get any points :(
i.e. my biggest peeve with fah.
What is the UserID for that machine?
The times shown in your log don't match the ones shown in the database and until I can make all the numbers match, I don't know what to say. Is your computer clock set right? . . . so that FAHlog shows UTC?
Mactin
Post by Mactin »
[02:59:00] - User name: Martin_Q6600_SMP2 (Team 96377)
[02:59:00] - User ID: 62EBC8E873299FD9
[02:59:00] - Machine ID: 2
I'm running two SMP clients on this Q6600/Vista home premium (french) 32bit machine, in the past couple of weeks I have also been using it as a sneakernet head unit.
Sneakernetting has become much more involved with the new AS code, so we cant "mix things up" as we used to before. So now instead of only using my work machine, I use my home machine and a bunch of USB keys. This way, uploads and Downloads are allways kept in check, This is a hole other subject, but I feel I had to disclose it.
Every thing is under control. Thanks.
kasson
Pande Group Member
Post by kasson »
I have a sneaky feeling this might be an interaction of a special case with the assignment of work units and sneakernetting.
