5779 (Run 3, Clone 0, Gen 27)
CASSTOR !!!
Unstable machine.
Re: 5779 (Run 3, Clone 0, Gen 27)
There's no data for this WU in the DB yet.
Could you please post the part of the FAHLog.txt file showing the issue ?
CASSTOR !!!
[09:20:58] Folding@Home GPU Core - Beta
[09:20:58] Version 1.19 (Mon Nov 3 09:34:13 PST 2008)
[09:20:58]
[09:20:58] Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[09:20:58] Build host: amoeba
[09:20:58] Board Type: Nvidia
[09:20:58] Core :
[09:20:58] Preparing to commence simulation
[09:20:58] - Looking at optimizations...
[09:20:58] - Created dyn
[09:20:58] - Files status OK
[09:20:58] - Expanded 66304 -> 348500 (decompressed 525.6 percent)
[09:20:58] Called DecompressByteArray: compressed_data_size=66304 data_size=348500, decompressed_data_size=348500 diff=0
[09:20:58] - Digital signature verified
[09:20:58]
[09:20:58] Project: 5779 (Run 3, Clone 0, Gen 27)
[09:20:58]
[09:20:58] Assembly optimizations on if available.
[09:20:58] Entering M.D.
[09:21:05] Working on Protein
[09:21:06] Client config found, loading data.
[09:21:06] Starting GUI Server
[09:22:27] Completed 1%
[09:23:48] Completed 2%
[09:25:09] Completed 3%
[09:26:29] Completed 4%
[09:27:50] Completed 5%
[09:29:11] Completed 6%
[09:30:32] Completed 7%
[09:31:52] Completed 8%
[09:33:13] Completed 9%
[09:34:34] Completed 10%
[09:35:32] Completed 11%
[09:35:32] mdrun_gpu returned
[09:35:32] NANs detected on GPU
[09:35:32]
[09:35:32] Folding@home Core Shutdown: UNSTABLE_MACHINE
[09:35:35] CoreStatus = 7A (122)
[09:35:35] Sending work to server
[09:35:35] Project: 5779 (Run 3, Clone 0, Gen 27)
[09:35:35] - Read packet limit of 540015616... Set to 524286976.
[09:35:35] - Error: Could not get length of results file work/wuresults_06.dat
[09:35:35] - Error: Could not read unit 06 file. Removing from queue.
[09:35:35] - Preparing to get new work unit...
[09:35:35] + Attempting to get work packet
[09:35:35] - Connecting to assignment server
[09:35:36] - Successful: assigned to (171.64.65.106).
[09:35:36] + News From Folding@Home: GPU folding beta
[09:35:36] Loaded queue successfully.
[09:35:38] + Closed connections
[09:35:43]
[09:35:43] + Processing work unit
[09:35:43] Core required: FahCore_11.exe
[09:35:43] Core found.
[09:35:43] Working on queue slot 07 [March 23 09:35:43 UTC]
[09:35:43] + Working ...
[09:35:43]
[09:35:43] *------------------------------*
[09:35:43] Folding@Home GPU Core - Beta
[09:35:43] Version 1.19 (Mon Nov 3 09:34:13 PST 2008)
[09:35:43]
[09:35:43] Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[09:35:43] Build host: amoeba
[09:35:43] Board Type: Nvidia
[09:35:43] Core :
[09:35:43] Preparing to commence simulation
[09:35:43] - Looking at optimizations...
[09:35:43] - Created dyn
[09:35:43] - Files status OK
[09:35:43] - Expanded 66304 -> 348500 (decompressed 525.6 percent)
[09:35:43] Called DecompressByteArray: compressed_data_size=66304 data_size=348500, decompressed_data_size=348500 diff=0
[09:35:43] - Digital signature verified
[09:35:43]
[09:35:43] Project: 5779 (Run 3, Clone 0, Gen 27)
[09:35:43]
[09:35:43] Assembly optimizations on if available.
[09:35:43] Entering M.D.
[09:35:49] Working on Protein
[09:35:50] Client config found, loading data.
[09:35:50] Starting GUI Server
[09:37:11] Completed 1%
[09:38:32] Completed 2%
[09:39:53] Completed 3%
[09:41:14] Completed 4%
[09:42:34] Completed 5%
[09:43:55] Completed 6%
[09:45:16] Completed 7%
[09:46:37] Completed 8%
[09:47:57] Completed 9%
[09:49:18] Completed 10%
[09:50:39] Completed 11%
[09:52:00] Completed 12%
[09:53:20] Completed 13%
[09:54:41] Completed 14%
[09:56:02] Completed 15%
[09:57:23] Completed 16%
[09:58:43] Completed 17%
[10:00:04] Completed 18%
[10:01:25] Completed 19%
[10:02:46] Completed 20%
[10:04:07] Completed 21%
[10:05:27] Completed 22%
[10:06:48] Completed 23%
[10:08:09] Completed 24%
[10:09:30] Completed 25%
[10:10:50] Completed 26%
[10:12:11] Completed 27%
[10:13:32] Completed 28%
[10:14:53] Completed 29%
[10:16:13] Completed 30%
[10:17:34] Completed 31%
[10:18:55] Completed 32%
[10:20:16] Completed 33%
[10:21:36] Completed 34%
[10:22:57] Completed 35%
[10:24:12] Completed 36%
[10:24:13] mdrun_gpu returned
[10:24:13] NANs detected on GPU
[10:24:13]
[10:24:13] Folding@home Core Shutdown: UNSTABLE_MACHINE
[10:24:15] CoreStatus = 7A (122)
[10:24:15] Sending work to server
[10:24:15] Project: 5779 (Run 3, Clone 0, Gen 27)
[10:24:15] - Read packet limit of 540015616... Set to 524286976.
[10:24:15] - Error: Could not get length of results file work/wuresults_07.dat
[10:24:15] - Error: Could not read unit 07 file. Removing from queue.
[10:24:15] - Preparing to get new work unit...
[10:24:15] + Attempting to get work packet
[10:24:15] - Connecting to assignment server
[10:24:16] - Successful: assigned to (171.64.122.70).
[10:24:16] + News From Folding@Home: GPU folding beta
[10:24:16] Loaded queue successfully.
[10:24:19] + Closed connections
[10:24:24]
[10:24:24] + Processing work unit
[10:24:24] Core required: FahCore_14.exe
[10:24:24] Core found.
[10:24:24] Working on queue slot 08 [March 23 10:24:24 UTC]
[10:24:24] + Working ...
[10:24:24]
[10:24:24] *------------------------------*
[10:24:24] Folding@Home GPU Core - Beta
[10:24:24] Version 1.24 (Mon Mar 2 19:49:32 PST 2009)
[10:24:24]
[10:24:24] Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[10:24:24] Build host: vspm46
[10:24:24] Board Type: Nvidia
[10:24:24] Core :
[10:24:24] Preparing to commence simulation
[10:24:24] - Looking at optimizations...
[10:24:24] - Created dyn
[10:24:24] - Files status OK
[10:24:24] - Expanded 68435 -> 357580 (decompressed 522.5 percent)
[10:24:24] Called DecompressByteArray: compressed_data_size=68435 data_size=357580, decompressed_data_size=357580 diff=0
[10:24:24] - Digital signature verified
[10:24:24]
[10:24:24] Project: 5904 (Run 14, Clone 165, Gen 1)
[10:24:24]
[10:24:24] Assembly optimizations on if available.
[10:24:24] Entering M.D.
[10:24:30] Tpr hash work/wudata_08.tpr: 2464558682 3143560863 1833325759 3091436203 2720146605
[10:24:30] Working on Protein
[10:24:31] Client config found, loading data.
[10:24:31] Starting GUI Server
[10:27:31] Completed 1%
[10:30:47] Completed 2%
[10:34:04] Completed 3%
[10:37:17] Completed 4%
[10:40:35] Completed 5%
[10:43:51] Completed 6%
[10:47:04] Completed 7%
[10:50:18] Completed 8%
[10:53:33] Completed 9%
[10:56:55] Completed 10%
[11:00:11] Completed 11%
[11:03:26] Completed 12%
[11:06:39] Completed 13%
[11:09:51] Completed 14%
[11:13:11] Completed 15%
[11:16:27] Completed 16%
[11:19:39] Completed 17%
[11:22:54] Completed 18%
[11:26:08] Completed 19%
[11:29:27] Completed 20%
[11:32:44] Completed 21%
[11:35:58] Completed 22%
[11:39:15] Completed 23%
[11:42:10] + Working...
[11:42:29] Completed 24%
[11:45:46] Completed 25%
[11:48:59] Completed 26%
[11:52:14] Completed 27%
[11:55:31] Completed 28%
[11:58:49] Completed 29%
[12:02:10] Completed 30%
[12:05:24] Completed 31%
[12:08:39] Completed 32%
[12:11:54] Completed 33%
[12:15:12] Completed 34%
[12:18:27] Completed 35%
[12:21:41] Completed 36%
[12:24:56] Completed 37%
[12:28:00] Completed 38%
[12:30:53] Completed 39%
[12:33:47] Completed 40%
[12:36:38] Completed 41%
[12:39:30] Completed 42%
[12:42:21] Completed 43%
[12:45:12] Completed 44%
[12:48:07] Completed 45%
[12:50:57] Completed 46%
[12:53:45] Completed 47%
[12:56:36] Completed 48%
[12:59:24] Completed 49%
[13:02:20] Completed 50%
[13:05:12] Completed 51%
[13:08:02] Completed 52%
[13:10:52] Completed 53%
[13:13:44] Completed 54%
[13:16:40] Completed 55%
[13:19:29] Completed 56%
[13:22:17] Completed 57%
[13:25:06] Completed 58%
[13:27:57] Completed 59%
[13:30:50] Completed 60%
[13:33:41] Completed 61%
[13:36:31] Completed 62%
[13:39:22] Completed 63%
[13:42:14] Completed 64%
[13:45:09] Completed 65%
[13:48:00] Completed 66%
[13:50:51] Completed 67%
[13:53:40] Completed 68%
[13:56:27] Completed 69%
[13:59:19] Completed 70%
[14:02:09] Completed 71%
[14:05:00] Completed 72%
[14:07:49] Completed 73%
[14:10:39] Completed 74%
[14:13:34] Completed 75%
[14:16:25] Completed 76%
[14:19:16] Completed 77%
[14:22:07] Completed 78%
[14:24:57] Completed 79%
[14:27:50] Completed 80%
[14:30:43] Completed 81%
[14:33:29] Completed 82%
[14:36:17] Completed 83%
[14:39:09] Completed 84%
[14:42:03] Completed 85%
[14:44:53] Completed 86%
[14:47:43] Completed 87%
[14:50:31] Completed 88%
[14:53:21] Completed 89%
[14:56:12] Completed 90%
[14:59:02] Completed 91%
[15:01:52] Completed 92%
[15:04:45] Completed 93%
[15:07:38] Completed 94%
[15:10:30] Completed 95%
[15:13:19] Completed 96%
[15:16:10] Completed 97%
[15:19:01] Completed 98%
[15:21:52] Completed 99%
[15:24:48] Completed 100%
[15:24:48] Successful run
[15:24:48] DynamicWrapper: Finished Work Unit: sleep=10000
[15:24:58] Reserved 33908 bytes for xtc file; Cosm status=0
[15:24:58] Allocated 33908 bytes for xtc file
[15:24:58] - Reading up to 33908 from "work/wudata_08.xtc": Read 33908
[15:24:58] Read 33908 bytes from xtc file; available packet space=786396556
[15:24:58] xtc file hash check passed.
[15:24:58] Reserved 23472 23472 786396556 bytes for arc file=<work/wudata_08.trr> Cosm status=0
[15:24:58] Allocated 23472 bytes for arc file
[15:24:58] - Reading up to 23472 from "work/wudata_08.trr": Read 23472
[15:24:58] Read 23472 bytes from arc file; available packet space=786373084
[15:24:58] trr file hash check passed.
[15:24:58] Allocated 560 bytes for edr file
[15:24:58] Read bedfile
[15:24:58] edr file hash check passed.
[15:24:58] Allocated 15803 bytes for logfile
[15:24:58] Read logfile
[15:24:58] GuardedRun: success in DynamicWrapper
[15:24:58] GuardedRun: done
[15:24:58] Run: GuardedRun completed.
[15:24:59] - Writing 74255 bytes of core data to disk...
[15:24:59] Done: 73743 -> 62916 (compressed to 85.3 percent)
[15:24:59] ... Done.
[15:24:59] - Shutting down core
[15:24:59]
[15:24:59] Folding@home Core Shutdown: FINISHED_UNIT
[15:25:03] CoreStatus = 64 (100)
[15:25:03] Sending work to server
[15:25:03] Project: 5904 (Run 14, Clone 165, Gen 1)
[15:25:03] - Read packet limit of 540015616... Set to 524286976.
[15:25:03] + Attempting to send results [March 23 15:25:03 UTC]
[15:25:09] + Results successfully sent
[15:25:09] Thank you for your contribution to Folding@Home.
[15:25:09] + Number of Units Completed: 277Re: 5779 (Run 3, Clone 0, Gen 27)
No data for this WU has appeared in the database yet.
The previous generation appears to have been completed routinely on 22 March 2009.
If you're running overclocked, please keep an eye on this GPU and be prepared to roll it back to stock clocks if you see more unstable machine errors.
Thanks for your report!
