I saw this thread over OCN
http://www.overclock.net/overclock-net- ... -easy.html
However, is only for OCN team I don't know how to change the team or setting it up. If anyone got experiences with this please give me some insight.
Thanks.
How to set VM under Windows?
Re: How to set VM under Windows?
Did you look at notfred's diskless solutions ? He also have a VM appliance : http://reilly.homeip.net/folding/
I download the Virtual Appliance from that website, however the setup isn't changable.
Team set to 2640 and can't set my desire memory usage,
LogID -- only root (can be login) no password required
I try other ID such as my ID doesn't work, probably due to the team
Password is a no go,
after I login with 'root' I struck with 'help' doesn't seems to be running.
From the page where you downloaded the VM files:
The system will start up and run with default settings, point a web browser at the specified IP address and hit the "Reconfigure this host and any USB drives." link to reconfigure it and then hit the "Remote reboot: enabled" link to get it to pick up the new configuration.
P.S : these tools are not supported by Stanford. This forum is not the good place to get technical support about these tools. It's better to visit the author's forum or team website.
I'm moving this thread to 3rd party supported tools forum.
