Project 3861 (Run 114, Clone 5, Gen 2)
Mactin
Post by Mactin »
Project 3861 (Run 114, Clone 5, Gen 2) EUE (CoreStatus = 72 (114)) at 76% for ZERO points !
Username = Martin_UM_PX3, Team = Mactin (96377)
(code includes an unrelated unsent p3859 due to problems with 128.59.74.4)
[20:38:02] *------------------------------*
[20:38:02] Folding@Home Double Gromacs Core C
[20:38:02] Version 1.00 (Thu Apr 24 19:12:09 PDT 2008)
[20:38:02]
[20:38:02] Preparing to commence simulation
[20:38:02] - Assembly optimizations manually forced on.
[20:38:02] - Not checking prior termination.
[20:38:02] - Expanded 246418 -> 661416 (decompressed 268.4 percent)
[20:38:02]
[20:38:02] Project: 3861 (Run 114, Clone 5, Gen 2)
[20:38:02]
[20:38:02] Assembly optimizations on if available.
[20:38:02] Entering M.D.
[20:38:08] Will resume from checkpoint file
[20:38:08] Working on p3861_fkbpabsolute_ligand
[20:38:08] Completed 0 out of 1500000 steps  (0%)
[20:38:08] Extra SSE2 boost OK
[20:38:10] Resuming from checkpoint
[20:38:10] Verified work/wudata_02.log
[20:38:10] Verified work/wudata_02.edr
[20:38:10] Verified work/wudata_02.xvg
[20:38:10] Verified work/wudata_02.trr
[20:38:10] Verified work/wudata_02.xtc
[20:38:23] - Couldn't send HTTP request to server
[20:38:23] + Could not connect to Work Server (results)
[20:38:23]     (128.59.74.4:8080)
[20:38:23] + Retrying using alternative port
[20:38:23] Connecting to http://128.59.74.4:80/
[20:38:44] - Couldn't send HTTP request to server
[20:38:44] + Could not connect to Work Server (results)
[20:38:44]     (128.59.74.4:80)
[20:38:44] - Error: Could not transmit unit 04 (completed February 27) to work server.
[20:38:44] - 576 failed uploads of this unit.
[20:38:44] + Attempting to send results [March 6 20:38:44 UTC]
[20:38:44] - Reading file work/wuresults_04.dat from core
[20:38:44]   (Read 870762 bytes from disk)
[20:38:44] Connecting to http://171.65.103.100:8080/
[20:38:44]   (Got status 503)
[20:38:44]     (171.65.103.100:8080)
[20:38:44] + Retrying using alternative port
[20:38:44] Connecting to http://171.65.103.100:80/
[20:38:44]     (171.65.103.100:80)
[20:38:44]   Could not transmit unit 04 to Collection server; keeping in queue.
[20:38:44] + Sent 0 of 1 completed units to the server
[20:38:44] - Autosend completed
[20:48:10] Timer requesting checkpoint
[20:58:10] Timer requesting checkpoint
[21:01:07] Completed 15000 out of 1500000 steps  (1%)
[02:31:06] Completed 1125000 out of 1500000 steps  (75%)
[02:41:10] Timer requesting checkpoint
[02:44:31] - Autosending finished units... [March 9 02:44:31 UTC]
[02:44:31] Trying to send all finished work units
[02:44:31] Project: 3859 (Run 8465, Clone 0, Gen 8)
[02:44:31] + Attempting to send results [March 9 02:44:31 UTC]
[02:44:31] - Reading file work/wuresults_04.dat from core
[02:44:31]   (Read 870762 bytes from disk)
[02:44:31] Connecting to http://128.59.74.4:8080/
[02:44:52] - Couldn't send HTTP request to server
[02:44:52] + Could not connect to Work Server (results)
[02:44:52]     (128.59.74.4:8080)
[02:44:52] + Retrying using alternative port
[02:44:52] Connecting to http://128.59.74.4:80/
[02:45:13] - Couldn't send HTTP request to server
[02:45:13] + Could not connect to Work Server (results)
[02:45:13]     (128.59.74.4:80)
[02:45:13] - Error: Could not transmit unit 04 (completed February 27) to work server.
[02:45:13] - 585 failed uploads of this unit.
[02:45:13] + Attempting to send results [March 9 02:45:13 UTC]
[02:45:13] - Reading file work/wuresults_04.dat from core
[02:45:13]   (Read 870762 bytes from disk)
[02:45:13] Connecting to http://171.65.103.100:8080/
[02:45:13]   (Got status 503)
[02:45:13]     (171.65.103.100:8080)
[02:45:13] + Retrying using alternative port
[02:45:13] Connecting to http://171.65.103.100:80/
[02:45:13]     (171.65.103.100:80)
[02:45:13]   Could not transmit unit 04 to Collection server; keeping in queue.
[02:45:13] + Sent 0 of 1 completed units to the server
[02:45:13] - Autosend completed
[02:51:11] Timer requesting checkpoint
[03:01:12] Timer requesting checkpoint
[03:11:14] Timer requesting checkpoint
[03:15:17] Completed 1140000 out of 1500000 steps  (76%)
[03:24:27] Gromacs cannot continue further.
[03:24:27] Going to send back what have done.
[03:24:27] logfile size: 95183
[03:24:27] - Writing 95719 bytes of core data to disk...
[03:24:27] Done: 95207 -> 22069 (compressed to 2  ... Done.
[03:24:28]
[03:24:28] Folding@home Core Shutdown: EARLY_UNIT_END
[03:24:32] CoreStatus = 72 (114)
[03:24:32] Sending work to server
[03:24:32] Project: 3861 (Run 114, Clone 5, Gen 2)
[03:24:32] + Attempting to send results [March 9 03:24:32 UTC]
[03:24:32] - Reading file work/wuresults_02.dat from core
[03:24:32]   (Read 22581 bytes from disk)
[03:24:32] Connecting to http://128.143.48.226:8080/
[03:24:32] Posted data.
[03:24:32] Initial: 0000; Conversation time very short, giving reduced weight in bandwidth avg
[03:24:32] - Uploaded at ~46 kB/s
[03:24:32] - Averaged speed for that direction ~288 kB/s
[03:24:32] + Results successfully sent
[03:24:32] Thank you for your contribution to Folding@Home.
[03:24:36] Trying to send all finished work units
[03:24:36] Project: 3859 (Run 8465, Clone 0, Gen 8)
[03:24:36] + Attempting to send results [March 9 03:24:36 UTC]
[03:24:36] - Reading file work/wuresults_04.dat from core
[03:24:36]   (Read 870762 bytes from disk)
[03:24:36] Connecting to http://128.59.74.4:8080/
[03:24:57] - Couldn't send HTTP request to server
[03:24:57] + Could not connect to Work Server (results)
[03:24:57]     (128.59.74.4:8080)
[03:24:57] + Retrying using alternative port
[03:24:57] Connecting to http://128.59.74.4:80/
[03:25:18] - Couldn't send HTTP request to server
[03:25:18] + Could not connect to Work Server (results)
[03:25:18]     (128.59.74.4:80)
[03:25:18] - Error: Could not transmit unit 04 (completed February 27) to work server.
[03:25:18] - 586 failed uploads of this unit.
This is the third EUE with WUs from this series (p3860 to p3864) and where-ever it's at in processing results in zero points.
Is this normal ?
Re: Project 3861 (Run 114, Clone 5, Gen 2)
No that's strange ...
By the way, someone else was able to complete it successfully ... there's might be an issue with your machine.
Pick2
Hardware configuration: Linux & CPUs
Post by Pick2 »
No wonder I can't get thru ! :lol:
<just kidding>
only4u
Post by only4u »
Metioned in thread viewtopic.php?f=18&t=8739&p=87992#p87992, I have some PCs are folding 386x WUs. Still not be able to send results :(.
