Project: 2665 (Run 3, Clone 94, Gen 94)
harlam357
Post by harlam357 »
...and another one. :(
Logs note that this is twice this unit has errored @ 23%. All other units in available logs have processed normally. Please pull this WU.
[18:14:12] *------------------------------*
[18:14:12] Folding@Home Gromacs SMP Core
[18:14:12] Version 1.74 (November 27, 2006)
[18:14:12]
[18:14:12] Preparing to commence simulation
[18:14:12] - Ensuring status. Please wait.
[18:14:29] - Assembly optimizations manually forced on.
[18:14:29] - Not checking prior termination.
[18:14:30] - Expanded 4713141 -> 24426905 (decompressed 518.2 percent)
[18:14:31] - Starting from initial work packet
[18:14:31]
[18:14:31] Project: 2665 (Run 3, Clone 94, Gen 94)
[18:14:31]
[18:14:31] Assembly optimizations on if available.
[18:14:31] Entering M.D.
[18:14:37] Rejecting checkpoint
[18:14:39]
[18:14:39] Writing local files
[18:14:40]
[18:14:40] Writing local files
[18:14:41] Extra SSE boost OK.
[18:14:42] Writing local files
[18:14:43] Completed 0 out of 250000 steps  (0 percent)
[18:30:59] Writing local files
[18:31:00] Completed 2500 out of 250000 steps  (1 percent)
[18:47:14] Writing local files
[18:47:14] Completed 5000 out of 250000 steps  (2 percent)
[18:55:49] - Autosending finished units... [February 24 18:55:49 UTC]
[18:55:49] Trying to send all finished work units
[18:55:49] + No unsent completed units remaining.
[18:55:49] - Autosend completed
[19:03:22] Writing local files
[19:03:22] Completed 7500 out of 250000 steps  (3 percent)
[19:19:27] Writing local files
[19:19:28] Completed 10000 out of 250000 steps  (4 percent)
[19:35:37] Writing local files
[19:35:37] Completed 12500 out of 250000 steps  (5 percent)
[19:51:47] Writing local files
[19:51:47] Completed 15000 out of 250000 steps  (6 percent)
[20:07:56] Writing local files
[20:07:56] Completed 17500 out of 250000 steps  (7 percent)
[20:24:02] Writing local files
[20:24:03] Completed 20000 out of 250000 steps  (8 percent)
[20:40:10] Writing local files
[20:40:10] Completed 22500 out of 250000 steps  (9 percent)
[20:56:12] Writing local files
[20:56:12] Completed 25000 out of 250000 steps  (10 percent)
[21:12:19] Writing local files
[21:12:19] Completed 27500 out of 250000 steps  (11 percent)
[21:28:26] Writing local files
[21:28:27] Completed 30000 out of 250000 steps  (12 percent)
[21:44:35] Writing local files
[21:44:35] Completed 32500 out of 250000 steps  (13 percent)
[22:00:42] Writing local files
[22:00:42] Completed 35000 out of 250000 steps  (14 percent)
[22:16:49] Writing local files
[22:16:49] Completed 37500 out of 250000 steps  (15 percent)
[22:32:57] Writing local files
[22:32:57] Completed 40000 out of 250000 steps  (16 percent)
[22:49:00] Writing local files
[22:49:00] Completed 42500 out of 250000 steps  (17 percent)
[23:05:06] Writing local files
[23:05:06] Completed 45000 out of 250000 steps  (18 percent)
[23:21:11] Writing local files
[23:21:12] Completed 47500 out of 250000 steps  (19 percent)
[23:37:18] Writing local files
[23:37:19] Completed 50000 out of 250000 steps  (20 percent)
[23:53:26] Writing local files
[23:53:26] Completed 52500 out of 250000 steps  (21 percent)
[00:09:33] Writing local files
[00:09:33] Completed 55000 out of 250000 steps  (22 percent)
[00:25:41] Writing local files
[00:25:41] Completed 57500 out of 250000 steps  (23 percent)
[00:33:04] Warning:  long 1-4 interactions
[00:33:04]
[00:33:04] Folding@home Core Shutdown: INTERRUPTED
[00:33:08] CoreStatus = 66 (102)
[00:33:08] + Shutdown requested by user. Exiting.***** Got a SIGTERM signal (15)
[00:33:08] Killing all core threads
Folding@Home Client Shutdown.
Re: Project: 2665 (Run 3, Clone 94, Gen 94)
There's no data in the DB for this WU yet ...
harlam357
Post by harlam357 »
Well... I got it again. Same result.
This is really frustrating... being that the client won't return the partial result. Then it just stops and does not pick up a new WU.
So in the end I've gotten no credit for my work and then I also loose further production because this error just kills the client completely.
There is one report in the DB for partial credit (~1300 points) ...
harlam357
Post by harlam357 »
Maybe you can tell me how to return partial credit then...
Should I do a ./fah6 -delete 0x - then run qfix - then try to submit the result?
harlam357 wrote:Maybe you can tell me how to return partial credit then...
That might be the right thing to do, depending on what we see in FAHlog. Qfix will display messages that can help determine if that's the right thing to do, too as long as you run qfix correctly in the text window.
harlam357
Post by harlam357 »
Got this one again too... doing a -delete on the queue position and then running qfix does nothing. I still cannot upload the partial result.
# Linux Console Edition #######################################################
                       Folding@Home Client Version 6.24beta
                          http://folding.stanford.edu
Launch directory: /home/harlarw/FAH
Executable: ./fah6
Arguments: -delete 02
[19:47:36] - Ask before connecting: No
[19:47:36] - User name: harlam357 (Team 32)
[19:47:36] - User ID: 4A62B5D43AA85C36
[19:47:36] - Machine ID: 1
[19:47:36]
[19:47:36] Loaded queue successfully.
[19:47:36] Deleting work unit #2 from work queue...
[19:51:38] - Failed to delete the requested work unit
ran ./qfix
--- Opening Log file [March 4 19:51:57 UTC]
Executable: ./fah6
Arguments: -send all
[19:51:57] - Ask before connecting: No
[19:51:57] - User name: harlam357 (Team 32)
[19:51:57] - User ID: 4A62B5D43AA85C36
[19:51:57] - Machine ID: 1
[19:51:57]
[19:51:57] Loaded queue successfully.
[19:51:57] Attempting to return result(s) to server...
There are now two reports for partial credit for this WU in the DB.
I've marked it as bad.
harlam357
Post by harlam357 »
Thank you... I just picked this one up again tonight after trying to Fold it again after posting this afternoon.
I've deleted it... I'll keep you apprised if I see any of these that have been giving me fits.
If I don't see any... maybe I'll quit bugging/moaning about/complaining to you for a while. ;)
