P3907 also has the Gen 1 problem
Pette Broad
Hardware configuration: CPU folding on only one machine a laptop
GPU Hardware..
3 x 460
1 X 260
4 X 250
+ 1 X 9800GT (3 days a week)
Post by Pette Broad »
Just had 3 in a row. Make that 5 :(
[22:12:04] Project: 3907 (Run 40, Clone 1, Gen 1)
[22:12:04]
[22:12:04] Assembly optimizations on if available.
[22:12:04] Entering M.D.
[22:12:10] mdrun returned -1
[22:12:10] Going to send back what have done.
[22:12:10] logfile size: 858
[22:12:10] - Writing 1396 bytes of core data to disk...
[22:12:10] Done: 884 -> 594 (compressed to 67.1 percent)
[22:12:10]   ... Done.
[22:12:10]
[22:12:10] Folding@home Core Shutdown: EARLY_UNIT_END
[22:12:14] CoreStatus = 72 (114)
[22:12:14] Sending work to server
[21:51:45] Project: 3907 (Run 12, Clone 3, Gen 1)
[21:51:45]
[21:51:45] Assembly optimizations on if available.
[21:51:45] Entering M.D.
[22:34:39] CoreStatus = C000000D (-1073741811)
[22:34:39] Client-core communications error: ERROR 0xc000000d
[22:34:39] Deleting current work unit & continuing...
[22:34:51] - Preparing to get new work unit...
[22:34:51] + Attempting to get work packet
[22:34:51] - Connecting to assignment server
[22:26:14] Project: 3907 (Run 24, Clone 1, Gen 1)
[22:26:14]
[22:26:14] Assembly optimizations on if available.
[22:26:14] Entering M.D.
[22:26:20] mdrun returned -1
[22:26:20] Going to send back what have done.
[22:26:20] logfile size: 858
[22:26:20] - Writing 1396 bytes of core data to disk...
[22:26:20] Done: 884 -> 584 (compressed to 66.0 percent)
[22:26:20]   ... Done.
[22:26:20]
[22:26:20] Folding@home Core Shutdown: EARLY_UNIT_END
[22:26:24] CoreStatus = 72 (114)
[22:26:24] Sending work to server
Pete
thread
Re: Oh Dear, P3907 also has the Gen 1 problem
Post by thread »
I'll confirm that, I've had about 10 in a row as well (P3907 Gen1)
sortofageek
Post by sortofageek »
Same issues here:
Project: 3907 (Run 329, Clone 1, Gen 1)
and
Project: 3907 (Run 280, Clone 4, Gen 1)
kasson
Pande Group Member
Post by kasson »
Thanks. We're looking into it. More when we know more.
[Fight]Gor
Post by [Fight]Gor »
Confirming, too.
Project: 3907 (Run 120, Clone 4, Gen 1).
kasson
Pande Group Member
Post by kasson »
We've found the problem and anticipate having it fixed in the next hour or so (right now, I have a script re-generating all the Gen1 input files properly).
sortofageek
Thanks for the instant response! :)
kasson
Pande Group Member
Post by kasson »
You're welcome; thanks for the bug reports. Regenerating all the files take a little longer than I expected; I have swapped server .88 back to assigning 3906 instead of 3907. Right now Gen1 should be good on everything through about Run 700; all the Gen 0's are good. Once the scripts finish, I'll start assigning both 3906 and 3907 again.
sortofageek
Re: P3907 also has the Gen 1 problem
Post by muziqaz »
that's what I like most about this project, immediate response and problem fixing. I got 3907 yesterday, and woke up this morning, and it is 100% finished, now just needs to be sent :) the only problem with this wu is that it is not recognized by fahmon, but that's different story :)
FAH Omega tester
Pette Broad
GPU Hardware..
3 x 460
1 X 260
4 X 250
I'm getting good Gen 1 P3906 units again :) . Thanks.
Pete
kasson
Pande Group Member
Post by kasson »
Glad it's working. Both 3906 and 3907 Gen 1's should be good now.
