171.67.108.13 classic vsp17v gbowman full Reject Mode
171.67.108.13 classic vsp17v gbowman full Reject Mode.
I have completed WUs, waiting to be uploaded to this server. I hope the issue will be corrected soon.
Thanks.
Thanks.
Re: 171.67.108.13 classic vsp17v gbowman full Reject Mode
It's back now :
171.67.108.13 classic vsp17v gbowman full Accepting
Are you still having trouble returning your WUs ?
chienquipete
hello
one wu gpu and one 2665 in the "fridge"
[13:13:03] (171.67.108.25:80) for the gpu
and for the smp
[13:29:35] + Attempting to send results [January 20 13:29:35 UTC]
[13:54:39] + Could not connect to Work Server (results)
[13:54:39] (171.64.65.64:8080)
[13:54:39] + Retrying using alternative port
i tried the command -send all it didn't work so
bye
and for the smp
bye
chienquipete
re
[14:50:19] Completed 7500 out of 250000 steps (3 percent)
[14:53:14] - Unknown packet returned from server, expected ACK for results
[14:53:14] - Error: Could not transmit unit 02 (completed January 20) to work server.
[14:53:14] Keeping unit 02 in queue.
[15:03:26] Writing local files
[15:03:26] Completed 10000 out of 250000 steps (4 percent)
what does it mean?
thank's
what does it mean?
thank's
I've just sent a WU to 171.64.65.64 ... and it gave me a new one right away.
It means that you have to upgrade your client to 6.23 : viewtopic.php?f=46&t=6642chienquipete wrote:re
what does it mean?
thank's
chienquipete
i shut down my client and i replace Folding@home-Win32-x86.exe by http://www.stanford.edu/~kasson/folding ... 32-x86.exe and restart my client?
i have downloaded the smp client there is 2 ou 3 days ; this client is not updated? (6.22 beta2 for MPICH (32-bit or 64-bit)
you can answer in french i understand english with most difficuties
EDIT: I just checked my exe (smp 3) they are all 413 KB
there is there another way to check?
Just replace your current exe with the one given in the linked post.
In French : la version disponible sur le site avec l'installeur n'est pas complètement à jour. Il faut que tu remplace ton exe actuel (fournit avec l'installeur) par celui qui est donné dans le post. Il suffit de quitter le client, remplacer l'exe, et relancer.
This means that there has been some sort of communications error. In most cases, upgrading the client to v6.23 will take care of the problem. In rare cases, you may have a proxy or firewall between your machine and the internet which discards important messages.chienquipete wrote:[14:53:14] - Unknown packet returned from server, expected ACK for results
what does it mean?
thank's
chienquipete
thank you totow
