MACHINE 1
[10:15:26] Project: 3906 (Run 16, Clone 4, Gen 1)
[10:15:26]
[10:15:26] Assembly optimizations on if available.
[10:15:26] Entering M.D.
[10:15:40] CoreStatus = C000000D (-1073741811)
[10:15:40] Client-core communications error: ERROR 0xc000000d
[10:15:40] Deleting current work unit & continuing...
[10:15:44] - Preparing to get new work unit...
[10:15:44] + Attempting to get work packet
[10:15:44] - Connecting to assignment server
[10:15:44] - Successful: assigned to (171.64.122.88).
[10:15:44] + News From Folding@Home: Welcome to Folding@Home
[10:15:45] Loaded queue successfully.
[10:15:48] + Closed connections
[10:15:53]
[10:15:53] + Processing work unit
[10:15:53] Core required: FahCore_7b.exe
[10:15:53] Core found.
[10:15:53] Working on Unit 04 [January 17 10:15:53]
[10:15:53] + Working ...
[10:15:53]
[10:15:53] *------------------------------*
[10:15:53] Folding@Home Double Gromacs Core B
[10:15:53] Version 1.04 (Fri Aug 10 16:46:39 PDT 2007)
[10:15:53]
[10:15:53] Preparing to commence simulation
[10:15:53] - Files status OK
[10:15:53] - Expanded 341797 -> 1169393 (decompressed 342.1 percent)
[10:15:53]
[10:15:53] Project: 3906 (Run 16, Clone 4, Gen 1)
[10:15:53]
[10:15:54] Assembly optimizations on if available.
[10:15:54] Entering M.D.
[10:16:05] CoreStatus = C000000D (-1073741811)
[10:16:05] Client-core communications error: ERROR 0xc000000d
[10:16:05] Deleting current work unit & continuing...
[10:16:09] - Preparing to get new work unit...
[10:16:09] + Attempting to get work packet
[10:16:09] - Connecting to assignment server
[10:16:10] - Successful: assigned to (171.64.122.88).
[10:16:10] + News From Folding@Home: Welcome to Folding@Home
[10:16:10] Loaded queue successfully.
[10:16:15] + Closed connectionsCode: Select all
[09:13:51] Project: 3906 (Run 14, Clone 2, Gen 1)
[09:13:51]
[09:13:51] Assembly optimizations on if available.
[09:13:51] Entering M.D.
[09:58:12] CoreStatus = C000000D (-1073741811)
[09:58:12] Client-core communications error: ERROR 0xc000000d
[09:58:12] Deleting current work unit & continuing...
[09:58:24] Trying to send all finished work units
[09:58:24] + No unsent completed units remaining.
[09:58:24] - Preparing to get new work unit...
[09:58:24] + Attempting to get work packet
[09:58:24] - Will indicate memory of 2047 MB.
[09:58:24] - Connecting to assignment server
[09:58:25] - Successful: assigned to (171.64.122.88).MACHINE 3
[09:58:22] Project: 3906 (Run 23, Clone 0, Gen 1)
[09:58:22]
[09:58:22] Assembly optimizations on if available.
[09:58:22] Entering M.D.
[09:58:34] CoreStatus = C000000D (-1073741811)
[09:58:34] Client-core communications error: ERROR 0xc000000d
[09:58:34] Deleting current work unit & continuing...
[09:58:38] - Preparing to get new work unit...
[09:58:38] + Attempting to get work packet
[09:58:38] - Connecting to assignment server
[09:58:39] - Successful: assigned to (171.64.122.88).
[09:58:39] + News From Folding@Home: Welcome to Folding@Home
[09:58:39] Loaded queue successfully.
[09:58:43] + Closed connections
[09:58:48]
[09:58:48] + Processing work unit
[09:58:48] Core required: FahCore_7b.exe
[09:58:48] Core found.
[09:58:48] Working on Unit 05 [January 17 09:58:48]
[09:58:48] + Working ...
[09:58:48]
[09:58:48] *------------------------------*
[09:58:48] Folding@Home Double Gromacs Core B
[09:58:48] Version 1.04 (Fri Aug 10 16:46:39 PDT 2007)
[09:58:48]
[09:58:48] Preparing to commence simulation
[09:58:48] - Files status OK
[09:58:48] - Expanded 330340 -> 1132781 (decompressed 342.9 percent)
[09:58:48]
[09:58:48] Project: 3906 (Run 23, Clone 0, Gen 1)
[09:58:48]
[09:58:49] Assembly optimizations on if available.
[09:58:49] Entering M.D.
[09:59:00] CoreStatus = C000000D (-1073741811)
[09:59:00] Client-core communications error: ERROR 0xc000000d
[09:59:00] - Attempting to download new core...
[09:59:00] + Downloading new core: FahCore_7b.exe
[09:59:01] + 10240 bytes downloaded
[09:59:05] + 724218 bytes downloaded
[09:59:05] Verifying core Core_7b.fah...
[09:59:05] Signature is VALID
[09:59:05]
[09:59:05] Trying to unzip core FahCore_7b.exe
[09:59:05] Decompressed FahCore_7b.exe (2101248 bytes) successfully
[09:59:05] + Core successfully engaged
[09:59:05] Deleting current work unit & continuing...Code: Select all
[11:29:49] Project: 3906 (Run 54, Clone 1, Gen 1)
[11:29:49]
[11:29:50] Assembly optimizations on if available.
[11:29:50] Entering M.D.
[11:48:15] CoreStatus = C000000D (-1073741811)
[11:48:15] Client-core communications error: ERROR 0xc000000d
[11:48:15] Deleting current work unit & continuing...EDIT, Just checked and I found that I have another seven P3906 units in progress, they are all Gen 0 and have Run numbers in the 4xxx range and are progressing O.K. The 3 machines whose logs are posted above eventually got allocated other work.
Pete
