Project: 2653 (Run 17, Clone 56, Gen 97)
anko1
(3.2GHz) HT;Windows XP
Post by anko1 »
EUE. This is using Windows SMP console, v. 6023 Beta R1.
[11:54:42] + Closed connections
[11:54:42]
[11:54:42] + Processing work unit
[11:54:42] Work type a1 not eligible for variable processors
[11:54:42] Core required: FahCore_a1.exe
[11:54:42] Core found.
[11:54:42] Using generic mpiexec calls
[11:54:42] Working on queue slot 00 [December 21 11:54:42 UTC]
[11:54:42] + Working ...
[11:54:42] - Calling 'mpiexec -np 4 -channel auto -host 127.0.0.1 FahCore_a1.exe -dir work/ -suffix 00 -checkpoint 15 -verbose -lifeline 856 -version 623'
[11:54:42]
[11:54:42] *------------------------------*
[11:54:42] Folding@Home Gromacs SMP Core
[11:54:42] Version 1.74 (March 10, 2007)
[11:54:42]
[11:54:42] Preparing to commence simulation
[11:54:42] - Ensuring status. Please wait.
[11:54:44] - Starting from initial work packet
[11:54:44]
[11:54:44] Project: 2653 (Run 17, Clone 56, Gen 97)
[11:54:44]
[11:54:44] Assembly optimizations on if available.
[11:54:44] Entering M.D.
[11:55:02] al work packet
[11:55:02]
[11:55:02] Project: 2653 (Run 17, Clone 56, Gen 97)
[11:55:02]
[11:55:02] 53 (Run 17, Clone 56, Gen 97)
[11:55:02]
[11:55:03] Entering M.D.
[11:55:09] Rejecting checkpoint
[11:55:10] SE boost OK.
[11:55:10] ein in POPC
[11:55:10] Writing local files
[11:55:11] Extra SSE boost OK.
[11:55:11] Writing local files
[11:55:11] Completed 0 out of 500000 steps  (0 percent)
[12:04:59] Writing local files
[12:04:59] Completed 5000 out of 500000 steps  (1 percent)
        {snip}
[23:31:59] Writing local files
[23:31:59] Completed 355000 out of 500000 steps  (71 percent)
[23:39:07] Gromacs cannot continue further.
[23:39:07] Going to send back what have done.
[23:39:07] logfile size: 8784
[23:39:07] - Writing 9320 bytes of core data to disk...
[23:39:07]   ... Done.
[23:39:07] - Failed to delete work/wudata_00.sas
[23:39:07] - Failed to delete work/wudata_00.goe
[23:39:07] Warning:  check for stray files
[23:39:07]
[23:39:07] Folding@home Core Shutdown: EARLY_UNIT_END
[23:39:07]
[23:39:10] CoreStatus = 7B (123)
[23:39:10] Sending work to server
[23:39:10] Project: 2653 (Run 17, Clone 56, Gen 97)
[23:39:10] + Attempting to send results [December 21 23:39:10 UTC]
[23:39:10] - Reading file work/wuresults_00.dat from core
[23:39:10]   (Read 9320 bytes from disk)
[23:39:10] Connecting to http://171.64.65.64:8080/
[23:39:11] Posted data.
[23:39:11] Initial: 0000; - Uploaded at ~10 kB/s
[23:39:11] - Averaged speed for that direction ~43 kB/s
[23:39:11] + Results successfully sent
[23:39:11] Thank you for your contribution to Folding@Home.
Re: Project: 2653 (Run 17, Clone 56, Gen 97)
You're the only one to have reported an issue with this WU ... two other people completed it successfully.
