Project: 2669 (Run 16, Clone 130, Gen 22)
Locked
alberts1414
Post by alberts1414 »
This WU has failed on 4 attempts to upload since mid afternoon (GMT) with the message "Server does not have record of this unit". Is there an issue with the server or some other problem anyone?
[15:33:10] Completed 250000 out of 250000 steps  (100%)
[15:34:11]
[15:34:11] Finished Work Unit:
[15:34:11] - Reading up to 21124656 from "work/wudata_09.trr": Read 21124656
[15:34:11] trr file hash check passed.
[15:34:11] - Reading up to 4483064 from "work/wudata_09.xtc": Read 4483064
[15:34:11] xtc file hash check passed.
[15:34:11] edr file hash check passed.
[15:34:11] logfile size: 179566
[15:34:11] Leaving Run
[15:34:15] - Writing 26018870 bytes of core data to disk...
[15:34:15]   ... Done.
[15:34:18] - Shutting down core
[15:34:18]
[15:34:18] Folding@home Core Shutdown: FINISHED_UNIT
[15:37:35] CoreStatus = 64 (100)
[15:37:35] Unit 9 finished with 75 percent of time to deadline remaining.
[15:37:35] Updated performance fraction: 0.738963
[15:37:35] Sending work to server
[15:37:35] + Attempting to send results
[15:37:35] - Reading file work/wuresults_09.dat from core
[15:37:35]   (Read 26018870 bytes from disk)
[15:37:35] Connecting to http://171.64.65.56:8080/
[15:37:35] - Couldn't send HTTP request to server
[15:37:35] + Could not connect to Work Server (results)
[15:37:35]     (171.64.65.56:8080)
[15:37:35] - Error: Could not transmit unit 09 (completed November 28) to work server.
[15:37:35] - 1 failed uploads of this unit.
[15:37:35]   Keeping unit 09 in queue.
[15:37:35] Trying to send all finished work units
[15:37:35] - 2 failed uploads of this unit.
[15:37:35] Connecting to http://171.67.108.25:8080/
[15:46:41] Posted data.
[15:46:41] Initial: 0000; - Uploaded at ~46 kB/s
[15:46:41] - Averaged speed for that direction ~45 kB/s
[15:46:41] - Server does not have record of this unit. Will try again later.
[15:46:41]   Could not transmit unit 09 to Collection server; keeping in queue.
[15:46:41] + Sent 0 of 1 completed units to the server
[15:46:41] - Preparing to get new work unit...
[15:46:41] + Attempting to get work packet
[15:46:41] - Connecting to assignment server
[15:46:41] Connecting to http://assign.stanford.edu:8080/
[15:46:42] Posted data.
[15:46:42] Initial: 40AB; - Successful: assigned to (171.64.65.64).
[15:46:42] + News From Folding@Home: Welcome to Folding@Home
[15:46:42] Loaded queue successfully.
[15:46:42] Connecting to http://171.64.65.64:8080/
[15:46:48] Posted data.
[15:46:48] Initial: 0000; - Receiving payload (expected size: 4729469)
[15:47:08] - Downloaded at ~230 kB/s
[15:47:08] - Averaged speed for that direction ~248 kB/s
[15:47:08] + Received work.
[15:47:08] Trying to send all finished work units
[15:47:08] + Attempting to send results
[15:47:08] - Reading file work/wuresults_09.dat from core
[15:47:08]   (Read 26018870 bytes from disk)
[15:47:08] Connecting to http://171.64.65.56:8080/
[15:47:08] - Couldn't send HTTP request to server
[15:47:08] + Could not connect to Work Server (results)
[15:47:08]     (171.64.65.56:8080)
[15:47:08] - Error: Could not transmit unit 09 (completed November 28) to work server.
[15:47:08] - 3 failed uploads of this unit.
[15:47:08] Connecting to http://171.67.108.25:8080/
[15:56:14] Posted data.
[15:56:15] Initial: 0000; - Uploaded at ~46 kB/s
[15:56:15] - Averaged speed for that direction ~45 kB/s
[15:56:15] - Server does not have record of this unit. Will try again later.
[15:56:15]   Could not transmit unit 09 to Collection server; keeping in queue.
[15:56:15] + Sent 0 of 1 completed units to the server
[15:56:15] + Closed connections
Reason: Added code tags. Changed title to standard WU format
Re: Project 2669 Run16 Clone130 Gen22
Please use the "Issue with specific server" forum to report this kind of issues ... and you'll find that there is already a thread about this server : viewtopic.php?f=18&t=5750
Locked
