Hi folks,, I'm just starting up,, and I have been getting the WU's and finishing them,,, but seems I'm having trouble sending the results in,, here is a sample of what I'm seeing:
+ Attempting to send results [November 26 22:03:30 UTC]
[22:06:39] - Couldn't send HTTP request to server
[22:06:39] + Could not connect to Work Server (results)
[22:06:39] (128.59.74.4:8080)
[22:06:39] + Retrying using alternative port
[22:07:00] - Couldn't send HTTP request to server
[22:07:00] + Could not connect to Work Server (results)
[22:07:00] (128.59.74.4:80)
[22:07:00] - Error: Could not transmit unit 03 (completed November 26) to work server.
[22:07:00] + Attempting to send results [November 26 22:07:00 UTC]
[22:07:01] - Couldn't send HTTP request to server
[22:07:01] (Got status 503)
[22:07:01] + Could not connect to Work Server (results)
[22:07:01] (171.65.103.100:8080)
[22:07:01] + Retrying using alternative port
[22:07:01] (171.65.103.100:80)
[22:07:01] Could not transmit unit 03 to Collection server; keeping in queue.
[22:07:01] + Closed connections
[22:07:01]
[22:07:01] + Processing work unit
[22:07:01] Core required: FahCore_81.exe
[22:07:01] Core found.
[22:07:01] Working on queue slot 04 [November 26 22:07:01 UTC]
[22:07:01] + Working ...
[22:07:01]
[22:07:01] *------------------------------*
Any thoughts of what I can do?
Thanx in advance Dave
new guy here,,, with questions,,
anandhanju
Re: new guy here,,, with questions,,
Hello Dave, the 503 errors you're seeing means the servers are busy. The client will attemt to resend them after a certain time so its not something you need to be worried about. The log segment you posted doesn't contain the Project number but from the server, I'm assuming its a 385x with has a soft expiry period of 40 days and a final deadline of 60 days.
Cheers!
Cheers!
[18:12:52] Core required: FahCore_7c.exe
[18:12:52] Core found.
[18:12:52] Working on queue slot 03 [November 26 18:12:52 UTC]
[18:12:52] + Working ...
[18:12:52]
[18:12:52] *------------------------------*
[18:12:52] Folding@Home Double Gromacs Core C
[18:12:52] Version 1.00 (Thu Apr 24 19:12:09 PDT 2008)
[18:12:52]
[18:12:52] Preparing to commence simulation
[18:12:52] - Files status OK
[18:12:52] - Expanded 1197735 -> 3333813 (decompressed 278.3 percent)
[18:12:52]
[18:12:52] Project: 3858 (Run 9317, Clone 0, Gen 15)
[18:12:52]
[18:12:52] Assembly optimizations on if available.
[18:12:52] Entering M.D.
[18:12:58] Will resume from checkpoint file
[18:13:00] Working on p3851_fkbprelative_complex
[18:13:00] Completed 0 out of 200000 steps (0%)
[18:13:00] Extra SSE2 boost OK
[18:13:01] Resuming from checkpoint
[18:13:01] Verified work/wudata_03.log
[18:13:01] Verified work/wudata_03.edr
[18:13:01] Verified work/wudata_03.xvg
[18:13:01] Verified work/wudata_03.trr
[18:13:01] Verified work/wudata_03.xtc
[18:13:01] Completed 164001 out of 200000 steps (82%)
[18:13:17] Opening ...
[18:25:19] Completed 166000 out of 200000 steps (83%)
[18:37:35] Completed 168000 out of 200000 steps (84%)
[18:41:09] Opening http://fah-web.stanford.edu/cgi-bin/mai ... e_Pruitt...
[18:42:12] Opening ...
[18:49:56] Completed 170000 out of 200000 steps (85%)
[19:02:09] Completed 172000 out of 200000 steps (86%)
[19:14:21] Completed 174000 out of 200000 steps (87%)
[19:26:32] Completed 176000 out of 200000 steps (88%)
[19:38:44] Completed 178000 out of 200000 steps (89%)
[19:50:56] Completed 180000 out of 200000 steps (90%)
[20:03:09] Completed 182000 out of 200000 steps (91%)
[20:15:20] Completed 184000 out of 200000 steps (92%)
[20:27:30] Completed 186000 out of 200000 steps (93%)
[20:39:42] Completed 188000 out of 200000 steps (94%)
[20:51:55] Completed 190000 out of 200000 steps (95%)
[21:04:07] Completed 192000 out of 200000 steps (96%)
[21:16:19] Completed 194000 out of 200000 steps (97%)
[21:28:31] Completed 196000 out of 200000 steps (98%)
[21:40:44] Completed 198000 out of 200000 steps (99%)
[21:52:56] Completed 200000 out of 200000 steps (100%)
[21:53:57]
[21:53:57] Finished Work Unit:
[21:53:57] - Reading up to 2156240 from "work/wudata_03.trr": Read 2156240
[21:53:57] - Reading up to 121528 from "work/wudata_03.xtc": Read 121528
[21:53:57] xvg file size: 65369
[21:53:57] logfile size: 38107
[21:53:57] Leaving Run
[21:53:57] - Writing 2467584 bytes of core data to disk...
[21:53:58] ... Done.
[21:53:58] - Shutting down core
[21:53:58]
[21:53:58] Folding@home Core Shutdown: FINISHED_UNIT
[21:54:00] CoreStatus = 64 (100)
[21:54:00] Sending work to server
[21:54:00] Project: 3858 (Run 9317, Clone 0, Gen 15)
[21:54:00] + Attempting to send results [November 26 21:54:00 UTC]
[21:57:10] - Couldn't send HTTP request to server
[21:57:10] + Could not connect to Work Server (results)
[21:57:10] (128.59.74.4:8080)
[21:57:10] + Retrying using alternative port
[21:57:10] (Got status 503)
[21:57:10] (128.59.74.4:80)
[21:57:10] - Error: Could not transmit unit 03 (completed November 26) to work server.
[21:57:10] Keeping unit 03 in queue.
[21:57:10] Project: 3858 (Run 9317, Clone 0, Gen 15)
[21:57:10] + Attempting to send results [November 26 21:57:10 UTC]
[22:00:19] - Couldn't send HTTP request to server
[22:00:19] + Could not connect to Work Server (results)
[22:00:19] (128.59.74.4:8080)
[22:00:19] + Retrying using alternative port
[22:03:28] - Couldn't send HTTP request to server
[22:03:28] + Could not connect to Work Server (results)
[22:03:28] (128.59.74.4:80)
[22:03:28] - Error: Could not transmit unit 03 (completed November 26) to work server.
[22:03:28] + Attempting to send results [November 26 22:03:28 UTC]
[22:03:28] (Got status 503)
[22:03:28] (171.65.103.100:8080)
[22:03:28] + Retrying using alternative port
[22:03:28] (171.65.103.100:80)
[22:03:28] Could not transmit unit 03 to Collection server; keeping in queue.
[22:03:28] - Preparing to get new work unit...
[22:03:28] + Attempting to get work packet
[22:03:28] - Connecting to assignment server
[22:03:28] - Successful: assigned to (171.64.122.72).
[22:03:28] + News From Folding@Home: Welcome to Folding@Home
[22:03:28] Loaded queue successfully.
[22:03:30] Project: 3858 (Run 9317, Clone 0, Gen 15)
[22:03:30] + Attempting to send results [November 26 22:03:30 UTC]
[22:07:01]
[22:07:01]
[22:07:01] Folding@Home Gromacs Simulated Tempering Core
[22:07:01] Version 1.10 (Oct 4, 2007)
[22:07:01]
[22:07:01] Preparing to commence simulation
[22:07:01] - Looking at optimizations...
[22:07:01] - Created dyn
[22:07:01] - Files status OK
[22:07:01] - Expanded 240468 -> 1167687 (decompressed 485.5 percent)
[22:07:01] - Starting from initial work packet
[22:07:01]
[22:07:01] Project: 4421 (Run 25, Clone 19, Gen 140)
[22:07:01]
[22:07:01] Assembly optimizations on if available.
[22:07:01] Entering M.D.
[22:07:07] Protein: p4421_Seq_51_unf_AMBER
[22:07:07]
[22:07:07] Writing local files
[22:09:18] Extra SSE boost OK.
[22:09:19] Writing local files
[22:09:19] Completed 0 out of 150000 steps (0%)
[22:10:36] Writing local files
[22:10:36] Completed 1500 out of 150000 steps (1%)
[22:11:53] Writing local files
[22:11:53] Completed 3000 out of 150000 steps (2%)
[22:13:11] Writing local files
[22:13:11] Completed 4500 out of 150000 steps (3%)
[22:14:28] Writing local files
[22:14:28] Completed 6000 out of 150000 steps (4%)
[22:15:45] Writing local filesAlso, the Quere slots,, some have been deleted,, some are done but upload failed, ect. If it's just that it will take time to finish, I'm good with that. But If there is some settings that I can tweak to help out the setup, I'm fine with that also.
Thanx for the info!!
[22:15:45] Completed 7500 out of 150000 steps (5%)
metal03326
- Hardware configuration: Mainboard: Asus M2R32-MVP (AMD 580X CrossFire Chipset)
CPU: AMD Athlon X2 3800+@2.4GHz
CPU cooler: Arctic Cooling Freezer 64 Pro PWM
RAM: 2x1 GB Team XTreme Dark 800MHz@5-5-5-16 in Dual Channel mode
Video Card: Sapphire HD 2600 XT@850MHz GDDR4@2200MHz
HDD: WESTERN DIGITAL 640GB Caviar® Black™ SATA2 7200rpm 32MB
OS: Microsoft Windows 7 Ultimate x64
Clients (always latest version): SMP2
Dell Inspiron 1000 (Celeron@2.2GHz) - Location: Vratsa, Bulgaria.
There is nothing you can do, but wait. And please use "Code" button, for the log file text, when you are posting.
