Project: 2665 (Run 2, Clone 252, Gen 70)
osgorth
Post by osgorth »
Just got an EUE from an SMP client (6.23), see below. I haven't had one in a long time to be honest. :)
Anybody reported this successfully?
[01:01:20] *------------------------------*
[01:01:20] Folding@Home Gromacs SMP Core
[01:01:20] Version 1.74 (March 10, 2007)
[01:01:20]
[01:01:20] Preparing to commence simulation
[01:01:20] - Looking at optimizations...
[01:01:20] .
[01:01:28] - Starting from initial work packet
[01:01:28]
[01:01:28] Project: 2665 (Run 2, Clone 252, Gen 70)
[01:01:28]
[01:01:29] Assembly optimizations on if available.
[01:01:29] Entering M.D.
[01:01:59] al work packet
[01:01:59]
[01:01:59] Project: 2665 (Run 2, Clone 252, Gen 70)
[01:01:59]
[01:02:00] 65 (Run 2, Clone 252, Gen 70)
[01:02:00]
[01:02:02] Entering M.D.
[01:02:10] Protein: HGG with glycosylations
[01:02:10] Writing local files
[01:02:12] Extra SSE boost OK.
[01:02:23] cal files
[01:02:24] Completed 0 out of 250000 steps  (0 percent)
[12:42:55] Completed 127500 out of 250000 steps  (51 percent)
[13:18:12] Warning:  long 1-4 interactions
[13:18:15] Quit 101 - NaN detected: (ener[0])
[13:18:15]
[13:18:15] Simulation instability has been encountered. The run has entered a
[13:18:15]   state from which no further progress can be made.
[13:18:15] This may be the correct result of the simulation, however if you
[13:18:15]   often see other project units terminating early like this
[13:18:15]   too, you may wish to check the stability of your computer (issues
[13:18:15]   such as high temperature, overclocking, etc.).
[13:18:15] Going to send back what have done.
[13:18:15] logfile size: 106181
[13:18:15] - Writing 106730 bytes of core data to disk...
[13:18:15]   ... Done.
[13:20:15]
[13:20:15] Folding@home Core Shutdown: EARLY_UNIT_END
[13:20:15]
[13:20:19] CoreStatus = 7B (123)
[13:20:19] Sending work to server
[13:20:19] Project: 2665 (Run 2, Clone 252, Gen 70)
Re: Project: 2665 (Run 2, Clone 252, Gen 70)
There are three reports of failure in the DB ... that's probably a bad WU :(
