Hey
im working on a plugin for mediaportal which will show the work in progress to the user. that includes the progress, name, tag, project description (what is it working on) and user stats.
The progress, name and tag can I pull out of the unitinfo.txt, but the project description and user stats I have to collect from the website.
Yes I can download the site look through the html but it will be a lot easier if there was an xml file which has these data?
Does this exists? If not is there a plan to develop it?
Thanks
Get user stats in xml?
Re: Get user stats in xml?
A mate is gunna help me try and extract my team/personal stats daily and export to an excel document automatically for me.. but i don't think he's looked into how it could be done.. so if the XML thingo could help, i'd be very much interested in finding this info out as well.
Cheers
Aussie Rules Footy | Team 52735
smASHer88 - AMD64 3500+ 2.2GHz 2GB WinXP Pro SP2 5.04
Lahm_Family - Apple MacBook Pro 13" 2.26GHz 2GB SMP
smASHer88_PS3 & Lahm_Family_PS3 - both 40GB PAL PS3s
EOC has an XML file for users stats:
http://folding.extremeoverclocking.com/?nav=XML
For project description and other project data you'll have to parse the psummary.html and fahproject output.
I am not sure about psumarry but the other it surely prohibited afaik. You can use the full donor list and team list for external stats. Infact I do parse psummary myself with some applications, so maybe I am myself breaking some rules without being sure of it. I would appriciate a pg member/mod/admin from here to comment on psummary parsingsmoking2000 wrote:EOC has an XML file for users stats:
I posted a code snipper for parsing the full donor list in vb.net yesterday, working on a statistics site for the team I'm a member of.
With regard to the psummary, every 3rd party app which shows project data gets it from parsing the psummary. Just don't tell about beta projects.
Crawling the CGI pages is not allowed, but in some cases an exception could be made for scraping, as mentioned back on FCF and since copied to the wiki:
http://fahwiki.net/index.php/TeamStatsFile
The Team Stats file is available in both HTML and text form.
Only for the top n teams are these files generated. If a team drops below the rank of n-2, the files will not be generated any more, but the last ones will not be removed either. The value of n seems to vary, at one point in time it was 1240, at a later time it was 1674, right now it may be different again. Originally the files where generated for the top 500 team, later for the top 1500.
All the Team Stats files are available at:
http://fah-web.stanford.edu/teamstats/
They are updated every 3 hours.
This may have changed to once a day according to Folding-community: individual team stats update
The HTML file of the teams are linked on the team stats CGI page if is available, and contains the exact same information as the text file.
These team stats text files were created to be used by 3rd party stats applications to reduce the load on Stanfords servers.
Therefor if you create an application which uses stats for one or more teams, you should use the team stats text files instead of the CGI webpages.
In the case that there are no team stats files for the team you need the data for, you can grab the CGI page for that team, but DO NOT crawl through the CGI pages. Your IP will be banned if you do crawl the CGI pages.
If you only want the stats for one or more teams you could also consider the Full team list (daily_team_summary.txt). This file contains only the overall score and number of work units for all the teams, but not the team members, sorted by rank.
Thanks for the information What I don't understand though is, how can there be no information in the teams list or full donors list which is available through the cgi pages? I think none of the external stats site would object to having anyone included in the full donors list and every team in the team listings. Maybe back then there where more bandwidth conserns but I don't feel like it would bother me if I had to parse through more donors then I do with the 25mb listings ( as long as not everyone from team 0 is listed ).smoking2000 wrote:With regard to the psummary, every 3rd party app which shows project data gets it from parsing the psummary. Just don't tell about beta projects.
http://fahwiki.net/index.php/TeamStatsFileThe Team Stats file is available in both HTML and text form.
Edit: an example of a psummary parser in vb.net ( I download to a temp file and then parse, save in xml. ) If you want use a streameader to skip downloading.
Imports System.Xml
Imports System.Xml.XPath
Public Class clsProjectInfo
#Region "Declarations for collections and file downloading"
Private Const urlPsummary As String = "http://fah-web.stanford.edu/psummary.html"
'Temp file holder
Private fileTemp As String = Environment.GetFolderPath(Environment.SpecialFolder.ApplicationData) & "\FAHwatch\TmpProjects.tmp"
Private fileXML As String = Environment.GetFolderPath(Environment.SpecialFolder.ApplicationData) & "\FAHwatch\Projects.xml"
'Parsing constants
Private Const parseHeader As String = "<TD>Contact</TD>"
Private Const parseEnd As String = "</TABLE>"
'private properties
Shared colProjectNumber As New Collection
Shared colServerIP As New Collection
Shared colWorkUnitName As New Collection
Shared colNumberOfAtoms As New Collection
Shared colPreferredDays As New Collection
Shared colFinalDeadline As New Collection
Shared colCredit As New Collection
Shared colFrames As New Collection
Shared colCode As New Collection
Shared colDescriptionURL As New Collection
Shared colContact As New Collection
Shared intProjectCount As Int16 = 0
Public Enum eSource
Psummary = 1
PsummaryC = 2
End Enum
Public Function GetProjects(ByVal Source As eSource, Optional ByVal xtraFile As String = "") As Boolean
'check for network
Try
AddLog("Start getting projects")
If Not My.Computer.Network.IsAvailable Then
AddLog("No network available")
Return False
End If
'Clean collections
intProjectCount = 0
colProjectNumber.Clear() : colServerIP.Clear() : colWorkUnitName.Clear()
colNumberOfAtoms.Clear() : colPreferredDays.Clear() : colFinalDeadline.Clear()
colCredit.Clear() : colFrames.Clear() : colCode.Clear() : colDescriptionURL.Clear() : colContact.Clear()
Dim allTEXT As String
'Start with normal psummary
If My.Computer.FileSystem.FileExists(fileTemp) Then My.Computer.FileSystem.DeleteFile(fileTemp)
If Source = eSource.Psummary Then
Try
AddLog("Download psummary file")
My.Computer.Network.DownloadFile(urlPsummary, fileTemp)
Catch ex As Exception
AddLog("Error while downloading psummary")
AddLog("*" & Err.Number & " - " & Err.Description)
AddLog("*" & ex.Message)
Err.Clear()
Return False
End Try
allTEXT = My.Computer.FileSystem.ReadAllText(fileTemp)
If InStr(allTEXT, parseHeader) = 0 Then
AddLog("File does not seem to contain any project info")
Return False
Exit Function
Else
allTEXT = Mid(allTEXT, InStr(allTEXT, parseHeader) + Len(parseHeader))
End If
ParseProjects(allTEXT)
ElseIf Source = eSource.PsummaryC Then
Try
AddLog("Download psummaryC file")
My.Computer.Network.DownloadFile(urlPsummaryC, fileTemp)
Err.Clear()
Return False
End Try
Return False
Exit Function
Else
End If
End If
If xtraFile = "" Then
WriteXML()
AddLog("Finish getting projects")
Return True
End If
allTEXT = My.Computer.FileSystem.ReadAllText(xtraFile)
WriteXML()
Return True
Exit Function
Else
End If
WriteXML()
Return True
AddLog("Error while downloading project files")
Err.Clear()
Return False
End Try
End Function
Private Sub ParseProjects(ByVal allText As String)
Dim colKey As String ' every collection key is the projectnumber
Dim strTmp As String ' needed because parsing in one time is sh1t
AddLog("Parsing projects")
Do
'Cut to after <TD>
Try
allText = Mid(allText, InStr(allText, "<TD>") + 4)
colKey = Mid(allText, 1, InStr(allText, "</TD>") - 1).Trim
If Not colProjectNumber.Contains(colKey) Then
colProjectNumber.Add(colKey, colKey)
'Cut to after <TD>
If Mid(allText, 1, InStr(allText, "</TD>") - 1).Trim <> "" Then
colServerIP.Add(Mid(allText, 1, InStr(allText, "</TD>") - 1).Trim, colKey)
Else
colServerIP.Add("", colKey)
End If
'Cut to after <TD>
colWorkUnitName.Add(Mid(allText, 1, InStr(allText, "</TD>") - 1).Trim, colKey)
Else
colWorkUnitName.Add("", colKey)
End If
'Cut to after <TD>
colNumberOfAtoms.Add(Mid(allText, 1, InStr(allText, "</TD>") - 1).Trim, colKey)
Else
colNumberOfAtoms.Add("", colKey)
End If
'Cut to after <TD>
colPreferredDays.Add(Mid(allText, 1, InStr(allText, "</TD>") - 1).Trim, colKey)
Else
colPreferredDays.Add("", colKey)
End If
'Cut to after <TD>
colFinalDeadline.Add(Mid(allText, 1, InStr(allText, "</TD>") - 1).Trim, colKey)
Else
colFinalDeadline.Add("", colKey)
End If
'Cut to after <TD>
colCredit.Add(Mid(allText, 1, InStr(allText, "</TD>") - 1).Trim, colKey)
Else
colCredit.Add("", colKey)
End If
'Cut to after <TD>
colFrames.Add(Mid(allText, 1, InStr(allText, "</TD>") - 1).Trim, colKey)
Else
colFrames.Add("", colKey)
End If
'Cut to after <TD>
colCode.Add(Mid(allText, 1, InStr(allText, "</TD>") - 1).Trim, colKey)
Else
colCode.Add("", colKey)
End If
'Cut to after <TD>
strTmp = Mid(allText, 1, InStr(allText, "</TD>") - 1).Trim
'Looks like "<a href=http://fah-web.stanford.edu/cgi-bin/fahproject?p=772>Description</a>"
colDescriptionURL.Add(Mid(strTmp, InStr(strTmp, "http"), InStr(strTmp, ">Des") - 9), colKey)
Else
colDescriptionURL.Add("", colKey)
End If
'Cut to after <TD>
'looks like "<font size=-1>vvishal</font>"
strTmp = Mid(strTmp, InStr(strTmp, ">") + 1)
colContact.Add(Mid(strTmp, 1, Len(strTmp) - 7), colKey)
Else
'cut alltext
For tentimes As Int16 = 1 To 10
Next
End If
AddLog("Error while parsing projects from file")
Err.Clear()
Exit Do
End Try
If InStr(allText, "<TD>") = 0 Then Exit Do
Loop
End Sub
Private Sub WriteXML()
Try
AddLog("Writing projects to xml file")
If My.Computer.FileSystem.FileExists(fileXML) Then My.Computer.FileSystem.DeleteFile(fileXML)
Dim xSettings As New XmlWriterSettings
xSettings.Indent = True
xSettings.IndentChars = " "
Dim xWriter As XmlWriter = XmlWriter.Create(fileXML, xSettings)
xWriter.WriteStartElement("Projects")
xWriter.WriteStartElement("Count")
xWriter.WriteString(colProjectNumber.Count.ToString)
xWriter.WriteEndElement()
For x As Integer = 1 To colProjectNumber.Count
With xWriter
.WriteStartElement("Project")
.WriteStartElement("Projectnumber")
.WriteString(colProjectNumber(x).ToString)
.WriteEndElement()
.WriteStartElement("ServerIP")
.WriteString(colServerIP(x).ToString)
.WriteEndElement()
.WriteStartElement("WorkunitName")
.WriteString(colWorkUnitName(x).ToString)
.WriteEndElement()
.WriteStartElement("NumberOfAtoms")
.WriteString(colNumberOfAtoms(x).ToString)
.WriteEndElement()
.WriteStartElement("PreferredDays")
.WriteString(colPreferredDays(x).ToString)
.WriteEndElement()
.WriteStartElement("FinalDeadline")
.WriteString(colFinalDeadline(x).ToString)
.WriteEndElement()
.WriteStartElement("Credit")
.WriteString(colCredit(x).ToString)
.WriteEndElement()
.WriteStartElement("Frames")
.WriteString(colFrames(x).ToString)
.WriteEndElement()
.WriteStartElement("Code")
.WriteString(colCode(x).ToString)
.WriteEndElement()
.WriteStartElement("Description")
.WriteString(colDescriptionURL(x).ToString)
.WriteEndElement()
.WriteStartElement("Contact")
.WriteString(colContact(x).ToString)
.WriteEndElement()
.WriteEndElement()
End With
Next
xWriter.Close()
xWriter = Nothing
AddLog("Finished writing projects")
AddLog("Error while writing projects.xml")
Err.Clear()
End Try
End Sub
Private Sub ReadXML()
Try
AddLog("Starting to read projects xml")
Dim Xreader As XmlReader = XmlReader.Create(fileXML)
Dim colKey As String, intCount As Int16
'Clean collections
intProjectCount = 0
Xreader.ReadStartElement("Projects")
Xreader.ReadStartElement("Count")
intCount = CInt(Xreader.ReadString)
Xreader.ReadEndElement()
AddLog("Projects expected: " & intCount)
For Counter As Int16 = 1 To intCount
With Xreader
.ReadStartElement("Project")
.ReadStartElement("Projectnumber")
colKey = .ReadString
.ReadEndElement()
.ReadStartElement("ServerIP")
colServerIP.Add(.ReadString, colKey)
.ReadEndElement()
.ReadStartElement("WorkunitName")
colWorkUnitName.Add(.ReadString, colKey)
.ReadEndElement()
.ReadStartElement("NumberOfAtoms")
colNumberOfAtoms.Add(.ReadString, colKey)
.ReadEndElement()
.ReadStartElement("PreferredDays")
colPreferredDays.Add(.ReadString, colKey)
.ReadEndElement()
.ReadStartElement("FinalDeadline")
colFinalDeadline.Add(.ReadString, colKey)
.ReadEndElement()
.ReadStartElement("Credit")
colCredit.Add(.ReadString, colKey)
.ReadEndElement()
.ReadStartElement("Frames")
colFrames.Add(.ReadString, colKey)
.ReadEndElement()
.ReadStartElement("Code")
colCode.Add(.ReadString, colKey)
.ReadEndElement()
.ReadStartElement("Description")
colDescriptionURL.Add(.ReadString, colKey)
.ReadEndElement()
.ReadStartElement("Contact")
colContact.Add(.ReadString, colKey)
.ReadEndElement()
.ReadEndElement()
End With
Next
Xreader.Close()
Xreader = Nothing
AddLog("Finished reading projects from xml")
Err.Clear()
End Try
End Sub
#End Region
#Region "Project info properties"
Public ReadOnly Property ServerIP(ByVal Projectnumber As String) As String
Get
ServerIP = colServerIP(Projectnumber).ToString
End Get
End Property
Public ReadOnly Property WorkUnitName(ByVal ProjectNumber As String) As String
Get
WorkUnitName = colWorkUnitName(ProjectNumber).ToString
End Get
End Property
Public ReadOnly Property NumberOfAtoms(ByVal ProjectNumber As String) As String
Get
NumberOfAtoms = colNumberOfAtoms(ProjectNumber).ToString
End Get
End Property
Public ReadOnly Property PreferredDays(ByVal ProjectNumber As String) As String
Get
PreferredDays = colPreferredDays(ProjectNumber).ToString
End Get
End Property
Public ReadOnly Property FinalDeadline(ByVal ProjectNumber As String) As String
Get
FinalDeadline = colFinalDeadline(ProjectNumber).ToString
End Get
End Property
Public ReadOnly Property Credit(ByVal ProjectNumber As String) As String
Get
Credit = colCredit(ProjectNumber).ToString
End Get
End Property
Public ReadOnly Property Frames(ByVal ProjectNumber As String) As String
Get
Frames = colFrames(ProjectNumber).ToString
End Get
End Property
Public ReadOnly Property Code(ByVal ProjectNumber As String) As String
Get
Code = colCode(ProjectNumber).ToString
End Get
End Property
Public ReadOnly Property DescriptionURL(ByVal ProjectNumber As String) As String
Get
DescriptionURL = colDescriptionURL(ProjectNumber).ToString
End Get
End Property
Public ReadOnly Property Contact(ByVal ProjectNumber As String) As String
Get
Contact = colContact(ProjectNumber).ToString
End Get
End Property
Public ReadOnly Property ProjectKnown(ByVal ProjectNumber As String) As Boolean
Get
If colProjectNumber.Contains(ProjectNumber) Then
Return True
Else
Return False
End If
End Get
End Property
Public ReadOnly Property Project(ByVal Index As Integer) As String
Get
Project = colProjectNumber(Index).ToString
End Get
End Property
Public ReadOnly Property ProjectCount() As Integer
Get
ProjectCount = colProjectNumber.Count
End Get
End Property
#End Region
#Region "Class starting point"
Public Sub New()
ReadXML()
Else
GetProjects(eSource.Psummary)
End If
End Sub
#End Region
End Class
