Here's another one,
Failed 5 times before the first frame completed and put the client to sleep for 24 hrs
Luckily I happened to check the rig before I left for work........
Project: 5014 (Run 4, Clone 29, Gen 221)
Re: Project: 5014 (Run 4, Clone 29, Gen 221)
There's no data for this WU in the DB
A Phantom Wu ??toTOW wrote:There's no data for this WU in the DB
Double checked the log file and the Wu is correct,
if it's any help, when it failed it was deleted, then loaded again from this server: "Successful: assigned to (171.64.65.20)."
We don't really need a "mystery Wu" out there with the capability of shutting down a good folding Gpu for 24hrs,
Thanks for looking anway,
Hopefully it can been found and dealt with.
Well, I don't know where it went, but I can't find it in the DB ... it looks like nobody returned itJester wrote:A Phantom Wu ??toTOW wrote:There's no data for this WU in the DB![]()
Failed and was deleted 5 times in quick succession, so it won't be getting returned or getting any error message returned if it behaves that way,toTOW wrote:Well, I don't know where it went, but I can't find it in the DB ... it looks like nobody returned itJester wrote:A Phantom Wu ??toTOW wrote:There's no data for this WU in the DB![]()
It'll be just upload...fail...deleted etc, etc,
How many times will the server dish out a Wu like this until it's obvious that nothing is being returned ?
I suppose that's a variable depending on the return date ?
