Have we established that if it says "Unstable Machine" as opposed to "Early Unit End," it's a core failure v. a bad WU?
[08:04:21] + Closed connections
[08:04:21]
[08:04:21] + Processing work unit
[08:04:21] Core required: FahCore_11.exe
[08:04:21] Core found.
[08:04:21] Working on queue slot 04 [October 31 08:04:21 UTC]
[08:04:21] + Working ...
[08:04:21] - Calling '.\FahCore_11.exe -dir work/ -suffix 04 -priority 96 -checkpoint 15 -verbose -lifeline 2388 -version 620'
[08:04:21]
[08:04:21] *------------------------------*
[08:04:21] Folding@Home GPU Core - Beta
[08:04:21] Version 1.15 (Mon Oct 13 11:11:30 PDT 2008)
[08:04:21]
[08:04:21] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[08:04:21] Build host: amoeba
[08:04:21] Board Type: Nvidia
[08:04:21] Core      :
[08:04:21] Preparing to commence simulation
[08:04:21] - Looking at optimizations...
[08:04:21] - Created dyn
[08:04:21] - Files status OK
[08:04:21] - Expanded 44153 -> 244433 (decompressed 553.6 percent)
[08:04:21] Called DecompressByteArray: compressed_data_size=44153 data_size=244433, decompressed_data_size=244433 diff=0
[08:04:21] - Digital signature verified
[08:04:21]
[08:04:21] Project: 5016 (Run 4, Clone 276, Gen 150)
[08:04:21]
[08:04:21] Assembly optimizations on if available.
[08:04:21] Entering M.D.
[08:04:27] Working on 576 p5005_supervillin_e1
[08:04:27] Client config found, loading data.
[08:04:28] Starting GUI Server
[08:05:58] Completed 1%
[08:07:27] Completed 2%
[08:08:57] Completed 3%
[08:10:23] Completed 4%
[08:11:48] Completed 5%
[08:13:19] Completed 6%
[08:14:46] Completed 7%
[08:16:13] Completed 8%
[08:17:44] Completed 9%
[08:19:11] Completed 10%
[08:20:38] Completed 11%
[08:22:08] Completed 12%
[08:23:39] Completed 13%
[08:25:09] Completed 14%
[08:26:38] Completed 15%
[08:28:08] Completed 16%
[08:29:37] Completed 17%
[08:31:07] Completed 18%
[08:32:38] Completed 19%
[08:34:07] Completed 20%
[08:35:37] Completed 21%
[08:37:07] Completed 22%
[08:38:37] Completed 23%
[08:40:07] Completed 24%
[08:41:37] Completed 25%
[08:43:06] Run: exception thrown during GuardedRun
[08:43:06] Run: exception thrown in GuardedRun -- Gromacs cannot continue further.
[08:43:06] Going to send back what have done -- stepsTotalG=25000000
[08:43:06] Work fraction=0.2598 steps=25000000.
[08:43:10] logfile size=39856 infoLength=39856 edr=0 trr=23
[08:43:10] - Writing 40392 bytes of core data to disk...
[08:43:10] Done: 39880 -> 6331 (compressed to 15.8 percent)
[08:43:10]   ... Done.
[08:43:10]
[08:43:10] Folding@home Core Shutdown: UNSTABLE_MACHINE
[08:43:13] CoreStatus = 7A (122)
[08:43:13] Sending work to server
[08:43:13] Project: 5016 (Run 4, Clone 276, Gen 150)
[08:43:13] - Read packet limit of 540015616... Set to 524286976.
[08:43:13] + Attempting to send results [October 31 08:43:13 UTC]
[08:43:13] - Reading file work/wuresults_04.dat from core
[08:43:13]   (Read 6843 bytes from disk)
[08:43:13] Connecting to http://171.64.65.20:8080/
[08:43:13] Posted data.
[08:43:13] Initial: 0000; Conversation time very short, giving reduced weight in bandwidth avg
[08:43:13] - Uploaded at ~15 kB/s
[08:43:13] - Averaged speed for that direction ~39 kB/s
[08:43:13] + Results successfully sent
[08:43:13] Thank you for your contribution to Folding@Home.
