EUE: Project: 2492 (Run 53, Clone 36, Gen 0)
Snyde
Post by Snyde »
I understand this project, 2492, has been suspended, just reporting another EUE.
[14:14:35] Completed 200000 out of 250000 steps  (80)
[14:29:35] Timered checkpoint triggered.
[14:44:36] Timered checkpoint triggered.
[14:59:36] Timered checkpoint triggered.
[15:14:38] Timered checkpoint triggered.
[15:14:53] Writing local files
[15:14:53] Completed 202500 out of 250000 steps  (81)
[15:29:54] Timered checkpoint triggered.
[15:33:34] - Autosending finished units...
[15:33:34] Trying to send all finished work units
[15:33:34] + No unsent completed units remaining.
[15:33:34] - Autosend completed
[15:44:53] Timered checkpoint triggered.
[15:59:53] Timered checkpoint triggered.
[16:14:55] Timered checkpoint triggered.
[16:15:14] Writing local files
[16:15:14] Completed 205000 out of 250000 steps  (82)
[16:30:15] Timered checkpoint triggered.
[16:45:16] Timered checkpoint triggered.
[17:00:16] Timered checkpoint triggered.
[17:15:18] Timered checkpoint triggered.
[17:15:32] Writing local files
[17:15:33] Completed 207500 out of 250000 steps  (83)
[17:26:02] Quit 101 - Fatal error:
[17:26:02] Step 207935, time 415.87 (ps)  LINCS WARNING
[17:26:02] relative constraint deviation after LINCS:
[17:26:02] max 65751563767691220000000.000000 (between atoms 18530 and 18531) rms 604297994181409770000.000000
[17:26:02]
[17:26:02] Simulation instability has been encountered. The run has entered a
[17:26:02]   state from which no further progress can be made.
[17:26:02] This may be the correct result of the simulation, however if you
[17:26:02]   often see other project units terminating early like this
[17:26:02]   too, you may wish to check the stability of your computer (issues
[17:26:02]   such as high temperature, overclocking, etc.).
[17:26:02] Going to send back what have done.
[17:26:02] logfile size: 46802
[17:26:02] - Writing 47529 bytes of core data to disk...
[17:26:02]   ... Done.
[17:26:02]
[17:26:02] Folding@home Core Shutdown: EARLY_UNIT_END
[17:26:06] CoreStatus = 72 (114)
[17:26:06] Sending work to server
regards- :)
jb
Re: EUE: Project: 2492 (Run 53, Clone 36, Gen 0)
Thanks for the report :)
