Kaspersky denying F@H client to run.
solorize
Post by solorize »
Hi,
I recently installaed Kaspersky Internet Security
and now I am having a problem getting the Foling Client to run?
Kaspersky keeps on denying the client to run and I am not
sure on which setting I need to adjust to get it to run sucessfully.
If anyone can shed any light on this I would be greatfull, as I don't
want to just start changing setting in Kaspersky and start making
my pc unsecure.
Regards
Solorize
Folding Team: UK Folding AllStars (team id: 137091)
Team Page: http://fah-web.stanford.edu/cgi-bin/mai ... num=137091
MRD Photography
http://www.mrdphotography.co.uk
Re: Kaspersky denying F@H client to run.
You should put en exception on the FAH folder (and/or program) to exclude it from security checks (you know FAH is safe to run ;)).
John Naylor
Hardware configuration: Q9450 OC @ 3.2GHz (Win7 Home Premium) - SMP2
i5-3750k @ 3.8GHz (Win7 Pro) - SMP2
Post by John Naylor »
If you want to just remove security for the F@H folder only, while still leaving the rest of your computer protected by Kaspersky, do this...
Main window | Settings | Threats and Exclusions | Trusted Zone | Add
Then add the path to the folding@home folder and you should find it works without disturbing the rest of your computer's protection :)
Folding whatever I'm sent since March 2006 :) Beta testing since October 2006. www.FAH-Addict.net Administrator since August 2009.
solorize
Post by solorize »
Thanks for both of your help I will give it a go tonight =)
Regards
Solorize
MRD Photography
