Project: 2665 (Run 0, Clone 656, Gen 53)
ElectricVehicle
Post by ElectricVehicle »
Can someone please check for other reports in the DB on this wu? Thanks!
[15:12:32] Completed 170000 out of 250000 steps (68 percent)
[15:19:31] Warning: long 1-4 interactions
[15:19:31] Quit 101 - NaN detected: (ener[20])
[15:19:31]
[15:19:31] Simulation instability has been encountered. The run has entered a
[15:19:31] state from which no further progress can be made.
[15:19:31] This may be the correct result of the simulation, however if you
[15:19:31] often see other project units terminating early like this
[15:19:31] too, you may wish to check the stability of your computer (issues
[15:19:31] such as high temperature, overclocking, etc.).
[15:19:31] Going to send back what have done.
[15:19:31] logfile size: 26304
[15:19:31] - Writing 26854 bytes of core data to disk...
[15:19:31] ... Done.
[15:19:31] - Failed to delete work/wudata_02.arc
[15:19:31] Warning: check for stray files
[15:21:31]
[15:21:31] Folding@home Core Shutdown: EARLY_UNIT_END
[15:21:31]
[15:21:34] CoreStatus = 7B (123)
[15:21:34] Client-core communications error: ERROR 0x7b
[15:21:34] Deleting current work unit & continuing...
[15:21:34] Using generic mpiexec calls
[15:23:38] - Warning: Could not delete all work unit files (2): Core returned invalid code
[15:23:38] Trying to send all finished work units
[15:23:38] + No unsent completed units remaining.
                       Folding@Home Client Version 6.22 SMP Beta2r3
                          http://folding.stanford.edu
Launch directory: C:\Fah
Executable: C:\Fah\Folding@home-Win32-x86.exe
Arguments: -smp -verbosity 9
[16:10:38] - Ask before connecting: No
[16:10:38] - User name: [EV]Solar (Team 104636)
[16:10:38] - User ID: 37D9A66E498A77C3
[16:10:38] - Machine ID: 1
[16:10:38]
[16:10:38] Loaded queue successfully.
[16:10:38]
[16:10:38] + Processing work unit
[16:10:38] - Autosending finished units... [October 2 16:10:38 UTC]
[16:10:38] Work type a1 not eligible for variable processors
[16:10:38] Trying to send all finished work units
[16:10:38] Core required: FahCore_a1.exe
[16:10:38] + No unsent completed units remaining.
[16:10:38] - Autosend completed
[16:10:38] Core found.
[16:10:38] Using generic mpiexec calls
[16:10:38] Working on queue slot 02 [October 2 16:10:38 UTC]
[16:10:38] + Working ...
[16:10:38] - Calling 'mpiexec -np 4 -channel auto -host 127.0.0.1 FahCore_a1.exe -dir work/ -suffix 02 -checkpoint 30 -verbose -lifeline 5568 -version 622'
[16:10:38]
[16:10:38] *------------------------------*
[16:10:38] Folding@Home Gromacs SMP Core
[16:10:38] Version 1.74 (March 10, 2007)
[16:10:38]
[16:10:38] Preparing to commence simulation
[16:10:38] - Ensuring status. Please wait.
[16:10:55] - Looking at optimizations...
[16:10:55] - Working with standard loops on this execution.
[16:10:55] - Previous termination of core was improper.
[16:10:55] - Going to use standard loops.
[16:10:55] - Files status OK
[16:11:17] - Expanded 4749841 -> 24426905 (decompressed 514.2 percent)
[16:11:17]
[16:11:17] Project: 2665 (Run 0, Clone 656, Gen 53)
[16:11:17]
[16:11:18] Entering M.D.
[16:11:25] Warning:  cannot record process ID
[16:11:25] Calling FAH init
[16:11:27] Read topology
[16:11:27] ocal files
[16:11:27] Completed 22500 out of 250000 steps  (9 percent)
[16:11:27] ater
[16:11:27] Writing local files
[16:11:38] Extra SSE boost OK.
[16:35:31] Writing local files
[16:35:31] Completed 25000 out of 250000 steps  (10 percent)
[16:59:20] Writing local files
[16:59:20] Completed 27500 out of 250000 steps  (11 percent)
[17:22:53] Writing local files
[17:22:54] Completed 30000 out of 250000 steps  (12 percent)
[17:46:35] Writing local files
[17:46:35] Completed 32500 out of 250000 steps  (13 percent)
[18:10:11] Writing local files
[18:10:11] Completed 35000 out of 250000 steps  (14 percent)
[18:33:44] Writing local files
[18:33:44] Completed 37500 out of 250000 steps  (15 percent)
[18:57:18] Writing local files
[18:57:18] Completed 40000 out of 250000 steps  (16 percent)
[19:20:53] Writing local files
[19:20:53] Completed 42500 out of 250000 steps  (17 percent)
[19:44:25] Writing local files
[19:44:25] Completed 45000 out of 250000 steps  (18 percent)
[20:08:04] Writing local files
[20:08:04] Completed 47500 out of 250000 steps  (19 percent)
[20:31:39] Writing local files
[20:31:39] Completed 50000 out of 250000 steps  (20 percent)
[20:55:12] Writing local files
[20:55:12] Completed 52500 out of 250000 steps  (21 percent)
[21:18:47] Writing local files
[21:18:47] Completed 55000 out of 250000 steps  (22 percent)
[21:42:21] Writing local files
[21:42:21] Completed 57500 out of 250000 steps  (23 percent)
[22:05:56] Writing local files
[22:05:56] Completed 60000 out of 250000 steps  (24 percent)
[22:10:36] - Autosending finished units... [October 2 22:10:36 UTC]
[22:10:36] Trying to send all finished work units
[22:10:36] + No unsent completed units remaining.
[22:10:36] - Autosend completed
[22:29:31] Writing local files
[22:29:31] Completed 62500 out of 250000 steps  (25 percent)
[22:53:07] Writing local files
[22:53:07] Completed 65000 out of 250000 steps  (26 percent)
[23:16:41] Writing local files
[23:16:41] Completed 67500 out of 250000 steps  (27 percent)
[23:40:15] Writing local files
[23:40:15] Completed 70000 out of 250000 steps  (28 percent)
[00:03:50] Writing local files
[00:03:50] Completed 72500 out of 250000 steps  (29 percent)
[00:27:28] Writing local files
[00:27:28] Completed 75000 out of 250000 steps  (30 percent)
[00:51:07] Writing local files
[00:51:07] Completed 77500 out of 250000 steps  (31 percent)
[01:14:42] Writing local files
[01:14:42] Completed 80000 out of 250000 steps  (32 percent)
[01:38:16] Writing local files
[01:38:16] Completed 82500 out of 250000 steps  (33 percent)
[02:01:52] Writing local files
[02:01:52] Completed 85000 out of 250000 steps  (34 percent)
[02:25:25] Writing local files
[02:25:25] Completed 87500 out of 250000 steps  (35 percent)
[02:48:59] Writing local files
[02:48:59] Completed 90000 out of 250000 steps  (36 percent)
[03:12:30] Writing local files
[03:12:30] Completed 92500 out of 250000 steps  (37 percent)
[03:36:03] Writing local files
[03:36:03] Completed 95000 out of 250000 steps  (38 percent)
[03:59:56] Writing local files
[03:59:56] Completed 97500 out of 250000 steps  (39 percent)
[04:10:35] - Autosending finished units... [October 3 04:10:35 UTC]
[04:10:35] Trying to send all finished work units
[04:10:35] + No unsent completed units remaining.
[04:10:35] - Autosend completed
[04:23:37] Writing local files
[04:23:37] Completed 100000 out of 250000 steps  (40 percent)
[04:47:17] Writing local files
[04:47:17] Completed 102500 out of 250000 steps  (41 percent)
[05:10:47] Writing local files
[05:10:47] Completed 105000 out of 250000 steps  (42 percent)
[05:34:17] Writing local files
[05:34:17] Completed 107500 out of 250000 steps  (43 percent)
[05:57:56] Writing local files
[05:57:57] Completed 110000 out of 250000 steps  (44 percent)
[06:21:26] Writing local files
[06:21:26] Completed 112500 out of 250000 steps  (45 percent)
[06:44:52] Writing local files
[06:44:53] Completed 115000 out of 250000 steps  (46 percent)
[07:08:19] Writing local files
[07:08:20] Completed 117500 out of 250000 steps  (47 percent)
[07:31:46] Writing local files
[07:31:46] Completed 120000 out of 250000 steps  (48 percent)
[07:55:10] Writing local files
[07:55:11] Completed 122500 out of 250000 steps  (49 percent)
[08:18:39] Writing local files
[08:18:40] Completed 125000 out of 250000 steps  (50 percent)
[08:42:09] Writing local files
[08:42:09] Completed 127500 out of 250000 steps  (51 percent)
[09:05:53] Writing local files
[09:05:54] Completed 130000 out of 250000 steps  (52 percent)
[09:29:26] Writing local files
[09:29:26] Completed 132500 out of 250000 steps  (53 percent)
[09:52:55] Writing local files
[09:52:55] Completed 135000 out of 250000 steps  (54 percent)
[10:10:34] - Autosending finished units... [October 3 10:10:34 UTC]
[10:10:34] Trying to send all finished work units
[10:10:34] + No unsent completed units remaining.
[10:10:34] - Autosend completed
[10:16:23] Writing local files
[10:16:23] Completed 137500 out of 250000 steps  (55 percent)
[10:39:53] Writing local files
[10:39:53] Completed 140000 out of 250000 steps  (56 percent)
[11:03:23] Writing local files
[11:03:24] Completed 142500 out of 250000 steps  (57 percent)
[11:26:55] Writing local files
[11:26:55] Completed 145000 out of 250000 steps  (58 percent)
[11:50:25] Writing local files
[11:50:25] Completed 147500 out of 250000 steps  (59 percent)
[12:13:55] Writing local files
[12:13:55] Completed 150000 out of 250000 steps  (60 percent)
[12:37:21] Writing local files
[12:37:21] Completed 152500 out of 250000 steps  (61 percent)
[13:00:49] Writing local files
[13:00:49] Completed 155000 out of 250000 steps  (62 percent)
[13:24:17] Writing local files
[13:24:17] Completed 157500 out of 250000 steps  (63 percent)
[13:47:45] Writing local files
[13:47:46] Completed 160000 out of 250000 steps  (64 percent)
[14:11:12] Writing local files
[14:11:12] Completed 162500 out of 250000 steps  (65 percent)
[14:32:49] Writing local files
[14:32:49] Completed 165000 out of 250000 steps  (66 percent)
[14:52:42] Writing local files
[14:52:42] Completed 167500 out of 250000 steps  (67 percent)
[15:12:32] Writing local files
[15:19:31]
[15:21:31]
[15:21:31]
Fold On! (with 100% Renewable, 0 Carbon electricity) ElectricVehicle EV1, RAV4 EV, LEAF, Bolt EV, Volt, M3, s4 Simulator
Re: Project: 2665 (Run 0, Clone 656, Gen 53)
One report for partial credit, and one success.
