Fom log:
[00:28:13] Completed 2500000 out of 2500000 steps (100 percent)
[00:28:13] Writing final coordinates.
[00:28:14] Past main M.D. loop
[00:28:14] Will end MPI now
[00:29:14]
[00:29:14] Finished Work Unit:
[00:29:14] - Reading up to 1601592 from "work/wudata_01.arc": Read 1601592
[00:29:14] - Reading up to 492900 from "work/wudata_01.xtc": Read 492900
[00:29:14] goefile size: 0
[00:29:14] logfile size: 87555
[00:29:14] Leaving Run
[00:29:15] - Writing 2284883 bytes of core data to disk...
[00:29:15] ... Done.
[00:29:15] - Failed to delete work/wudata_01.sas
[00:29:15] - Failed to delete work/wudata_01.goe
[00:29:15] Warning: check for stray files
[00:29:15] - Shutting down core
[00:31:15]
[00:31:15] Folding@home Core Shutdown: FINISHED_UNIT
[00:31:15]
[00:31:18] CoreStatus = 7B (123)
[00:31:18] Client-core communications error: ERROR 0x7b
[00:31:18] This is a sign of more serious problems, shutting down
Running Qfix:
G:\Programfiler\Folding@Home Windows SMP Client V1.01>qfix
entry 2, status 0, address 0.0.0.0
entry 3, status 0, address 0.0.0.0
entry 4, status 0, address 0.0.0.0
entry 5, status 0, address 0.0.0.0
entry 6, status 0, address 0.0.0.0
entry 7, status 0, address 0.0.0.0
entry 8, status 0, address 0.0.0.0
entry 9, status 0, address 0.0.0.0
entry 0, status 0, address 0.0.0.0
entry 1, status 1, address 171.64.65.63:8080
Found results <work\wuresults_01.dat>: proj 3065, run 0, clone 178, gen 13
-- queue entry: proj 3065, run 0, clone 178, gen 13
-- queue entry isn't empty
File is OK
Trying -Send all
G:\Programfiler\Folding@Home Windows SMP Client V1.01>Folding@home-Win32-x86.ex
-send all
Note: Please read the license agreement (Folding@home-Win32-x86.exe -license).
urther
use of this software requires that you have read and accepted this agreement.
--- Opening Log file [September 18 06:25:54 UTC]
Folding@Home Client Version 6.22 SMP Beta2
http://folding.stanford.edu
Launch directory: G:\Programfiler\Folding@Home Windows SMP Client V1.01
Executable: Folding@home-Win32-x86.exe
Arguments: -send all
[06:25:54] - Ask before connecting: No
[06:25:54] - User name: BrgHW (Team 37651)
[06:25:54] - User ID: 555B5181794A3E62
[06:25:54] - Machine ID: 1
[06:25:54]
[06:25:54] Loaded queue successfully.
[06:25:54] Attempting to return result(s) to server...
Folding@Home Client Shutdown.
Project: 3065 (Run 0, Clone 178, Gen 16) Error 0x7b
Re: Project: 3065, Run 0, Clone 178, Gen 16. Error 0x7b
That's strange, I can't find that WU for you machine in the DB ... but it looks like your WU was sent (it's always better to run with -verbosity 9 switch too, to get a more detailed log).
anko1
- Hardware configuration: Old Faithful CPU: Windows Graphical 5.03; Intel Pentium 4 Processor 540
(3.2GHz) HT;Windows XP
Lenovo Think Pad: Windows 6.29 w/ SMP; Windows GPU Console 6.20r1 systray; Intel QX9300; NVIDIA Quadro FX-3700M; Windows XP Professional - Location: SF Peninsula
Also, may I recommend beta 2r3? It's solved the "quitting client" situation after an error for me, which I prefer.
http://foldingforum.org/viewtopic.php?f=46&t=4913
No it shuts down afte 3 sec. It is not possible to send or start the client again, until I have deleted "Queue" file and "Work" directory.toTOW wrote:That's strange, I can't find that WU for you machine in the DB ... but it looks like your WU was sent (it's always better to run with -verbosity 9 switch too, to get a more detailed log).
Ok I have started on this one now. Why is this not on Stanford's dowload page??anko1 wrote:Also, may I recommend beta 2r3? It's solved the "quitting client" situation after an error for me, which I prefer.
Thank You for the link
VijayPande
- Pande Group Member
Re: Project: 3065 (Run 0, Clone 178, Gen 16) Error 0x7b
It will get there after it's gone through enough testing. It's likely close.
I have had no errors after getting beta 2r3. Again thank you anko1 for the link
