I was getting great progress from this WU when it just froze up which I didn't notice for almost an hour. I restarted the client to no avail. I then deleted the WU core and all logs and guess what the client picked up the same exact WU and had no progress at all this time. There aren't any error codes noted in the logs just stops at this point. Nothing has changed on my end. It is maxing out it's assigned core. I'm not overclocking on the CPU. I have 4GB of memory between this classic uni-processor client and a GPU client. I am using GET and SET Affinity to seperate the two clients and their respective cores. I've not had any troubles thus far until now. Now what?
06:08:44] Folding@Home Gromacs Core
[06:08:44] Version 1.90 (March 8, 2006)
[06:08:44]
[06:08:44] Preparing to commence simulation
[06:08:44] - Looking at optimizations...
[06:08:44] - Created dyn
[06:08:44] - Files status OK
[06:08:48] - Expanded 3636088 -> 18750173 (decompressed 515.6 percent)
[06:08:48] - Starting from initial work packet
[06:08:48]
[06:08:48] Project: 2620 (Run 66, Clone 92, Gen 37)
[06:08:48]
[06:08:48] Assembly optimizations on if available.
[06:08:48] Entering M.D.
[06:08:55] Protein: p2620_p1475_tet1_03_1 t= 20000.00000
[06:08:55]
[06:08:55] Writing local files
eggman_42
- Hardware configuration: Ausus P5K-VM
Thermaltake Lan-Box Lite
Enermax 480 W
Intel Core 2 Duo E6550 @ 2.8GHZ
4GB Crucial Ballistix DDR2 1066
EVGA GeForce 8600 GT 512MB 558/1674/720
CPU Client V 6.20 on One Core ~500 ppd
Nvidia GPU Client V 6.20 ~2000 ppd - Location: Pueblo, CO
Re: Project: 2620 (Run 66, Clone 92, Gen 37)
Do you have an antivirus program that might be preventing FAH from working on its files?
eggman_42
Enermax 480 W
It fired back up. I thought I had excluded the folders from any anti virus scans but re-did it just to be sure. Thanks for the response.
