Project: 5506 (Run 6, Clone 751, Gen 40)
anko1
(3.2GHz) HT;Windows XP
Post by anko1 »
Well, as you can see, I'm catching up on my logs.
[14:17:12] + Closed connections
[14:17:12]
[14:17:12] + Processing work unit
[14:17:12] Core required: FahCore_11.exe
[14:17:12] Core found.
[14:17:12] Working on queue slot 04 [September 3 14:17:12 UTC]
[14:17:12] + Working ...
[14:17:12] - Calling '.\FahCore_11.exe -dir work/ -suffix 04 -priority 96 -checkpoint 15 -verbose -lifeline 180 -version 620'
[14:17:12]
[14:17:12] *------------------------------*
[14:17:12] Folding@Home GPU Core - Beta
[14:17:12] Version 1.09 (Fri Aug 1 11:46:54 PDT 2008)
[14:17:12]
[14:17:12] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[14:17:12] Build host: amoeba
[14:17:12] Board Type: Nvidia
[14:17:12] Core      :
[14:17:12] Preparing to commence simulation
[14:17:12] - Looking at optimizations...
[14:17:12] - Created dyn
[14:17:12] - Files status OK
[14:17:12] - Expanded 45398 -> 246249 (decompressed 542.4 percent)
[14:17:12] Called DecompressByteArray: compressed_data_size=45398 data_size=246249, decompressed_data_size=246249 diff=0
[14:17:12] - Digital signature verified
[14:17:12]
[14:17:12] Project: 5506 (Run 6, Clone 751, Gen 40)
[14:17:12]
[14:17:12] Assembly optimizations on if available.
[14:17:12] Entering M.D.
[14:17:18] Working on p5506_supervillin_e1
[14:17:19] Client config found, loading data.
[14:17:19] mdrun_gpu returned -1
[14:17:19] Going to send back what have done.
[14:17:19] Starting GUI Server
[14:17:20] logfile size: 10844 info=10844 bed=0 hdr=25
[14:17:20] - Writing 11382 bytes of core data to disk...
[14:17:20] Done: 10870 -> 3947 (compressed to 36.3 percent)
[14:17:20]   ... Done.
[14:17:20]
[14:17:20] Folding@home Core Shutdown: EARLY_UNIT_END
[14:17:22] CoreStatus = 72 (114)
[14:17:22] Sending work to server
[14:17:22] Project: 5506 (Run 6, Clone 751, Gen 40)
[14:17:22] - Read packet limit of 540015616... Set to 524286976.
[14:17:22] + Attempting to send results [September 3 14:17:22 UTC]
[14:17:22] - Reading file work/wuresults_04.dat from core
[14:17:22]   (Read 4459 bytes from disk)
[14:17:22] Connecting to http://171.64.65.106:8080/
[14:17:22] Posted data.
[14:17:22] Initial: 0000; Conversation time very short, giving reduced weight in bandwidth avg
[14:17:22] - Uploaded at ~10 kB/s
[14:17:22] - Averaged speed for that direction ~46 kB/s
[14:17:22] + Results successfully sent
[14:17:22] Thank you for your contribution to Folding@Home.
[14:17:26] Trying to send all finished work units
[14:17:26] + No unsent completed units remaining.
Re: Project: 5506 (Run 6, Clone 751, Gen 40)
Another bad one ... all reports are for 0 credits.
