I completed the subject work unit yesterday at 19:37 GMT, and it was successfully uploaded to the server this morning at 00:25 GMT. I have not received any credit for the wu. I am running the Linux client 6.02. Would someone please check the status. Here is a partial listing from the log file for this wu.
[06:03:24] + Attempting to get work packet
[06:03:24] - Connecting to assignment server
[06:03:24] - Successful: assigned to (171.64.65.65).
[06:03:24] + News From Folding@Home: Welcome to Folding@Home
[06:03:24] Loaded queue successfully.
[06:04:08] + Closed connections
[06:04:08]
[06:04:08] + Processing work unit
[06:04:08] Core required: FahCore_78.exe
[06:04:08] Core found.
[06:04:08] Working on Unit 08 [September 1 06:04:08]
[06:04:08] + Working ...
[06:04:08]
[06:04:08] *------------------------------*
[06:04:08] Folding@Home Gromacs Core
[06:04:08] Version 1.90 (March 8, 2006)
[06:04:08]
[06:04:08] Preparing to commence simulation
[06:04:08] - Looking at optimizations...
[06:04:08] - Created dyn
[06:04:08] - Files status OK
[06:04:10] - Expanded 9260497 -> 47924691 (decompressed 53.7 percent)
[06:04:11] - Starting from initial work packet
[06:04:11]
[06:04:11] Project: 2613 (Run 53, Clone 10, Gen 21)
[06:04:11]
[06:04:11] Assembly optimizations on if available.
[06:04:11] Entering M.D.
[06:04:20] Protein: p2613_TETHERED VESICLES
[06:04:20]
[06:04:20] Writing local files
[06:04:25] Extra SSE boost OK.
[06:04:26] Writing local files
[06:04:27] Completed 0 out of 125000 steps (0%)
[06:40:59] Writing local files
[06:41:00] Completed 1250 out of 125000 steps (1%)
[07:17:32] Writing local files
[07:17:33] Completed 2500 out of 125000 steps (2%)
[19:00:32] Completed 123750 out of 125000 steps (99%)
[19:37:09] Writing local files
[19:37:10] Completed 125000 out of 125000 steps (100%)
[19:37:10] Writing final coordinates.
[19:37:15] Past main M.D. loop
[19:38:16]
[19:38:16] Finished Work Unit:
[19:38:16] - Reading up to 7393248 from "work/wudata_08.arc": Read 7393248
[19:38:16] - Reading up to 10462752 from "work/wudata_08.xtc": Read 10462752
[19:38:16] goefile size: 0
[19:38:16] logfile size: 32465
[19:38:16] Leaving Run
[19:38:20] - Writing 17938029 bytes of core data to disk...
[19:38:27] Done: 17937517 -> 17459180 (compressed to 97.3 percent)
[19:38:27] ... Done.
[19:38:29] - Shutting down core
[19:38:29]
[19:38:29] Folding@home Core Shutdown: FINISHED_UNIT
[19:38:32] CoreStatus = 64 (100)
[19:38:32] Sending work to server
[19:38:32] - Read packet limit of 540015616... Set to 524286976.
[19:38:32] + Attempting to send results
[19:38:35] - Couldn't send HTTP request to server
[19:38:35] + Could not connect to Work Server (results)
[19:38:35] (171.64.65.65:8080)
[19:38:35] - Error: Could not transmit unit 08 (completed September 3) to work server.
[19:38:35] Keeping unit 08 in queue.
[19:38:35] - Read packet limit of 540015616... Set to 524286976.
[19:38:35] + Attempting to send results
[19:38:36] - Couldn't send HTTP request to server
[19:38:36] + Could not connect to Work Server (results)
[19:38:36] (171.64.122.76:8080)
[19:38:36] Could not transmit unit 08 to Collection server; keeping in queue.
[19:38:36] - Preparing to get new work unit...
[19:38:36] + Attempting to get work packet
[19:38:36] - Connecting to assignment server
[19:38:36] - Successful: assigned to (171.65.103.160).
[19:38:36] + News From Folding@Home: Welcome to Folding@Home
[19:38:36] Loaded queue successfully.
[19:38:37] - Read packet limit of 540015616... Set to 524286976.
[19:38:37] + Attempting to send results
[19:38:38] - Couldn't send HTTP request to server
[19:38:38] + Could not connect to Work Server (results)
[19:38:38] (171.64.65.65:8080)
[19:38:38] - Error: Could not transmit unit 08 (completed September 3) to work server.
[19:38:38] - Read packet limit of 540015616... Set to 524286976.
[19:38:38] + Attempting to send results
[19:38:38] (171.64.122.76:8080)
[19:38:38] Could not transmit unit 08 to Collection server; keeping in queue.
[19:38:38] + Closed connections
[00:20:29] + Attempting to send results
[00:24:04] Writing checkpoint files
[00:25:57] + Results successfully sent
[00:25:57] Thank you for your contribution to Folding@Home.
[00:25:57] + Number of Units Completed: 802
Re: Project: 2613 (Run 53, Clone 10, Gen 21)
I see a full credit for this WU, but not with "goodyca" as Username ...
Thorsten_Q.
- Hardware configuration: McOSX 10.6.4: MacBook, Mac mini, MacBook Pro
Ubuntu Linux 8.04:Core2Quad, Nvidia 9800gtx
Windows XP: Core2Quad, Nvidia 295gtx, Core2Duo (4x), Nvidia 240gt (2x), Nvidia 9600gt
Windows 7: Core i7 (3x), Nvidia 285gtx, , Nvidia 240gt, Nvidia 460 gtx (3x) - Location: old europe
I also miss at least one credit from the same server (171.64.65.65). WU 2613/35/8/25 uploaded about 12 hours ago and still no credit.
The collection server .76 is having trouble properly relaying work units to the work server .65.65. We're working on it. In the meantime, I changed the collection server settings so that the problematic CS will not accept work units that it can't relay. It may take a bit longer to return these WU's to the work server, but at least that way everything will be accounted for.
Here is the output from qd for the subject wu:toTOW wrote:I see a full credit for this WU, but not with "goodyca" as Username ...
Index 8: finished 755.00 pts (12.262 pt/hr) 15.6 X min speed
server: 171.64.65.65:8080; project: 2613, "p2613_TETHERED VESICLES"
Folding: run 53, clone 10, generation 21; benchmark 0; misc: 500, 400
issue: Mon Sep 1 01:03:24 2008; begin: Mon Sep 1 01:04:08 2008
end: Wed Sep 3 14:38:32 2008; due: Sat Oct 11 01:04:08 2008 (40 days)
preferred: Sun Sep 21 01:04:08 2008 (20 days)
core URL: http://www.stanford.edu/~pande/Linux/x86Core_78.fah (V1.90)
CPU: 1,0 x86; OS: 4,0 Linux
assignment info (le): Mon Sep 1 01:03:23 2008; BB174495
CS: 171.64.122.76; upload failures: 3; P limit: 524286976
user: goodyca; team: 439; ID: 39E9B0532092056A; mach ID: 1
work/wudata_08.dat file size: 9261009; WU type: Folding@Home
As can be seen, the user is "goodyca" and the unit was completed more than 2 weeks prior to the preferred due date.
Was this unit assigned to an additional user, or did the collection server make a mistake with the user name ???
The work server probably never got the WU back from the Collection Server ... so it assigned it to someone else, assuming your WU has been lost for some reason
That's definitely a weird behavior
