Hello!
I´d like to know, the same way the WUs are downloaded compressed, if the output can also be, before sending the results back to the servers. This is specially important as with some SMP WUs that the download size are usually 4.5Mb-5Mb (and decompressed to 27Mb) but the results are sent uncompressed the same size, 27Mb aprox.
Is this feasible?
Thanks!
WU Compression
Ultra Nexus
WU Compression
_-_ThaNexus_-_ folding for Team Icrontic (93)
^w^ing
- Hardware configuration: C2D E6400 2.13 GHz @ 3.2 GHz
Asus EN8800GTS 640 (G80) @ 660/792/1700 running the 6.23 w/ core11 v1.19
forceware 260.89
Asus P5N-E SLi
2GB 800MHz DDRII (2xCorsair TwinX 512MB)
WinXP 32 SP3 - Location: Prague
Re: WU Compression
results ARE compressed. (the compression method could be a bit better tho)
Re: WU Compression
They are already compressed ... but there are always things that you can't compress ...
^w^ing
forceware 260.89
Asus P5N-E SLi
Re: WU Compression
hm i just tried and the compression isnt so bad actually
