I think the Adrenalin 26.5.2 breaks F@H
kwerboom
Post by kwerboom »
Greetings. Today I upgraded from Adrenalin 26.3.1 to Adrenalin 26.5.2 and F@H failed. I had heard that there were issues with Adrenalin 26.5.1 with regards to Blender (link: https://videocardz.com/newz/blender-cyc ... ime-change ) and the release notes for Adrenalin 26.5.2 noted that users having issues should roll back to Adrenalin 26.3.1. I didn't think there would be an issue, but in the end I also wound up rolling back to Adrenalin 26.3.1 to get F@H working.
upgrade to Adrenalin 26.5.2:
*********************** Log Started 2026-05-15T18:51:55Z ***********************
18:51:55:I1:*********************** Folding@home Client ***********************
18:51:55:I1:    Version: 8.5.5
18:51:55:I1:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
18:51:55:I1:        Org: foldingathome.org
18:51:55:I1:  Copyright: 2023-2025, foldingathome.org
18:51:55:I1:   Homepage: https://foldingathome.org/
18:51:55:I1:    License: GPL-3.0-or-later
18:51:55:I1:        URL: https://v8-5.foldingathome.org/
18:51:55:I1:       Date: Dec 1 2025
18:51:55:I1:       Time: 13:40:46
18:51:55:I1:   Revision: 2c6fbaa45e4ee4854195a9f0d4b86300975b6543
18:51:55:I1:     Branch: master
18:51:55:I1:   Compiler: Visual C++
18:51:55:I1:    Options: $( /TP $) /std:c++17 /nologo /EHa /wd4297 /wd4103 /O2
18:51:55:I1:             /Zc:throwingNew /MT
18:51:55:I1:   Platform: win32 10
18:51:55:I1:       Bits: 64
18:51:55:I1:       Mode: Release
18:51:55:I1:****************************** CBang ******************************
18:51:55:I1:    Version: 1.7.2
18:51:55:I1:        Org: Cauldron Development
18:51:55:I1:  Copyright: Cauldron Development, 2003-2025
18:51:55:I1:   Homepage: https://cauldrondevelopment.com/
18:51:55:I1:    License: LGPL-2.1-or-later
18:51:55:I1:       Date: Dec 3 2025
18:51:55:I1:       Time: 11:44:07
18:51:55:I1:   Revision: 83a4be55c1b21d5383650f51a7887fd9c25b836c
18:51:55:I1:***************************** System ******************************
18:51:55:I1:        CPU: AMD Ryzen 5 7600X 6-Core Processor
18:51:55:I1:     CPU ID: AuthenticAMD Family 25 Model 97 Stepping 2
18:51:55:I1:       CPUs: 12
18:51:55:I1:     Memory: 31.16GiB
18:51:55:I1:Free Memory: 17.72GiB
18:51:55:I1: OS Version: 6.2
18:51:55:I1:Has Battery: false
18:51:55:I1: On Battery: false
18:51:55:I1:   Hostname: DESKTOP-6608UU8
18:51:55:I1: UTC Offset: -5
18:51:55:I1:        PID: 16064
18:51:55:I1:        CWD: C:\ProgramData\FAHClient
18:51:55:I1:       Exec: C:\Program Files\FAHClient\FAHClient.exe
18:51:55:I1:*******************************************************************
18:51:55:I2:<config/>
18:51:55:I1:Opening Database
18:51:55:I1:F@H ID = 8aOilh6YLQps5W1qTvspoDVTkjuCTeN251ZRFfq1U_Y
18:51:55:I3:Loading default resource group
18:51:55:I2:Listening for HTTP on 127.0.0.1:7396
18:51:55:I3:WU2239:Loading work unit 2239 with ID LZZmR74cS4tJsbFtrH0VrmLe-LAnNFSHw6bMpMziOLU
18:51:55:I3:Loaded 1 wus.
18:51:55:I2:Loading gpus.json
18:51:55:I1:Started Windows systray control
18:51:55:I3:gpus = {
18:51:55:I3:  "gpu:03:00:00": {
18:51:55:I3:    "vendor": 4098,
18:51:55:I3:    "type": "amd",
18:51:55:I3:    "description": "gfx1201",
18:51:55:I3:    "opencl": {"platform": 1, "device": 1, "compute": "2.0", "driver": "3652.0"},
18:51:55:I3:    "uuid": "30303030-3030-3033-3030-303030303030",
18:51:55:I3:    "hip": {"platform": 0, "device": 1, "compute": "12.0", "driver": "4724.20"},
18:51:55:I3:    "device": 30032,
18:51:55:I3:    "supported": true
18:51:55:I3:  },
18:51:55:I3:  "gpu:15:00:00": {
18:51:55:I3:    "description": "gfx1036",
18:51:55:I3:    "opencl": {"platform": 1, "device": 0, "compute": "2.0", "driver": "3652.0"},
18:51:55:I3:    "uuid": "30303030-3030-3135-3030-303030303030",
18:51:55:I3:    "hip": {"platform": 0, "device": 0, "compute": "10.3", "driver": "4724.20"},
18:51:55:I3:    "device": 5710,
18:51:55:I3:  }
18:51:55:I3:}
18:51:55:I2:OUT1:> GET /machine/8aOilh6YLQps5W1qTvspoDVTkjuCTeN251ZRFfq1U_Y HTTP/1.1
18:51:56:I2:OUT1:< HTTP/1.1 200 HTTP_OK
18:51:56:I2:OUT2:> GET /ws/client HTTP/1.1
18:51:56:I2:OUT2:< HTTP/1.1 101 HTTP_SWITCHING_PROTOCOLS
18:51:56:I1:Logging into node account
18:54:22:I2:REQ3:< GET /api/websocket HTTP/1.1
18:54:26:I1:Machine state fold
18:54:26:I1:Loaded cores/openmm-core-27/windows-10-64bit/release/fahcore-27-windows-10-64bit-release-8.2.1/FahCore_27.exe
18:54:26:I3:Running FahCore: C:\ProgramData\FAHClient\cores/openmm-core-27/windows-10-64bit/release/fahcore-27-windows-10-64bit-release-8.2.1/FahCore_27.exe -dir LZZmR74cS4tJsbFtrH0VrmLe-LAnNFSHw6bMpMziOLU -suffix 01 -version 8.5.5 -lifeline 16064 -gpu-uuid 30303030-3030-3033-3030-303030303030 -gpu-platform opencl -gpu-vendor amd -opencl-platform 1 -opencl-device 1 -hip-platform 0 -hip-device 1 -gpu 1
18:54:30:I3:WU2239:Started FahCore on PID 22248
18:54:30:I1:WU2239:*********************** Log Started 2026-05-15T18:54:30Z ***********************
18:54:30:I1:WU2239:*************************** Core27 Folding@home Core ***************************
18:54:30:I1:WU2239:       Core: Core27
18:54:30:I1:WU2239:       Type: 0x27
18:54:30:I1:WU2239:    Version: 8.2.1
18:54:30:I1:WU2239:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
18:54:30:I1:WU2239:  Copyright: 2022 foldingathome.org
18:54:30:I1:WU2239:   Homepage: https://foldingathome.org/
18:54:30:I1:WU2239:       Date: Mar 27 2025
18:54:30:I1:WU2239:       Time: 04:46:58
18:54:30:I1:WU2239:   Revision: 84019442387121f2bed4ed52e05c53b7b7b52a72
18:54:30:I1:WU2239:     Branch: HEAD
18:54:30:I1:WU2239:   Compiler: Visual C++
18:54:30:I1:WU2239:    Options: $( /TP $) /std:c++14 /nologo /EHa /wd4297 /wd4103 /O2
18:54:30:I1:WU2239:             /Zc:throwingNew /MT -DOPENMM_VERSION="\"8.2.0\"" /Ox /std:c++14
18:54:30:I1:WU2239:   Platform: win32 10
18:54:30:I1:WU2239:       Bits: 64
18:54:30:I1:WU2239:       Mode: Release
18:54:30:I1:WU2239:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
18:54:30:I1:WU2239:             <peastman@stanford.edu>
18:54:30:I1:WU2239:       Args: -dir LZZmR74cS4tJsbFtrH0VrmLe-LAnNFSHw6bMpMziOLU -suffix 01
18:54:30:I1:WU2239:             -version 8.5.5 -lifeline 16064 -gpu-uuid
18:54:30:I1:WU2239:             30303030-3030-3033-3030-303030303030 -gpu-platform opencl
18:54:30:I1:WU2239:             -gpu-vendor amd -opencl-platform 1 -opencl-device 1 -hip-platform 0
18:54:30:I1:WU2239:             -hip-device 1 -gpu 1
18:54:30:I1:WU2239:************************************ libFAH ************************************
18:54:30:I1:WU2239:       Time: 04:30:44
18:54:30:I1:WU2239:   Revision: c7d2824a47eb025fa8cda8968c7a5e971585d90c
18:54:30:I1:WU2239:    Options: $( /TP $) /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
18:54:30:I1:WU2239:************************************ CBang *************************************
18:54:30:I1:WU2239:    Version: 1.7.2
18:54:30:I1:WU2239:        Org: Cauldron Development LLC
18:54:30:I1:WU2239:  Copyright: Cauldron Development LLC, 2003-2024
18:54:30:I1:WU2239:   Homepage: https://cauldrondevelopment.com/
18:54:30:I1:WU2239:    License: LGPL-2.1-or-later
18:54:30:I1:WU2239:       Time: 04:29:12
18:54:30:I1:WU2239:   Revision: f1cd4c791e8c40a35dcfeab3ab85d910949cc0cb
18:54:30:I1:WU2239:************************************ System ************************************
18:54:30:I1:WU2239:        CPU: AMD Ryzen 5 7600X 6-Core Processor
18:54:30:I1:WU2239:     CPU ID: AuthenticAMD Family 25 Model 97 Stepping 2
18:54:30:I1:WU2239:       CPUs: 12
18:54:30:I1:WU2239:     Memory: 31.16GiB
18:54:30:I1:WU2239:Free Memory: 12.64GiB
18:54:30:I1:WU2239: OS Version: 10.0
18:54:30:I1:WU2239:Has Battery: false
18:54:30:I1:WU2239: On Battery: false
18:54:30:I1:WU2239:   Hostname: DESKTOP-6608UU8
18:54:30:I1:WU2239: UTC Offset: -5
18:54:30:I1:WU2239:        PID: 22248
18:54:30:I1:WU2239:        CWD: C:\ProgramData\FAHClient\work
18:54:30:I1:WU2239:       Exec: C:\ProgramData\FAHClient\cores\openmm-core-27\windows-10-64bit\release\fahcore-27-windows-10-64bit-release-8.2.1\FahCore_27.exe
18:54:30:I1:WU2239:************************************ OpenMM ************************************
18:54:30:I1:WU2239:    Version: 8.2.0
18:54:30:I1:WU2239:********************************************************************************
18:54:30:I1:WU2239:Project: 18245 (Run 27775, Clone 3, Gen 8)
18:54:30:I1:WU2239:Digital signatures verified
18:54:30:I1:WU2239:Folding@home GPU Core27 Folding@home Core
18:54:30:I1:WU2239:Version 8.2.1
18:54:30:I1:WU2239:  GPU info: Platform: OpenCL: AMD Accelerated Parallel Processing
18:54:30:I1:WU2239:  GPU info: PlatformIndex: 0
18:54:30:I1:WU2239:  GPU info: Device: gfx1036
18:54:30:I1:WU2239:  GPU info: DeviceIndex: 0
18:54:30:I1:WU2239:  GPU info: Vendor: 0x1002
18:54:30:I1:WU2239:  GPU info: PCI: 15:00:00
18:54:30:I1:WU2239:  GPU info: Compute: 2.0
18:54:30:I1:WU2239:  GPU info: Driver: 3679.0
18:54:30:I1:WU2239:  GPU info: GPU: true
18:54:30:I1:WU2239:  GPU info: Device: gfx1201
18:54:30:I1:WU2239:  GPU info: DeviceIndex: 1
18:54:30:I1:WU2239:  GPU info: PCI: 03:00:00
18:54:30:I1:WU2239:  GPU info: PlatformIndex: 1
18:54:30:I1:WU2239:  GPU info: Driver: 3652.0
18:54:30:I1:WU2239:  Checkpoint write interval: 62500 steps (5%) [20 total]
18:54:30:I1:WU2239:  JSON viewer frame write interval: 12500 steps (1%) [100 total]
18:54:30:I1:WU2239:  XTC frame write interval: 5000 steps (0.4%) [250 total]
18:54:30:I1:WU2239:  TRR frame write interval: disabled
18:54:30:I1:WU2239:  Global context and integrator variables write interval: disabled
18:54:30:I1:WU2239:There are 3 platforms available.
18:54:30:I1:WU2239:Platform 0: Reference
18:54:30:I1:WU2239:Platform 1: CPU
18:54:30:I1:WU2239:Platform 2: OpenCL
18:54:30:I1:WU2239:  opencl-device 1 specified
18:54:58:I1:WU2239:Attempting to create OpenCL context:
18:54:58:I1:WU2239:  Configuring platform OpenCL
18:55:01:E :WU2239:Core exited with Windows unhandled exception code 0xc0000005.  See https://bit.ly/2CXgWkZ for more information.
18:55:01:E :WU2239:Core returned FAILED_1 (0)
18:55:01:E :WU2239:Run did not produce any results. Dumping WU
18:55:01:I1:Default:Added new work unit: cpus:0 gpus:gpu:03:00:00
18:55:01:I1:WU2239:Sending dump report
18:55:01:I1:WU2240:Requesting WU assignment for user kwerboom_GRC_e9731a42787581aefd692a0981ffa510 team 224497
18:55:01:I2:OUT4:> POST /api/results HTTP/1.1
18:55:01:I2:OUT5:> POST /api/assign HTTP/1.1
18:55:01:I2:OUT5:< HTTP/1.1 200 HTTP_OK
18:55:01:I1:WU2240:Received WU assignment MB02xsn9uYRNdawWn60C_niIIoRZSCRAUy_LiKLf7vk
18:55:01:I1:WU2240:Downloading WU
18:55:01:I2:OUT6:> POST /api/assign HTTP/1.1
18:55:05:I1:WU2240:DOWNLOAD 100% 220B of 220B
18:55:07:I1:WU2240:DOWNLOAD 18% 3.27MiB of 17.64MiB
18:55:08:I1:WU2240:DOWNLOAD 26% 4.61MiB of 17.64MiB
18:55:09:I1:WU2240:DOWNLOAD 32% 5.70MiB of 17.64MiB
18:55:10:I1:WU2240:DOWNLOAD 40% 7.00MiB of 17.64MiB
18:55:11:I1:WU2240:DOWNLOAD 47% 8.31MiB of 17.64MiB
18:55:12:I1:WU2240:DOWNLOAD 54% 9.47MiB of 17.64MiB
18:55:12:I2:OUT4:< HTTP/1.1 200 HTTP_OK
18:55:12:I1:WU2239:Dumped
18:55:13:I1:WU2240:DOWNLOAD 62% 10.93MiB of 17.64MiB
18:55:14:I1:WU2240:DOWNLOAD 70% 12.41MiB of 17.64MiB
18:55:15:I1:WU2240:DOWNLOAD 78% 13.84MiB of 17.64MiB
18:55:16:I1:WU2240:DOWNLOAD 86% 15.26MiB of 17.64MiB
18:55:17:I1:WU2240:DOWNLOAD 93% 16.47MiB of 17.64MiB
18:55:18:I1:WU2240:DOWNLOAD 100% 17.64MiB of 17.64MiB
18:55:18:I2:OUT6:< HTTP/1.1 200 HTTP_OK
18:55:18:I1:WU2240:Received WU P17952 R5 C57 G8
18:55:18:I3:Running FahCore: C:\ProgramData\FAHClient\cores/openmm-core-27/windows-10-64bit/release/fahcore-27-windows-10-64bit-release-8.2.1/FahCore_27.exe -dir MB02xsn9uYRNdawWn60C_niIIoRZSCRAUy_LiKLf7vk -suffix 01 -version 8.5.5 -lifeline 16064 -gpu-uuid 30303030-3030-3033-3030-303030303030 -gpu-platform opencl -gpu-vendor amd -opencl-platform 1 -opencl-device 1 -hip-platform 0 -hip-device 1 -gpu 1
18:55:18:I3:WU2240:Started FahCore on PID 23340
18:55:18:I1:WU2240:*********************** Log Started 2026-05-15T18:55:18Z ***********************
18:55:18:I1:WU2240:*************************** Core27 Folding@home Core ***************************
18:55:18:I1:WU2240:       Core: Core27
18:55:18:I1:WU2240:       Type: 0x27
18:55:18:I1:WU2240:    Version: 8.2.1
18:55:18:I1:WU2240:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
18:55:18:I1:WU2240:  Copyright: 2022 foldingathome.org
18:55:18:I1:WU2240:   Homepage: https://foldingathome.org/
18:55:18:I1:WU2240:       Date: Mar 27 2025
18:55:18:I1:WU2240:       Time: 04:46:58
18:55:18:I1:WU2240:   Revision: 84019442387121f2bed4ed52e05c53b7b7b52a72
18:55:18:I1:WU2240:     Branch: HEAD
18:55:18:I1:WU2240:   Compiler: Visual C++
18:55:18:I1:WU2240:    Options: $( /TP $) /std:c++14 /nologo /EHa /wd4297 /wd4103 /O2
18:55:18:I1:WU2240:             /Zc:throwingNew /MT -DOPENMM_VERSION="\"8.2.0\"" /Ox /std:c++14
18:55:18:I1:WU2240:   Platform: win32 10
18:55:18:I1:WU2240:       Bits: 64
18:55:18:I1:WU2240:       Mode: Release
18:55:18:I1:WU2240:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
18:55:18:I1:WU2240:             <peastman@stanford.edu>
18:55:18:I1:WU2240:       Args: -dir MB02xsn9uYRNdawWn60C_niIIoRZSCRAUy_LiKLf7vk -suffix 01
18:55:18:I1:WU2240:             -version 8.5.5 -lifeline 16064 -gpu-uuid
18:55:18:I1:WU2240:             30303030-3030-3033-3030-303030303030 -gpu-platform opencl
18:55:18:I1:WU2240:             -gpu-vendor amd -opencl-platform 1 -opencl-device 1 -hip-platform 0
18:55:18:I1:WU2240:             -hip-device 1 -gpu 1
18:55:18:I1:WU2240:************************************ libFAH ************************************
18:55:18:I1:WU2240:       Time: 04:30:44
18:55:18:I1:WU2240:   Revision: c7d2824a47eb025fa8cda8968c7a5e971585d90c
18:55:18:I1:WU2240:    Options: $( /TP $) /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
18:55:18:I1:WU2240:************************************ CBang *************************************
18:55:18:I1:WU2240:    Version: 1.7.2
18:55:18:I1:WU2240:        Org: Cauldron Development LLC
18:55:18:I1:WU2240:  Copyright: Cauldron Development LLC, 2003-2024
18:55:18:I1:WU2240:   Homepage: https://cauldrondevelopment.com/
18:55:18:I1:WU2240:    License: LGPL-2.1-or-later
18:55:18:I1:WU2240:       Time: 04:29:12
18:55:18:I1:WU2240:   Revision: f1cd4c791e8c40a35dcfeab3ab85d910949cc0cb
18:55:18:I1:WU2240:************************************ System ************************************
18:55:18:I1:WU2240:        CPU: AMD Ryzen 5 7600X 6-Core Processor
18:55:18:I1:WU2240:     CPU ID: AuthenticAMD Family 25 Model 97 Stepping 2
18:55:18:I1:WU2240:       CPUs: 12
18:55:18:I1:WU2240:     Memory: 31.16GiB
18:55:18:I1:WU2240:Free Memory: 11.28GiB
18:55:18:I1:WU2240: OS Version: 10.0
18:55:18:I1:WU2240:Has Battery: false
18:55:18:I1:WU2240: On Battery: false
18:55:18:I1:WU2240:   Hostname: DESKTOP-6608UU8
18:55:18:I1:WU2240: UTC Offset: -5
18:55:18:I1:WU2240:        PID: 23340
18:55:18:I1:WU2240:        CWD: C:\ProgramData\FAHClient\work
18:55:18:I1:WU2240:       Exec: C:\ProgramData\FAHClient\cores\openmm-core-27\windows-10-64bit\release\fahcore-27-windows-10-64bit-release-8.2.1\FahCore_27.exe
18:55:18:I1:WU2240:************************************ OpenMM ************************************
18:55:18:I1:WU2240:    Version: 8.2.0
18:55:18:I1:WU2240:********************************************************************************
18:55:18:I1:WU2240:Project: 17952 (Run 5, Clone 57, Gen 8)
18:55:18:I1:WU2240:Reading tar file core.xml
18:55:18:I1:WU2240:Reading tar file integrator.xml
18:55:18:I1:WU2240:Reading tar file state.xml
18:55:18:I1:WU2240:Reading tar file system.xml
18:55:19:I1:WU2240:Digital signatures verified
18:55:19:I1:WU2240:Folding@home GPU Core27 Folding@home Core
18:55:19:I1:WU2240:Version 8.2.1
18:55:19:I1:WU2240:  GPU info: Platform: OpenCL: AMD Accelerated Parallel Processing
18:55:19:I1:WU2240:  GPU info: PlatformIndex: 0
18:55:19:I1:WU2240:  GPU info: Device: gfx1036
18:55:19:I1:WU2240:  GPU info: DeviceIndex: 0
18:55:19:I1:WU2240:  GPU info: Vendor: 0x1002
18:55:19:I1:WU2240:  GPU info: PCI: 15:00:00
18:55:19:I1:WU2240:  GPU info: Compute: 2.0
18:55:19:I1:WU2240:  GPU info: Driver: 3679.0
18:55:19:I1:WU2240:  GPU info: GPU: true
18:55:19:I1:WU2240:  GPU info: Device: gfx1201
18:55:19:I1:WU2240:  GPU info: DeviceIndex: 1
18:55:19:I1:WU2240:  GPU info: PCI: 03:00:00
18:55:19:I1:WU2240:  GPU info: PlatformIndex: 1
18:55:19:I1:WU2240:  GPU info: Driver: 3652.0
18:55:19:I1:WU2240:  Checkpoint write interval: 125000 steps (5%) [20 total]
18:55:19:I1:WU2240:  JSON viewer frame write interval: 25000 steps (1%) [100 total]
18:55:19:I1:WU2240:  XTC frame write interval: 25000 steps (1%) [100 total]
18:55:19:I1:WU2240:  TRR frame write interval: disabled
18:55:19:I1:WU2240:  Global context and integrator variables write interval: disabled
18:55:19:I1:WU2240:There are 3 platforms available.
18:55:19:I1:WU2240:Platform 0: Reference
18:55:19:I1:WU2240:Platform 1: CPU
18:55:19:I1:WU2240:Platform 2: OpenCL
18:55:19:I1:WU2240:  opencl-device 1 specified
18:55:28:I1:WU2240:Attempting to create OpenCL context:
18:55:28:I1:WU2240:  Configuring platform OpenCL
18:55:30:E :WU2240:Core exited with Windows unhandled exception code 0xc0000005.  See https://bit.ly/2CXgWkZ for more information.
18:55:30:E :WU2240:Core returned FAILED_1 (0)
18:55:30:E :WU2240:Run did not produce any results. Dumping WU
18:55:30:I1:Default:Added new work unit: cpus:0 gpus:gpu:03:00:00
18:55:30:I1:WU2240:Sending dump report
18:55:30:I1:WU2241:Requesting WU assignment for user kwerboom_GRC_e9731a42787581aefd692a0981ffa510 team 224497
18:55:30:I2:OUT7:> POST /api/results HTTP/1.1
18:55:30:I2:OUT8:> POST /api/assign HTTP/1.1
18:55:31:I2:OUT7:< HTTP/1.1 200 HTTP_OK
18:55:31:I1:WU2240:Dumped
18:55:31:I2:OUT8:< HTTP/1.1 200 HTTP_OK
18:55:31:I1:WU2241:Received WU assignment A_EFAMNGQMlNict3CpEaTY_98qGVQQaFMALLzNZxEh8
18:55:31:I1:WU2241:Downloading WU
18:55:33:I2:OUT9:> POST /api/assign HTTP/1.1
18:55:33:E :OUT9:Failed response: EOF
18:55:33:I1:WU2241:Retry #1 in 2 secs
18:55:35:I1:WU2241:Downloading WU
18:55:37:I2:OUT10:> POST /api/assign HTTP/1.1
18:55:37:E :OUT10:Failed response: EOF
18:55:37:I1:WU2241:Retry #2 in 4 secs
18:55:41:I1:WU2241:Downloading WU
18:55:44:I2:OUT11:> POST /api/assign HTTP/1.1
18:55:44:E :OUT11:Failed response: EOF
18:55:44:I1:WU2241:Retry #3 in 8 secs
18:55:52:I1:WU2241:Downloading WU
18:55:54:I2:OUT12:> POST /api/assign HTTP/1.1
18:55:54:E :OUT12:Failed response: EOF
18:55:54:I1:WU2241:Retry #4 in 16 secs
18:56:10:I1:WU2241:Downloading WU
18:56:12:I2:OUT13:> POST /api/assign HTTP/1.1
18:56:12:E :OUT13:Failed response: EOF
18:56:12:I1:WU2241:Retry #5 in 32 secs
18:56:44:I1:WU2241:Downloading WU
18:56:47:I2:OUT14:> POST /api/assign HTTP/1.1
18:56:47:E :OUT14:Failed response: EOF
18:56:47:I1:WU2241:Retry #6 in 1 min 4 secs
18:57:51:I1:WU2241:Downloading WU
18:57:53:I2:OUT15:> POST /api/assign HTTP/1.1
18:57:53:E :OUT15:Failed response: EOF
18:57:53:I1:WU2241:Retry #7 in 2 mins 8 secs
19:00:01:I1:WU2241:Downloading WU
19:00:03:I2:OUT16:> POST /api/assign HTTP/1.1
19:00:03:E :OUT16:Failed response: EOF
19:00:03:I1:WU2241:Retry #8 in 4 mins 16 secs
19:04:19:I1:WU2241:Downloading WU
19:04:22:I2:OUT17:> POST /api/assign HTTP/1.1
19:04:22:E :OUT17:Failed response: EOF
19:04:22:I1:WU2241:Retry #9 in 8 mins 32 secs
19:12:54:I1:WU2241:Downloading WU
19:12:56:I2:OUT18:> POST /api/assign HTTP/1.1
19:12:56:E :OUT18:Failed response: EOF
19:12:56:I1:WU2241:Too many retries (9), failing WU
19:12:59:I1:Default:Added new work unit: cpus:0 gpus:gpu:03:00:00
19:12:59:I1:WU2242:Requesting WU assignment for user kwerboom_GRC_e9731a42787581aefd692a0981ffa510 team 224497
19:12:59:I2:OUT19:> POST /api/assign HTTP/1.1
19:12:59:I2:OUT19:< HTTP/1.1 200 HTTP_OK
19:12:59:I1:WU2242:Received WU assignment KXKtM4EdDUrI3rElVjv2kw9Z5ATM3257doXiorKRBns
19:12:59:I1:WU2242:Downloading WU
19:12:59:I2:OUT20:> POST /api/assign HTTP/1.1
19:13:01:I1:WU2242:DOWNLOAD 100% 220B of 220B
19:13:03:I1:WU2242:DOWNLOAD 8% 3.33MiB of 40.59MiB
19:13:04:I1:WU2242:DOWNLOAD 13% 5.22MiB of 40.59MiB
19:13:05:I1:WU2242:DOWNLOAD 18% 7.15MiB of 40.59MiB
19:13:06:I1:WU2242:DOWNLOAD 22% 9.08MiB of 40.59MiB
19:13:07:I1:WU2242:DOWNLOAD 27% 11.01MiB of 40.59MiB
19:13:08:I1:WU2242:DOWNLOAD 31% 12.75MiB of 40.59MiB
19:13:09:I1:WU2242:DOWNLOAD 36% 14.69MiB of 40.59MiB
19:13:10:I1:WU2242:DOWNLOAD 41% 16.63MiB of 40.59MiB
19:13:11:I1:WU2242:DOWNLOAD 46% 18.52MiB of 40.59MiB
19:13:12:I1:WU2242:DOWNLOAD 50% 20.42MiB of 40.59MiB
19:13:13:I1:WU2242:DOWNLOAD 55% 22.35MiB of 40.59MiB
19:13:14:I1:WU2242:DOWNLOAD 60% 24.29MiB of 40.59MiB
19:13:15:I1:WU2242:DOWNLOAD 64% 26.10MiB of 40.59MiB
19:13:16:I1:WU2242:DOWNLOAD 69% 28.02MiB of 40.59MiB
19:13:17:I1:WU2242:DOWNLOAD 73% 29.80MiB of 40.59MiB
19:13:18:I1:WU2242:DOWNLOAD 78% 31.67MiB of 40.59MiB
19:13:19:I1:WU2242:DOWNLOAD 83% 33.59MiB of 40.59MiB
19:13:20:I1:WU2242:DOWNLOAD 88% 35.52MiB of 40.59MiB
19:13:21:I1:WU2242:DOWNLOAD 92% 37.33MiB of 40.59MiB
19:13:22:I1:WU2242:DOWNLOAD 97% 39.25MiB of 40.59MiB
19:13:23:I1:WU2242:DOWNLOAD 100% 40.59MiB of 40.59MiB
19:13:23:I2:OUT20:< HTTP/1.1 200 HTTP_OK
19:13:23:I1:WU2242:Received WU P18245 R832 C3 G9
19:13:23:I3:Running FahCore: C:\ProgramData\FAHClient\cores/openmm-core-27/windows-10-64bit/release/fahcore-27-windows-10-64bit-release-8.2.1/FahCore_27.exe -dir KXKtM4EdDUrI3rElVjv2kw9Z5ATM3257doXiorKRBns -suffix 01 -version 8.5.5 -lifeline 16064 -gpu-uuid 30303030-3030-3033-3030-303030303030 -gpu-platform opencl -gpu-vendor amd -opencl-platform 1 -opencl-device 1 -hip-platform 0 -hip-device 1 -gpu 1
19:13:23:I3:WU2242:Started FahCore on PID 18128
19:13:23:I1:WU2242:*********************** Log Started 2026-05-15T19:13:23Z ***********************
19:13:23:I1:WU2242:*************************** Core27 Folding@home Core ***************************
19:13:23:I1:WU2242:       Core: Core27
19:13:23:I1:WU2242:       Type: 0x27
19:13:23:I1:WU2242:    Version: 8.2.1
19:13:23:I1:WU2242:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
19:13:23:I1:WU2242:  Copyright: 2022 foldingathome.org
19:13:23:I1:WU2242:   Homepage: https://foldingathome.org/
19:13:23:I1:WU2242:       Date: Mar 27 2025
19:13:23:I1:WU2242:       Time: 04:46:58
19:13:23:I1:WU2242:   Revision: 84019442387121f2bed4ed52e05c53b7b7b52a72
19:13:23:I1:WU2242:     Branch: HEAD
19:13:23:I1:WU2242:   Compiler: Visual C++
19:13:23:I1:WU2242:    Options: $( /TP $) /std:c++14 /nologo /EHa /wd4297 /wd4103 /O2
19:13:23:I1:WU2242:             /Zc:throwingNew /MT -DOPENMM_VERSION="\"8.2.0\"" /Ox /std:c++14
19:13:23:I1:WU2242:   Platform: win32 10
19:13:23:I1:WU2242:       Bits: 64
19:13:23:I1:WU2242:       Mode: Release
19:13:23:I1:WU2242:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
19:13:23:I1:WU2242:             <peastman@stanford.edu>
19:13:23:I1:WU2242:       Args: -dir KXKtM4EdDUrI3rElVjv2kw9Z5ATM3257doXiorKRBns -suffix 01
19:13:23:I1:WU2242:             -version 8.5.5 -lifeline 16064 -gpu-uuid
19:13:23:I1:WU2242:             30303030-3030-3033-3030-303030303030 -gpu-platform opencl
19:13:23:I1:WU2242:             -gpu-vendor amd -opencl-platform 1 -opencl-device 1 -hip-platform 0
19:13:23:I1:WU2242:             -hip-device 1 -gpu 1
19:13:23:I1:WU2242:************************************ libFAH ************************************
19:13:23:I1:WU2242:       Time: 04:30:44
19:13:23:I1:WU2242:   Revision: c7d2824a47eb025fa8cda8968c7a5e971585d90c
19:13:23:I1:WU2242:    Options: $( /TP $) /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
19:13:23:I1:WU2242:************************************ CBang *************************************
19:13:23:I1:WU2242:    Version: 1.7.2
19:13:23:I1:WU2242:        Org: Cauldron Development LLC
19:13:23:I1:WU2242:  Copyright: Cauldron Development LLC, 2003-2024
19:13:23:I1:WU2242:   Homepage: https://cauldrondevelopment.com/
19:13:23:I1:WU2242:    License: LGPL-2.1-or-later
19:13:23:I1:WU2242:       Time: 04:29:12
19:13:23:I1:WU2242:   Revision: f1cd4c791e8c40a35dcfeab3ab85d910949cc0cb
19:13:23:I1:WU2242:************************************ System ************************************
19:13:23:I1:WU2242:        CPU: AMD Ryzen 5 7600X 6-Core Processor
19:13:23:I1:WU2242:     CPU ID: AuthenticAMD Family 25 Model 97 Stepping 2
19:13:23:I1:WU2242:       CPUs: 12
19:13:23:I1:WU2242:     Memory: 31.16GiB
19:13:23:I1:WU2242:Free Memory: 13.65GiB
19:13:23:I1:WU2242: OS Version: 10.0
19:13:23:I1:WU2242:Has Battery: false
19:13:23:I1:WU2242: On Battery: false
19:13:23:I1:WU2242:   Hostname: DESKTOP-6608UU8
19:13:23:I1:WU2242: UTC Offset: -5
19:13:23:I1:WU2242:        PID: 18128
19:13:23:I1:WU2242:        CWD: C:\ProgramData\FAHClient\work
19:13:23:I1:WU2242:       Exec: C:\ProgramData\FAHClient\cores\openmm-core-27\windows-10-64bit\release\fahcore-27-windows-10-64bit-release-8.2.1\FahCore_27.exe
19:13:23:I1:WU2242:************************************ OpenMM ************************************
19:13:23:I1:WU2242:    Version: 8.2.0
19:13:23:I1:WU2242:********************************************************************************
19:13:23:I1:WU2242:Project: 18245 (Run 832, Clone 3, Gen 9)
19:13:23:I1:WU2242:Reading tar file core.xml
19:13:23:I1:WU2242:Reading tar file integrator.xml
19:13:23:I1:WU2242:Reading tar file state.xml.bz2
19:13:23:I1:WU2242:Reading tar file system.xml.bz2
19:13:23:I1:WU2242:Digital signatures verified
19:13:23:I1:WU2242:Folding@home GPU Core27 Folding@home Core
19:13:23:I1:WU2242:Version 8.2.1
19:13:23:I1:WU2242:  GPU info: Platform: OpenCL: AMD Accelerated Parallel Processing
19:13:23:I1:WU2242:  GPU info: PlatformIndex: 0
19:13:23:I1:WU2242:  GPU info: Device: gfx1036
19:13:23:I1:WU2242:  GPU info: DeviceIndex: 0
19:13:23:I1:WU2242:  GPU info: Vendor: 0x1002
19:13:23:I1:WU2242:  GPU info: PCI: 15:00:00
19:13:23:I1:WU2242:  GPU info: Compute: 2.0
19:13:23:I1:WU2242:  GPU info: Driver: 3679.0
19:13:23:I1:WU2242:  GPU info: GPU: true
19:13:23:I1:WU2242:  GPU info: Device: gfx1201
19:13:23:I1:WU2242:  GPU info: DeviceIndex: 1
19:13:23:I1:WU2242:  GPU info: PCI: 03:00:00
19:13:23:I1:WU2242:  GPU info: PlatformIndex: 1
19:13:23:I1:WU2242:  GPU info: Driver: 3652.0
19:13:23:I1:WU2242:  Checkpoint write interval: 62500 steps (5%) [20 total]
19:13:23:I1:WU2242:  JSON viewer frame write interval: 12500 steps (1%) [100 total]
19:13:23:I1:WU2242:  XTC frame write interval: 5000 steps (0.4%) [250 total]
19:13:23:I1:WU2242:  TRR frame write interval: disabled
19:13:23:I1:WU2242:  Global context and integrator variables write interval: disabled
19:13:23:I1:WU2242:There are 3 platforms available.
19:13:23:I1:WU2242:Platform 0: Reference
19:13:23:I1:WU2242:Platform 1: CPU
19:13:23:I1:WU2242:Platform 2: OpenCL
19:13:23:I1:WU2242:  opencl-device 1 specified
19:13:48:I1:WU2242:Attempting to create OpenCL context:
19:13:48:I1:WU2242:  Configuring platform OpenCL
19:13:50:E :WU2242:Core exited with Windows unhandled exception code 0xc0000005.  See https://bit.ly/2CXgWkZ for more information.
19:13:50:E :WU2242:Core returned FAILED_1 (0)
19:13:50:E :WU2242:Run did not produce any results. Dumping WU
19:13:50:I1:Default:Added new work unit: cpus:0 gpus:gpu:03:00:00
19:13:50:I1:WU2242:Sending dump report
19:13:50:I1:WU2243:Requesting WU assignment for user kwerboom_GRC_e9731a42787581aefd692a0981ffa510 team 224497
19:13:50:I2:OUT21:> POST /api/results HTTP/1.1
19:13:50:I2:OUT22:> POST /api/assign HTTP/1.1
19:13:51:I2:OUT22:< HTTP/1.1 200 HTTP_OK
19:13:51:I1:WU2243:Received WU assignment Em4VoGYcvKq8SIBiNdfuKHR2X_OvAji4JHRK0GyKI5A
19:13:51:I1:WU2243:Downloading WU
19:13:51:I2:OUT23:> POST /api/assign HTTP/1.1
19:13:53:I2:OUT21:< HTTP/1.1 200 HTTP_OK
19:13:53:I1:WU2242:Dumped
19:13:55:I1:WU2243:DOWNLOAD 100% 220B of 220B
19:13:57:I1:WU2243:DOWNLOAD 8% 3.33MiB of 40.58MiB
19:13:58:I1:WU2243:DOWNLOAD 12% 5.03MiB of 40.58MiB
19:13:59:I1:WU2243:DOWNLOAD 17% 6.90MiB of 40.58MiB
19:14:00:I1:WU2243:DOWNLOAD 22% 8.82MiB of 40.58MiB
19:14:01:I1:WU2243:DOWNLOAD 26% 10.75MiB of 40.58MiB
19:14:02:I1:WU2243:DOWNLOAD 31% 12.60MiB of 40.58MiB
19:14:03:I1:WU2243:DOWNLOAD 36% 14.49MiB of 40.58MiB
19:14:04:I1:WU2243:DOWNLOAD 40% 16.43MiB of 40.58MiB
19:14:05:I1:WU2243:DOWNLOAD 45% 18.33MiB of 40.58MiB
19:14:06:I1:WU2243:DOWNLOAD 50% 20.26MiB of 40.58MiB
19:14:07:I1:WU2243:DOWNLOAD 55% 22.19MiB of 40.58MiB
19:14:08:I1:WU2243:DOWNLOAD 59% 24.04MiB of 40.58MiB
19:14:09:I1:WU2243:DOWNLOAD 64% 25.96MiB of 40.58MiB
19:14:10:I1:WU2243:DOWNLOAD 69% 27.89MiB of 40.58MiB
19:14:11:I1:WU2243:DOWNLOAD 74% 29.81MiB of 40.58MiB
19:14:12:I1:WU2243:DOWNLOAD 78% 31.73MiB of 40.58MiB
19:14:13:I1:WU2243:DOWNLOAD 83% 33.65MiB of 40.58MiB
19:14:14:I1:WU2243:DOWNLOAD 88% 35.49MiB of 40.58MiB
19:14:15:I1:WU2243:DOWNLOAD 92% 37.40MiB of 40.58MiB
19:14:16:I1:WU2243:DOWNLOAD 96% 39.11MiB of 40.58MiB
19:14:17:I1:WU2243:DOWNLOAD 100% 40.58MiB of 40.58MiB
19:14:17:I2:OUT23:< HTTP/1.1 200 HTTP_OK
19:14:17:I1:WU2243:Received WU P18245 R836 C3 G9
19:14:18:I3:Running FahCore: C:\ProgramData\FAHClient\cores/openmm-core-27/windows-10-64bit/release/fahcore-27-windows-10-64bit-release-8.2.1/FahCore_27.exe -dir Em4VoGYcvKq8SIBiNdfuKHR2X_OvAji4JHRK0GyKI5A -suffix 01 -version 8.5.5 -lifeline 16064 -gpu-uuid 30303030-3030-3033-3030-303030303030 -gpu-platform opencl -gpu-vendor amd -opencl-platform 1 -opencl-device 1 -hip-platform 0 -hip-device 1 -gpu 1
19:14:18:I3:WU2243:Started FahCore on PID 32716
19:14:18:I1:WU2243:*********************** Log Started 2026-05-15T19:14:18Z ***********************
19:14:18:I1:WU2243:*************************** Core27 Folding@home Core ***************************
19:14:18:I1:WU2243:       Core: Core27
19:14:18:I1:WU2243:       Type: 0x27
19:14:18:I1:WU2243:    Version: 8.2.1
19:14:18:I1:WU2243:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
19:14:18:I1:WU2243:  Copyright: 2022 foldingathome.org
19:14:18:I1:WU2243:   Homepage: https://foldingathome.org/
19:14:18:I1:WU2243:       Date: Mar 27 2025
19:14:18:I1:WU2243:       Time: 04:46:58
19:14:18:I1:WU2243:   Revision: 84019442387121f2bed4ed52e05c53b7b7b52a72
19:14:18:I1:WU2243:     Branch: HEAD
19:14:18:I1:WU2243:   Compiler: Visual C++
19:14:18:I1:WU2243:    Options: $( /TP $) /std:c++14 /nologo /EHa /wd4297 /wd4103 /O2
19:14:18:I1:WU2243:             /Zc:throwingNew /MT -DOPENMM_VERSION="\"8.2.0\"" /Ox /std:c++14
19:14:18:I1:WU2243:   Platform: win32 10
19:14:18:I1:WU2243:       Bits: 64
19:14:18:I1:WU2243:       Mode: Release
19:14:18:I1:WU2243:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
19:14:18:I1:WU2243:             <peastman@stanford.edu>
19:14:18:I1:WU2243:       Args: -dir Em4VoGYcvKq8SIBiNdfuKHR2X_OvAji4JHRK0GyKI5A -suffix 01
19:14:18:I1:WU2243:             -version 8.5.5 -lifeline 16064 -gpu-uuid
19:14:18:I1:WU2243:             30303030-3030-3033-3030-303030303030 -gpu-platform opencl
19:14:18:I1:WU2243:             -gpu-vendor amd -opencl-platform 1 -opencl-device 1 -hip-platform 0
19:14:18:I1:WU2243:             -hip-device 1 -gpu 1
19:14:18:I1:WU2243:************************************ libFAH ************************************
19:14:18:I1:WU2243:       Time: 04:30:44
19:14:18:I1:WU2243:   Revision: c7d2824a47eb025fa8cda8968c7a5e971585d90c
19:14:18:I1:WU2243:    Options: $( /TP $) /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
19:14:18:I1:WU2243:************************************ CBang *************************************
19:14:18:I1:WU2243:    Version: 1.7.2
19:14:18:I1:WU2243:        Org: Cauldron Development LLC
19:14:18:I1:WU2243:  Copyright: Cauldron Development LLC, 2003-2024
19:14:18:I1:WU2243:   Homepage: https://cauldrondevelopment.com/
19:14:18:I1:WU2243:    License: LGPL-2.1-or-later
19:14:18:I1:WU2243:       Time: 04:29:12
19:14:18:I1:WU2243:   Revision: f1cd4c791e8c40a35dcfeab3ab85d910949cc0cb
19:14:18:I1:WU2243:************************************ System ************************************
19:14:18:I1:WU2243:        CPU: AMD Ryzen 5 7600X 6-Core Processor
19:14:18:I1:WU2243:     CPU ID: AuthenticAMD Family 25 Model 97 Stepping 2
19:14:18:I1:WU2243:       CPUs: 12
19:14:18:I1:WU2243:     Memory: 31.16GiB
19:14:18:I1:WU2243:Free Memory: 13.66GiB
19:14:18:I1:WU2243: OS Version: 10.0
19:14:18:I1:WU2243:Has Battery: false
19:14:18:I1:WU2243: On Battery: false
19:14:18:I1:WU2243:   Hostname: DESKTOP-6608UU8
19:14:18:I1:WU2243: UTC Offset: -5
19:14:18:I1:WU2243:        PID: 32716
19:14:18:I1:WU2243:        CWD: C:\ProgramData\FAHClient\work
19:14:18:I1:WU2243:       Exec: C:\ProgramData\FAHClient\cores\openmm-core-27\windows-10-64bit\release\fahcore-27-windows-10-64bit-release-8.2.1\FahCore_27.exe
19:14:18:I1:WU2243:************************************ OpenMM ************************************
19:14:18:I1:WU2243:    Version: 8.2.0
19:14:18:I1:WU2243:********************************************************************************
19:14:18:I1:WU2243:Project: 18245 (Run 836, Clone 3, Gen 9)
19:14:18:I1:WU2243:Reading tar file core.xml
19:14:18:I1:WU2243:Reading tar file integrator.xml
19:14:18:I1:WU2243:Reading tar file state.xml.bz2
19:14:18:I1:WU2243:Reading tar file system.xml.bz2
19:14:18:I1:WU2243:Digital signatures verified
19:14:18:I1:WU2243:Folding@home GPU Core27 Folding@home Core
19:14:18:I1:WU2243:Version 8.2.1
19:14:18:I1:WU2243:  GPU info: Platform: OpenCL: AMD Accelerated Parallel Processing
19:14:18:I1:WU2243:  GPU info: PlatformIndex: 0
19:14:18:I1:WU2243:  GPU info: Device: gfx1036
19:14:18:I1:WU2243:  GPU info: DeviceIndex: 0
19:14:18:I1:WU2243:  GPU info: Vendor: 0x1002
19:14:18:I1:WU2243:  GPU info: PCI: 15:00:00
19:14:18:I1:WU2243:  GPU info: Compute: 2.0
19:14:18:I1:WU2243:  GPU info: Driver: 3679.0
19:14:18:I1:WU2243:  GPU info: GPU: true
19:14:18:I1:WU2243:  GPU info: Device: gfx1201
19:14:18:I1:WU2243:  GPU info: DeviceIndex: 1
19:14:18:I1:WU2243:  GPU info: PCI: 03:00:00
19:14:18:I1:WU2243:  GPU info: PlatformIndex: 1
19:14:18:I1:WU2243:  GPU info: Driver: 3652.0
19:14:18:I1:WU2243:  Checkpoint write interval: 62500 steps (5%) [20 total]
19:14:18:I1:WU2243:  JSON viewer frame write interval: 12500 steps (1%) [100 total]
19:14:18:I1:WU2243:  XTC frame write interval: 5000 steps (0.4%) [250 total]
19:14:18:I1:WU2243:  TRR frame write interval: disabled
19:14:18:I1:WU2243:  Global context and integrator variables write interval: disabled
19:14:18:I1:WU2243:There are 3 platforms available.
19:14:18:I1:WU2243:Platform 0: Reference
19:14:18:I1:WU2243:Platform 1: CPU
19:14:18:I1:WU2243:Platform 2: OpenCL
19:14:18:I1:WU2243:  opencl-device 1 specified
19:14:42:I1:WU2243:Attempting to create OpenCL context:
19:14:42:I1:WU2243:  Configuring platform OpenCL
19:14:45:E :WU2243:Core exited with Windows unhandled exception code 0xc0000005.  See https://bit.ly/2CXgWkZ for more information.
19:14:45:E :WU2243:Core returned FAILED_1 (0)
19:14:45:E :WU2243:Run did not produce any results. Dumping WU
19:14:45:I1:Default:Added new work unit: cpus:0 gpus:gpu:03:00:00
19:14:45:I1:WU2243:Sending dump report
19:14:45:I1:WU2244:Requesting WU assignment for user kwerboom_GRC_e9731a42787581aefd692a0981ffa510 team 224497
19:14:45:I2:OUT24:> POST /api/results HTTP/1.1
19:14:45:I2:OUT25:> POST /api/assign HTTP/1.1
19:14:45:I2:OUT24:< HTTP/1.1 200 HTTP_OK
19:14:45:I1:WU2243:Dumped
19:14:45:I2:OUT25:< HTTP/1.1 200 HTTP_OK
19:14:45:I1:WU2244:Received WU assignment NHhnLx2uHlAkRgUkWNxhAT8YwNaUS-dNz0GU-uaSv7I
19:14:45:I1:WU2244:Downloading WU
19:14:45:I2:OUT26:> POST /api/assign HTTP/1.1
19:14:49:I1:WU2244:DOWNLOAD 100% 220B of 220B
19:14:51:I1:WU2244:DOWNLOAD 20% 3.47MiB of 17.67MiB
19:14:52:I1:WU2244:DOWNLOAD 30% 5.32MiB of 17.67MiB
19:14:53:I1:WU2244:DOWNLOAD 41% 7.25MiB of 17.67MiB
19:14:54:I1:WU2244:DOWNLOAD 52% 9.18MiB of 17.67MiB
19:14:55:I1:WU2244:DOWNLOAD 63% 11.06MiB of 17.67MiB
19:14:56:I1:WU2244:DOWNLOAD 73% 12.97MiB of 17.67MiB
19:14:57:I1:WU2244:DOWNLOAD 84% 14.88MiB of 17.67MiB
19:14:58:I1:WU2244:DOWNLOAD 95% 16.75MiB of 17.67MiB
19:14:59:I1:WU2244:DOWNLOAD 100% 17.67MiB of 17.67MiB
19:14:59:I2:OUT26:< HTTP/1.1 200 HTTP_OK
19:14:59:I1:WU2244:Received WU P17951 R5 C185 G0
19:14:59:I3:Running FahCore: C:\ProgramData\FAHClient\cores/openmm-core-27/windows-10-64bit/release/fahcore-27-windows-10-64bit-release-8.2.1/FahCore_27.exe -dir NHhnLx2uHlAkRgUkWNxhAT8YwNaUS-dNz0GU-uaSv7I -suffix 01 -version 8.5.5 -lifeline 16064 -gpu-uuid 30303030-3030-3033-3030-303030303030 -gpu-platform opencl -gpu-vendor amd -opencl-platform 1 -opencl-device 1 -hip-platform 0 -hip-device 1 -gpu 1
19:14:59:I3:WU2244:Started FahCore on PID 30884
19:14:59:I1:WU2244:*********************** Log Started 2026-05-15T19:14:59Z ***********************
19:14:59:I1:WU2244:*************************** Core27 Folding@home Core ***************************
19:14:59:I1:WU2244:       Core: Core27
19:14:59:I1:WU2244:       Type: 0x27
19:14:59:I1:WU2244:    Version: 8.2.1
19:14:59:I1:WU2244:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
19:14:59:I1:WU2244:  Copyright: 2022 foldingathome.org
19:14:59:I1:WU2244:   Homepage: https://foldingathome.org/
19:14:59:I1:WU2244:       Date: Mar 27 2025
19:14:59:I1:WU2244:       Time: 04:46:58
19:14:59:I1:WU2244:   Revision: 84019442387121f2bed4ed52e05c53b7b7b52a72
19:14:59:I1:WU2244:     Branch: HEAD
19:14:59:I1:WU2244:   Compiler: Visual C++
19:14:59:I1:WU2244:    Options: $( /TP $) /std:c++14 /nologo /EHa /wd4297 /wd4103 /O2
19:14:59:I1:WU2244:             /Zc:throwingNew /MT -DOPENMM_VERSION="\"8.2.0\"" /Ox /std:c++14
19:14:59:I1:WU2244:   Platform: win32 10
19:14:59:I1:WU2244:       Bits: 64
19:14:59:I1:WU2244:       Mode: Release
19:14:59:I1:WU2244:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
19:14:59:I1:WU2244:             <peastman@stanford.edu>
19:14:59:I1:WU2244:       Args: -dir NHhnLx2uHlAkRgUkWNxhAT8YwNaUS-dNz0GU-uaSv7I -suffix 01
19:14:59:I1:WU2244:             -version 8.5.5 -lifeline 16064 -gpu-uuid
19:14:59:I1:WU2244:             30303030-3030-3033-3030-303030303030 -gpu-platform opencl
19:14:59:I1:WU2244:             -gpu-vendor amd -opencl-platform 1 -opencl-device 1 -hip-platform 0
19:14:59:I1:WU2244:             -hip-device 1 -gpu 1
19:14:59:I1:WU2244:************************************ libFAH ************************************
19:14:59:I1:WU2244:       Time: 04:30:44
19:14:59:I1:WU2244:   Revision: c7d2824a47eb025fa8cda8968c7a5e971585d90c
19:14:59:I1:WU2244:    Options: $( /TP $) /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
19:14:59:I1:WU2244:************************************ CBang *************************************
19:14:59:I1:WU2244:    Version: 1.7.2
19:14:59:I1:WU2244:        Org: Cauldron Development LLC
19:14:59:I1:WU2244:  Copyright: Cauldron Development LLC, 2003-2024
19:14:59:I1:WU2244:   Homepage: https://cauldrondevelopment.com/
19:14:59:I1:WU2244:    License: LGPL-2.1-or-later
19:14:59:I1:WU2244:       Time: 04:29:12
19:14:59:I1:WU2244:   Revision: f1cd4c791e8c40a35dcfeab3ab85d910949cc0cb
19:14:59:I1:WU2244:************************************ System ************************************
19:14:59:I1:WU2244:        CPU: AMD Ryzen 5 7600X 6-Core Processor
19:14:59:I1:WU2244:     CPU ID: AuthenticAMD Family 25 Model 97 Stepping 2
19:14:59:I1:WU2244:       CPUs: 12
19:14:59:I1:WU2244:     Memory: 31.16GiB
19:14:59:I1:WU2244:Free Memory: 13.67GiB
19:14:59:I1:WU2244: OS Version: 10.0
19:14:59:I1:WU2244:Has Battery: false
19:14:59:I1:WU2244: On Battery: false
19:14:59:I1:WU2244:   Hostname: DESKTOP-6608UU8
19:14:59:I1:WU2244: UTC Offset: -5
19:14:59:I1:WU2244:        PID: 30884
19:14:59:I1:WU2244:        CWD: C:\ProgramData\FAHClient\work
19:14:59:I1:WU2244:       Exec: C:\ProgramData\FAHClient\cores\openmm-core-27\windows-10-64bit\release\fahcore-27-windows-10-64bit-release-8.2.1\FahCore_27.exe
19:14:59:I1:WU2244:************************************ OpenMM ************************************
19:14:59:I1:WU2244:    Version: 8.2.0
19:14:59:I1:WU2244:********************************************************************************
19:14:59:I1:WU2244:Project: 17951 (Run 5, Clone 185, Gen 0)
19:14:59:I1:WU2244:Reading tar file core.xml
19:14:59:I1:WU2244:Reading tar file integrator.xml
19:14:59:I1:WU2244:Reading tar file state.xml
19:14:59:I1:WU2244:Reading tar file system.xml
19:15:00:I1:WU2244:Digital signatures verified
19:15:00:I1:WU2244:Folding@home GPU Core27 Folding@home Core
19:15:00:I1:WU2244:Version 8.2.1
19:15:00:I1:WU2244:  GPU info: Platform: OpenCL: AMD Accelerated Parallel Processing
19:15:00:I1:WU2244:  GPU info: PlatformIndex: 0
19:15:00:I1:WU2244:  GPU info: Device: gfx1036
19:15:00:I1:WU2244:  GPU info: DeviceIndex: 0
19:15:00:I1:WU2244:  GPU info: Vendor: 0x1002
19:15:00:I1:WU2244:  GPU info: PCI: 15:00:00
19:15:00:I1:WU2244:  GPU info: Compute: 2.0
19:15:00:I1:WU2244:  GPU info: Driver: 3679.0
19:15:00:I1:WU2244:  GPU info: GPU: true
19:15:00:I1:WU2244:  GPU info: Device: gfx1201
19:15:00:I1:WU2244:  GPU info: DeviceIndex: 1
19:15:00:I1:WU2244:  GPU info: PCI: 03:00:00
19:15:00:I1:WU2244:  GPU info: PlatformIndex: 1
19:15:00:I1:WU2244:  GPU info: Driver: 3652.0
19:15:00:I1:WU2244:  Checkpoint write interval: 125000 steps (5%) [20 total]
19:15:00:I1:WU2244:  JSON viewer frame write interval: 25000 steps (1%) [100 total]
19:15:00:I1:WU2244:  XTC frame write interval: 25000 steps (1%) [100 total]
19:15:00:I1:WU2244:  TRR frame write interval: disabled
19:15:00:I1:WU2244:  Global context and integrator variables write interval: disabled
19:15:00:I1:WU2244:There are 3 platforms available.
19:15:00:I1:WU2244:Platform 0: Reference
19:15:00:I1:WU2244:Platform 1: CPU
19:15:00:I1:WU2244:Platform 2: OpenCL
19:15:00:I1:WU2244:  opencl-device 1 specified
19:15:09:I1:WU2244:Attempting to create OpenCL context:
19:15:09:I1:WU2244:  Configuring platform OpenCL
19:15:12:E :WU2244:Core exited with Windows unhandled exception code 0xc0000005.  See https://bit.ly/2CXgWkZ for more information.
19:15:12:E :WU2244:Core returned FAILED_1 (0)
19:15:12:E :WU2244:Run did not produce any results. Dumping WU
19:15:12:I1:Default:Added new work unit: cpus:0 gpus:gpu:03:00:00
19:15:12:I1:WU2244:Sending dump report
19:15:12:I1:WU2245:Requesting WU assignment for user kwerboom_GRC_e9731a42787581aefd692a0981ffa510 team 224497
19:15:12:I2:OUT27:> POST /api/results HTTP/1.1
19:15:12:I2:OUT28:> POST /api/assign HTTP/1.1
19:15:12:I2:OUT27:< HTTP/1.1 200 HTTP_OK
19:15:12:I1:WU2244:Dumped
19:15:13:I2:OUT28:< HTTP/1.1 200 HTTP_OK
19:15:13:I1:WU2245:Received WU assignment _Z2s8UjiC59rUkhjHGrp8-6tvuEI6wMSi2LKo_HtnZg
19:23:09:I1:Clean exit
