Repeated Memory Access Errors
BB63
Post by BB63 »
Hello all,
I keep on getting dumped WUs on my desktop, IDK why i'm getting memory access errors. Any tips on how to troubleshoot?Snippet of Error log as follows:
08:04:54:I1:WU5: Homepage: https://cauldrondevelopment.com/
08:04:54:I1:WU5: License: LGPL-2.1-or-later
08:04:54:I1:WU5: Date: Mar 27 2025
08:04:54:I1:WU5: Time: 04:29:12
08:04:54:I1:WU5: Revision: f1cd4c791e8c40a35dcfeab3ab85d910949cc0cb
08:04:54:I1:WU5: Branch: HEAD
08:04:54:I1:WU5: Compiler: Visual C++
08:04:54:I1:WU5: Options: $( /TP $) /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
08:04:54:I1:WU5: Platform: win32 10
08:04:54:I1:WU5: Bits: 64
08:04:54:I1:WU5: Mode: Release
08:04:54:I1:WU5:************************************ System ************************************
08:04:54:I1:WU5: CPU: AMD Ryzen 7 9800X3D 8-Core Processor
08:04:54:I1:WU5: CPU ID: AuthenticAMD Family 26 Model 68 Stepping 0
08:04:54:I1:WU5: CPUs: 16
08:04:54:I1:WU5: Memory: 31.16GiB
08:04:54:I1:WU5:Free Memory: 15.67GiB
08:04:54:I1:WU5: OS Version: 10.0
08:04:54:I1:WU5:Has Battery: false
08:04:54:I1:WU5: On Battery: false
08:04:54:I1:WU5: Hostname: ThunderServer2
08:04:54:I1:WU5: UTC Offset: -7
08:04:54:I1:WU5: PID: 29364
08:04:54:I1:WU5: CWD: C:\ProgramData\FAHClient\work
08:04:54:I1:WU5: Exec: C:\ProgramData\FAHClient\cores\openmm-core-27\windows-10-64bit\release\fahcore-27-windows-10-64bit-release-8.2.1\FahCore_27.exe
08:04:54:I1:WU5:************************************ OpenMM ************************************
08:04:54:I1:WU5: Version: 8.2.0
08:04:54:I1:WU5:********************************************************************************
08:04:54:I1:WU5:Project: 18261 (Run 229, Clone 7, Gen 228)
08:04:54:I1:WU5:Reading tar file core.xml
08:04:54:I1:WU5:Reading tar file integrator.xml
08:04:54:I1:WU5:Reading tar file state.xml.bz2
08:04:54:I1:WU5:Reading tar file system.xml.bz2
08:04:54:I1:WU5:Digital signatures verified
08:04:54:I1:WU5:Folding@home GPU Core27 Folding@home Core
08:04:54:I1:WU5:Version 8.2.1
08:04:54:I1:WU5: GPU info: Platform: OpenCL: AMD Accelerated Parallel Processing
08:04:54:I1:WU5: GPU info: PlatformIndex: 0
08:04:54:I1:WU5: GPU info: Device: gfx1036
08:04:54:I1:WU5: GPU info: DeviceIndex: 0
08:04:54:I1:WU5: GPU info: Vendor: 0x1002
08:04:54:I1:WU5: GPU info: PCI: 19:00:00
08:04:54:I1:WU5: GPU info: Compute: 2.0
08:04:54:I1:WU5: GPU info: Driver: 3679.0
08:04:54:I1:WU5: GPU info: GPU: true
08:04:54:I1:WU5: GPU info: Device: gfx1201
08:04:54:I1:WU5: GPU info: DeviceIndex: 1
08:04:54:I1:WU5: GPU info: PCI: 03:00:00
08:04:54:I1:WU5: GPU info: PlatformIndex: 1
08:04:54:I1:WU5: GPU info: Driver: 3652.0
08:04:54:I1:WU5: Checkpoint write interval: 12500 steps (5%) [20 total]
08:04:54:I1:WU5: JSON viewer frame write interval: 2500 steps (1%) [100 total]
08:04:54:I1:WU5: XTC frame write interval: 5000 steps (2%) [50 total]
08:04:54:I1:WU5: TRR frame write interval: disabled
08:04:54:I1:WU5: Global context and integrator variables write interval: disabled
08:04:54:I1:WU5:There are 3 platforms available.
08:04:54:I1:WU5:Platform 0: Reference
08:04:54:I1:WU5:Platform 1: CPU
08:04:54:I1:WU5:Platform 2: OpenCL
08:04:54:I1:WU5: opencl-device 1 specified
08:06:04:I1:WU5:Attempting to create OpenCL context:
08:06:04:I1:WU5: Configuring platform OpenCL
08:06:05:E :WU5:Core exited with Windows unhandled exception code 0xc0000005. See https://bit.ly/2CXgWkZ for more information.
08:06:05:E :WU5:Core returned FAILED_1 (0)
08:06:05:E :WU5:Run did not produce any results. Dumping WU
08:06:05:I1:Default:Added new work unit: cpus:0 gpus:gpu:03:00:00
08:06:05:I1:WU5:Sending dump report
08:06:05:I1:WU6:Requesting WU assignment for user BB1363 team 0
08:06:05:I2:OUT23:> POST /api/results HTTP/1.1
08:06:05:I2:OUT24:> POST /api/assign HTTP/1.1
08:06:05:I2:OUT23:< HTTP/1.1 200 HTTP_OK
08:06:05:I1:WU5:Dumped
08:06:06:I2:OUT24:< HTTP/1.1 200 HTTP_OK
08:06:06:I1:WU6:Received WU assignment qkCyvMYo2N50SxGVkyYxhbG4nup_yfxvDZe3QYQDB90
02:04:18:I3:WU6:Dumping qkCyvMYo2N50SxGVkyYxhbG4nup_yfxvDZe3QYQDB90
Useful config data (not in the log) is as follows:
1. TUF GAMING X670E-PLUS WIFI Rev 1.xx
2. Microsoft Windows 11 Pro 10.0.26200
3. Bios Version 3854
4. RAM is 32 GB of Corsair Vengeance DDR5
Edit: FAH isn't allowing me to copy-paste my entire log. Had to copy-paste in snippets
