[Fold Control] Android app to control your v8 client
Frodo The Hobbit
Post by Frodo The Hobbit »
Fold Control — remote control app for F@H, open beta tonight on Play Store
Tonight I'm putting my Android app into open beta. Sharing here in case anyone wants to try it.
What it is
A native Android app for remotely monitoring and controlling the F@H clients.
What it does
Every linked machine on one screen — PPD, active WU, progress, status
Remote fold / pause / finish, global, per-machine, or per-group
Scheduler with per-machine opt-in (fold your rig 24/7, let your laptop sleep)
Home-screen widgets — small PPD badge + medium widget with per-machine rows and fold/pause buttons
Notifications when a machine drops offline, a WU fails, or a milestone is hit
Tappable drop notifications open the affected machine's detail screen directly
Daily credit summary at 8pm
Data Saver mode with a 1–15 min configurable refresh interval for mobile data
Dark / AMOLED theme, CSV export of WU history
Open beta link
https://play.google.com/store/apps/deta ... foldingapp
Feedback
DM me here or reply in the thread — I'll fix bugs quickly during beta.
Thanks!
Farmer 4 Monster Folding since 2008...
Re: [Fold Control] Android app to control your v8 client
I'm in ! :)
Post by muziqaz »
I have not found the way to start the resource group folding. If I have the group already folding from my PC, app sees it and allows me to control it, but if I do not have a resource group running, it does not show up at all in the app
FAH Omega tester
Frodo The Hobbit
muziqaz wrote: Tue Apr 21, 2026 7:29 pm I have not found the way to start the resource group folding. If I have the group already folding from my PC, app sees it and allows me to control it, but if I do not have a resource group running, it does not show up at all in the app
You do not see any machine name in orange or in white for exemple ?
Post by calxalot »
Does this work well on android tablets?
