Ultimate Guide to prepare your AMD system for Core28 (HIP)
Post by muziqaz »
This guide is for core28 only. Future cores might have waay less restrictions and requirements.
HIP is officially supported on v8.5.5 and up. It might work on v7, solution might be posted in the comments in this thread
Core28 requires ROCm 6.4.4. Nothing less, nothing more
RHEL10/EL10 based distros are not supported by Core28
AMD Vega and up are supported by Core28
This guide assumes you already have your Linux box set up for OpenCL folding according to this guide:
viewtopic.php?t=43222
Using the above guide, please change ROCm 6.4.3 mentioned in that guide to 6.4.4
Consider removing opencl-mesa, as that package hides ROCm stuff in certain systems.
Windows seems to be working on my system. Still trying to confirm if I am just lucky, or everyone will be able to run HIP FAHcore on Windows.
--UBUNTU/KUBUNTU based systems:
First remove ROCm if you have the latest version installed.
sudo apt remove rocm*
Remove /opt/rocm if it still exists.
If you are using 6.4.3 ROCm, change it to 6.4.4 with the help of the guide linked at the top of this post.
sudo apt policy <---note the highest priority repo, and what that priority is (on ubuntu/kubuntu all of them are 500), in Mint official repositories are 700. In both ROCm is listed last and comes with priority 500 (some distros might have 600).
Check /etc/apt/preferences.d/ for anything rocm (like rocm-pin-500)
If it doesn't exist you can create it by:
sudo nano /etc/apt/preferences.d/rocm-pin-600
File should contain this:
Package: *
Pin: release o=repo.radeon.com
Pin-Priority: 600
CTRL+X,
Type Y
Press Enter
If the rocm-pin-500 exists, rename it to rocm-pin-600, and then nano it as above, and change Pin-Priority to 600.
--Linux Mint
Everything as above, but Pin-Priority should be 800 for ROCm repo, to beat official repositories pin value.
All this above let’s apt pick the repo with the highest priority when installing ROCm packages, which prevents any clashes between rocm packages in official repo (outdated/newer ones) and packages in rocm.radeon repository.
Linux Mint 21.3 might require ocl-icd-opencl-dev to expose HIP to FAHClient. This is in case that package gets nuked when we are clearing up the system from ROCm
--Pop_OS
Similar as above in regards to repo priority pin value.
Then
sudo nano /etc/apt/sources.list.d/rocm.list
Change to 6.4.4
--Debian
Same as Pop_OS, I know I know, I should have put Debian first :P
Final Steps for Deb related systems:
sudo apt update && sudo apt upgrade
sudo apt install rocm-opencl-runtime
sudo apt install rocm-hip-runtime
sudo systemctl restart fah-client
--ARCH based systems
Option 1: viewtopic.php?p=373702#p373702 (Thanks borketh)
If that fails for some reason:
Option 2:
sudo pacman -R rocm-opencl-sdk rocm-opencl-runtime hip-runtime-amd
sudo pacman -R comgr rocminfo
sudo pacman -R hsa-rocr
sudo pacman -R rocm-device-libs rocm-llvm rocmprofiler-register
sudo pacman -R rocm-core
Uninstall them in order I posted above, that way you will not going to be bothered by dependencies
or
sudo pacman -Rsc rocm-opencl-runtime
sudo pacman -Rsc rocm-hip-runtime
Then
sudo nano /etc/pacman.conf
Find
[options]
IgnorePkg =
Add following:
rocm-opencl-sdk rocm-opencl-runtime hip-runtime-amd comgr rocminfo hsa-rocr rocm-device-libs rocm-llvm rocprofiler-register rocm-core rocm-hip-runtime rocm-cmake rocm-language-runtime
So it looks like this:
[options]
IgnorePkg = rocm-opencl-sdk rocm-opencl-runtime hip-runtime-amd comgr rocminfo hsa-rocr rocm-device-libs rocm-llvm rocprofiler-register rocm-core rocm-hip-runtime rocm-cmake rocm-language-runtime
CTRL+o and CTRL+X
Then
sudo pacman -Syu
and for test purposes:
sudo pacman -S rocm-hip-runtime
you will see the following:
:: rocm-hip-runtime is in IgnorePkg/IgnoreGroup. Install anyway? [Y/n] n
warning: skipping target: rocm-hip-runtime
there is nothing to do
This means that exclusion is working. Make sure to enter N, when asked to install anyway.
Now to install ROCm 6.4.4:
sudo pacman -U https://archive.archlinux.org/repos/2025/10/31/extra/os/x86_64/rocm-core-6.4.4-1-x86_64.pkg.tar.zst
sudo pacman -U https://archive.archlinux.org/repos/2025/10/31/extra/os/x86_64/rocm-llvm-2:6.4.4-2-x86_64.pkg.tar.zst
sudo pacman -U https://archive.archlinux.org/repos/2025/10/31/extra/os/x86_64/rocm-device-libs-2:6.4.4-2-x86_64.pkg.tar.zst
sudo pacman -U https://archive.archlinux.org/repos/2025/10/31/extra/os/x86_64/comgr-2:6.4.4-2-x86_64.pkg.tar.zst
sudo pacman -U https://archive.archlinux.org/repos/2025/10/31/extra/os/x86_64/rocprofiler-register-6.4.4-2-x86_64.pkg.tar.zst
sudo pacman -U https://archive.archlinux.org/repos/2025/10/31/extra/os/x86_64/hsa-rocr-6.4.4-1-x86_64.pkg.tar.zst
sudo pacman -U https://archive.archlinux.org/repos/2025/10/31/extra/os/x86_64/rocm-opencl-runtime-6.4.4-1-x86_64.pkg.tar.zst
sudo pacman -U https://archive.archlinux.org/repos/2025/10/31/extra/os/x86_64/rocminfo-6.4.4-1-x86_64.pkg.tar.zst
sudo pacman -U https://archive.archlinux.org/repos/2025/10/31/extra/os/x86_64/hip-runtime-amd-6.4.4-1-x86_64.pkg.tar.zst
sudo pacman -U https://archive.archlinux.org/repos/2025/10/31/extra/os/x86_64/rocm-cmake-6.4.4-1-any.pkg.tar.zst
sudo pacman -U https://archive.archlinux.org/repos/2025/10/31/extra/os/x86_64/rocm-language-runtime-6.4.4-1-any.pkg.tar.zst
sudo pacman -U https://archive.archlinux.org/repos/2025/10/31/extra/os/x86_64/rocm-hip-runtime-6.4.4-1-any.pkg.tar.zst
sudo pacman -S ocl-icd
This will download and install older packages from archive. Install them in the order I posted them here, as this way you will not going to be bothered by dependencies.
I know, this is amazingly involving, but I am Arch newb, btw, so I went with the installation process I could understand.
The above probably can be simplified by downloading these packages and installing them locally, or there are other ways of doing this. I don't know. The above worked for me on CachyOS.
--AlmaLinux 8
If system has ROCm v7 and above:
sudo dnf remove rocm-opencl-runtime (or anything related to rocm)
Then
sudo nano /etc/yum.repos.d/almalinux.repo
Add exclude=rocm* (this might not be needed, but just in case Alma decides to bundle ROCm in their own repos in latest distro versions)
Tweak or create rocm.repo for ROCm 6.4.4 (as per following guide: viewtopic.php?t=43222 under Fedora).
Then
sudo dnf update
sudo dnf install rocm-opencl-runtime
sudo dnf install rocm-hip-runtime
--Fedora
Same as AlmaLinux above (replace almalinux.repo with fedora.repo), except you definitely need to remove all the rocm packages and you definitely need to add exclude=rocm* to your fedora.repo file.
And I know, I should have put Fedora first :P :D
--oSuse
For me ROCm 6.4.3 seems to be working on oSuse, but in case you have issues replace
https://repo.radeon.com/rocm/zyp/6.4.3/main/ in your Yast Software Repositories app with https://repo.radeon.com/rocm/zyp/6.4.4/main/
Then
sudo zypper update
sudo zypper install rocm-hip-runtime
After all the above when you click on System Info within Web UI, you should see something like this (pay attention to OpenCL and HIP sections under GPU):
The systems I have HIP working:
Fedora 42 and 43
Debian 12 and 13
Ubuntu/Kubuntu 24.04 and 25.04
CachyOS
AlmaLinux 8
oSuse
Linux Mint 21.3 and 22.3+
Windows 11 with latest driver
FAH Omega tester
borketh
Hardware configuration: 9800X3D + 7800XT
Re: Ultimate Guide to prepare your AMD system for Core28 (HIP)
Post by borketh »
For Arch Linux and derivatives, you can use the downgrade utility instead of manually doing all of that.
sudo downgrade rocm-core rocm-llvm rocm-device-libs comgr rocprofiler-register hsa-rocr rocm-opencl-runtime rocminfo hip-runtime-amd rocm-cmake rocm-language-runtime rocm-hip-runtime
For each package, it will pop up a TUI where you can select 6.4.4 (if there are multiple builds, go with the most recent), and it will prompt you to add them to IgnorePkg.
jackal
Post by jackal »
Anything special required set-up wise for Windows? I see you (@muziqaz) mentioned you have it running on Win11, but you didn't mention any instructions, so can I assume that as long as my AMD drivers are up to date, it'll work once a WU with core_28 gets downloaded?
Post by muziqaz »
jackal wrote: Tue Mar 31, 2026 5:40 pm Anything special required set-up wise for Windows? I see you (@muziqaz) mentioned you have it running on Win11, but you didn't mention any instructions, so can I assume that as long as my AMD drivers are up to date, it'll work once a WU with core_28 gets downloaded?
search for amdhip64_6.dll. If you have it, you are good to go. If you don't, let me know, which driver version, and how old is your Windows install.
FAH Omega tester
borketh
Post by borketh »
Can you comment on how likely we are to get any Core28 jobs? I have betas turned on, but 5 WUs later it's all Core27 (18265, 15092).
Using HIP driver 60443.48 with compute level 11.0 on gfx1101 (7800XT)
Post by muziqaz »
borketh wrote: Tue Mar 31, 2026 7:55 pm Can you comment on how likely we are to get any Core28 jobs? I have betas turned on, but 5 WUs later it's all Core27 (18265, 15092).
Unless you are beta tester, you should disable Beta option. And HIP is still couple of weeks away
FAH Omega tester
jackal
Post by jackal »
muziqaz wrote: Tue Mar 31, 2026 5:55 pm
Thanks. I'm back in town after being gone a month. I do have it at C:\Windows\System32\amdhip64_6.dll.
I saw in your other thread that the system needs >40GB of free RAM. I do have 48GB of free memory. So I guess I should be good to go. However, I just re-started FAH (after being gone with my computer shut down) and I pulled a Core27 WU. I assume I'm all set for a Core28 WU to come my way eventually and I just need to wait for one to be distributed to me?
I do have v8.5.5 and am running Win11 Pro (Version 10.0.26200 Build 26200). My GPU is a Radeon RX 7800 XT on AMD Software: Adrenalin Edition 25.30.33.01-260309a-198975C / AMD Windows Driver 32.0.23033.1002.
Post by muziqaz »
core28 is not live yet.
FAH Omega tester
nada391
Post by nada391 »
hello , what should i do if the card am using is only supported starting with "rocm 7.12" (gfx1102) (rocm7.12 technical preview) ?
https://rocm.docs.amd.com/en/7.12.0-pre ... 4&i=pkgman
nada391 wrote: Sat May 09, 2026 4:38 pm hello , what should i do if the card am using is only supported starting with "rocm 7.12" (gfx1102) (rocm7.12 technical preview) ?
You may just have to wait. The developers for Core_28 so far have only been able to code it to be compatible with ROCm 6.4.4 and additional work will be needed to support a newer version. They would also have to evaluate if that would disable older series of GPUs.
Post by muziqaz »
Ignore what documentation is writing and use your card with 6.4.3
That GPU works fine with older versions.
There is a hope in near future that Rocm version lock will be lifted
FAH Omega tester
