Project dumped itself at 97.8%
Hello!
Why did the project dumped itself minutes before finish? I never faced such issue (did few others)
https://imgur.com/a/WLfXiGy#XWdrdB4
Re: Project dumped itself at 97.8%
Content is not available in UK. Great.Shrump wrote: ↑Fri Feb 27, 2026 6:21 am Hello!
Please post the snippet of the log where it shows the dumping process.
It's already moved to the history tab, as the machine started new project. Can I still see the log somehow?muziqaz wrote: ↑Fri Feb 27, 2026 6:47 amContent is not available in UK. Great.Shrump wrote: ↑Fri Feb 27, 2026 6:21 am Hello!
Project 18245
Of course, inside of fah-client directory you have logs folderShrump wrote: ↑Fri Feb 27, 2026 7:16 amIt's already moved to the history tab, as the machine started new project. Can I still see the log somehow?muziqaz wrote: ↑Fri Feb 27, 2026 6:47 amContent is not available in UK. Great.Shrump wrote: ↑Fri Feb 27, 2026 6:21 am Hello!
Project 18245
Here:
05:02:32:I1:WU7:Completed 1137500 out of 1250000 steps (91%)
05:06:33:I1:WU7:Completed 1150000 out of 1250000 steps (92%)
05:10:35:I1:WU7:Completed 1162500 out of 1250000 steps (93%)
05:14:36:I1:WU7:Completed 1175000 out of 1250000 steps (94%)
05:18:38:I1:WU7:Completed 1187500 out of 1250000 steps (95%)
05:18:40:I1:WU7:Checkpoint completed at step 1187500
05:20:31:I1:Machine state fold
05:21:16:I1:Account websocket closed: PROTOCOL msg=Failed to read header start
05:21:16:I2:OUT9:> GET /machine/spaIhoOCH6I_PVEkeiWaGN8zjrR8rbbwBWPLKE17vkA HTTP/1.1
05:21:17:I2:OUT9:< HTTP/1.1 200 HTTP_OK
05:21:17:I2:OUT2:> GET /ws/client HTTP/1.1
05:21:17:I2:OUT2:< HTTP/1.1 101 HTTP_SWITCHING_PROTOCOLS
05:21:17:I1:Logging into node account
05:22:42:I1:WU7:Completed 1200000 out of 1250000 steps (96%)
05:26:47:I1:WU7:Completed 1212500 out of 1250000 steps (97%)
05:30:05:E :WU7:Core exited with Windows unhandled exception code 0xc0000005. See https://bit.ly/2CXgWkZ for more information.
05:30:05:E :WU7:Core returned FAILED_1 (0)
05:30:05:E :WU7:Run did not produce any results. Dumping WU
05:30:05:I1:Default:Added new work unit: cpus:0 gpus:gpu:08:00:00
05:30:05:I1:WU7:Sending dump report
05:30:05:I1:WU9:Requesting WU assignment for user Shrump team 0
05:30:05:I2:OUT11:> POST /api/assign HTTP/1.1
05:30:05:I2:OUT10:> POST /api/results HTTP/1.1
05:30:05:I2:OUT10:< HTTP/1.1 200 HTTP_OK
05:30:05:I1:WU7:Dumped
05:30:06:I2:OUT11:< HTTP/1.1 200 HTTP_OK
05:30:06:I1:WU9:Received WU assignment LUPxHFnbDPDDuT9nvJtgN_dYnBtAzHT895qWRZ1WQJ0
05:30:06:I1:WU9:Downloading WU
05:30:06:I2:OUT12:> POST /api/assign HTTP/1.1
05:30:09:I1:WU9:DOWNLOAD 100% 220B of 220B
05:30:11:I1:WU9:DOWNLOAD 100% 17.61MiB of 17.61MiB
05:30:11:I2:OUT12:< HTTP/1.1 200 HTTP_OK
05:30:11:I1:WU9:Received WU P16775 R44 C2 G229
So it is likely RAM issue
Could it be restore/done one more time?
Yeah, nah, your crash was quite severe if it takes down the WU. This WU will be redone by someone else later.
I would suggest to test you system stability
You may find more information about the error in the Windows error logs. You will need to adjust from the UTC time shown in the folding log to local time in the Windows log.
