p18245 and intel arc b580 are not good friends
Lem
Post by Lem »
The issue is with p18245 running on intel arc b580.
In about 20 workunits, not a single one ended successfully.
Linux kernel: 6.17.0-14-generic
Driver: xe
Mesa: 26.1.0~git2602112334.b651fd90d2d~q~mesaaco15
OpenCL: 26.01.36711.4
No problem with the nvidia card, by the way. And the Intel works well with other projects.
Bye, Lem
bikeaddict
Re: p18245 and intel arc b580 are not good friends
Post by bikeaddict »
Mine's completed seven WUs for 18245 over the last 18 days.
Run/Clone/Generation
8017,2,11
11507,2,10
349,2,8
3931,1,19
7599,1,18
5796,1,15
1560,1,14
Currently running 10643,2,11
6.19.0 Fedora kernel, xe driver, mesa 25.3.5, OpenCL 25.3.5
Post by muziqaz »
Latest intel firmware nukes opencl compute.
Mine is running fine on fedora 43 driver 25.48
FAH Omega tester
bikeaddict
My B580 has the latest firmware available from fwupdmgr and performance is not impaired. The two WUs run today had about 3.1M PPD.
Lem
Post by Lem »
Wow! I haven't changed anything, but here it is my first successful p18245 workunit on Intel, after 20 failed: 827,2,12. Only 2.7M PPDs though.
However one swallow does not make a summer. We'll see.
BTW: my b580 loves projects 16773/4/5, instead. With them It goes up to 3.7M PPDs, even if the base credit is only 53.000. On the contrary, as an example, with p12137 and its base credit of 43.248, it stays low at about 2.5M PPDs.
Bye, Lem
Lem
Post by Lem »
bikeaddict wrote: Sun Feb 15, 2026 9:39 pm My B580 has the latest firmware available from fwupdmgr
Mine has:
$ fwupdmgr get-devices
ASUS System Product Name
├─Arc B580:
│ │   Device ID:          e32966e41f54b47823eef28bd8b4bd9e1018b923
│ │   Summary:            Discrete Graphics Card
│ │   Current version:    21.1174
│ ├─Arc B580 (Data):
│ │     Device ID:        ede93f29d76c5957eecaeb986b4472c151cbf3bc
│ │     Current version:  203.1
│ ├─Arc B580 (OptionROM Code):
│ │     Device ID:        767385145958df94c0f10f8d02442c2c750622d3
│ │     Current version:  23.1064.0.0
│ └─Arc B580 (OptionROM Data):
│       Device ID:        f9e2305d03d4c8b8b8a6f4b9ade6b881fccb9739
│       Current version:  23.1051.0.0
On fwupd.org https://fwupd.org/lvfs/search?value=b580 there is also a marginally newer firmware, but it's the intel standard so fwupdmgr ignores it (and I won't install it manually).
Bye, Lem
CaptainHalon
Post by CaptainHalon »
Agree, getting lots of errors on 182XX projects w/ B580. Latest Intel drivers.
BenT14
Post by BenT14 »
I have two B580’s that have been having the same issue on windows since a driver update in February. It’s not just wu 18245 but that’s definitely the one most affected for me. Does anyone know if other opencl applications are affected by whatever this issue is? Kind of wonder if Intel even knows of the issue at this point
Post by muziqaz »
I found out that my B580 on Linux does not like to fold stably while also driving the desktop. So, to make it more stable, I enabled AMD CPU iGPU, and plugged the monitor to that iGPU.
However, even with that some projects are NaN erroring all over the place with kernel 7.0.4 and latest firmware on Fedora43.
So it is possible that B580 might see reduced amount of projects available to it in near future
FAH Omega tester
BenT14
Post by BenT14 »
I found with the older driver from January the issue doesn't happen and opened this on their github if anyone is interested.
https://github.com/IGCIT/Intel-GPU-Comm ... ssues/1458
