amdgpu pro card no longer folding
nada391
Post by nada391 »
Hello ,
have since short a pro card W6400 which according to
AMD website has limited support for Ubuntu et.al
it functioned for few weeks but now it does no longer function with FAH (the newer kernel upgrade 6.17.29 fails to build the amdgpu portion > DKMS issue)
if installing just the portion that has been shared in the apposite section here on forum
viewtopic.php?t=43222
sudo apt install rocm-opencl-runtime (select 6.4.3) or (select 7.0.1?)
then the card would be supported, however the gpu section would always crash or stall at 0%.
and re-begin to stall anew.
is there a new routine available or should i just hope that the DKMS issue get solved for the AMDGPU PRO driver?
the concerned OS is Ubuntu 24.04. LTS (latest updates applied).
https://www.amd.com/en/support/download ... w6400.html
thank you very much for help and insight.
Re: amdgpu pro card no longer folding
Post by muziqaz »
Please post the examples of the crash and on which projects. Also screenshot of the fahclient system info section would help.
I still have RDNA2 GPU folding fine on bleeding edge kernel with latest rocm, so something else is happening down your end.
DKMS should not engage at all, unless you tried downloading and installing the amdgpu-install driver from AMD website. This is not needed, and most of the time brings pain to the user with new kernels
FAH Omega tester
nada391
Post by nada391 »
getting such error as
17:13:32:I1:WU2:Reading tar file integrator.xml
17:13:32:I1:WU2:Reading tar file state.xml
17:13:33:I1:WU2:Reading tar file system.xml
17:13:33:I1:WU2:Digital signatures verified
17:13:33:I1:WU2:Folding@home GPU Core27 Folding@home Core
17:13:33:I1:WU2:Version 8.2.1
17:13:33:I1:WU2: Checkpoint write interval: 100000 steps (4%) [25 total]
17:13:33:I1:WU2: JSON viewer frame write interval: 25000 steps (1%) [100 total]
17:13:33:I1:WU2: XTC frame write interval: 25000 steps (1%) [100 total]
17:13:33:I1:WU2: TRR frame write interval: disabled
17:13:33:I1:WU2: Global context and integrator variables write interval: disabled
17:13:33:I1:WU2:There are 3 platforms available.
17:13:33:I1:WU2:Platform 0: Reference
17:13:33:I1:WU2:Platform 1: CPU
17:13:33:I1:WU2:Platform 2: OpenCL
17:13:33:I1:WU2: opencl-device 0 specified
17:13:36:I1:WU2:Attempting to create OpenCL context:
17:13:36:I1:WU2: Configuring platform OpenCL
17:13:43:I1:WU2:ERROR:Discrepancy: Forces are blowing up! 4881 0
17:13:43:I1:WU2:Saving result file ../logfile_01.txt
17:13:43:I1:WU2:Saving result file science.log
17:13:43:I1:WU2:Saving result file state.xml
17:13:44:I1:WU2:Folding@home Core Shutdown: BAD_WORK_UNIT
17:13:45:E :WU2:Core returned BAD_WORK_UNIT (114)
17:13:46:I1:WU2:Uploading WU results
17:13:47:I1:WU2:UPLOAD 13% 2.06MiB of 15.65MiB
17:13:48:I1:WU2:UPLOAD 23% 3.66MiB of 15.65MiB
17:13:50:I1:WU2:UPLOAD 34% 5.32MiB of 15.65MiB
17:13:51:I1:WU2:UPLOAD 41% 6.38MiB of 15.65MiB
17:13:53:I1:WU2:UPLOAD 48% 7.56MiB of 15.65MiB
17:13:54:I1:WU2:UPLOAD 52% 8.10MiB of 15.65MiB
after fresh install of ubuntu 24.04 lts with amdgpu-install 7.1.0
and clinfo report success
  Platform Name                                   AMD Accelerated Parallel Processing
  Platform Vendor                                 Advanced Micro Devices, Inc.
  Platform Version                                OpenCL 2.1 AMD-APP (3581.0)
  Platform Extensions                             cl_khr_icd cl_amd_event_callback
  Platform Extensions function suffix             AMD
  Platform Host timer resolution                  1ns
  Device Name                                     gfx1034
  Device Vendor                                   Advanced Micro Devices, Inc.
  Device Version                                  OpenCL 2.0
  Driver Version                                  3581.0 (HSA1.1,LC)
  Device OpenCL C Version                         OpenCL C 2.0
  Device Board Name (AMD)                         AMD Radeon PRO W6400
  Device PCI-e ID (AMD)                           0x7422
  Device Topology (AMD)                           PCI-E, 0000:2b:00.0
  Max compute units                               6
  SIMD per compute unit (AMD)                     4
  SIMD width (AMD)                                32
  SIMD instruction width (AMD)                    1
  Max clock frequency                             2320MHz
  Graphics IP (AMD)                               10.3
    Max number of sub-devices                     6
    Supported affinity domains                    (n/a)
  Max work item sizes                             1024x1024x1024
  Preferred work group size (AMD)                 256
  Max work group size (AMD)                       1024
  Preferred work group size multiple (kernel)     32
  Wavefront width (AMD)                           32
    char                                                 4 / 4
    short                                                2 / 2
    half                                                 1 / 1        (cl_khr_fp16)
  Half-precision Floating-point support           (cl_khr_fp16)
  Global memory size                              4278190080 (3.984GiB)
  Global free memory (AMD)                        4001792 (3.816GiB) 4001792 (3.816GiB)
  Global memory channels (AMD)                    2
  Global memory banks per channel (AMD)           4
  Global memory bank width (AMD)                  256 bytes
  Max memory allocation                           3636461568 (3.387GiB)
  Shared Virtual Memory (SVM) capabilities        (core)
    Coarse-grained buffer sharing                 Yes
    Fine-grained buffer sharing                   Yes
    Fine-grained system sharing                   No
    Atomics                                       No
  Alignment of base address                       2048 bits (256 bytes)
  Preferred alignment for atomics
    SVM                                           0 bytes
    Global                                        0 bytes
    Local                                         0 bytes
  Max size for global variable                    3636461568 (3.387GiB)
  Preferred total size of global vars             4278190080 (3.984GiB)
  Global Memory cache size                        16384 (16KiB)
  Global Memory cache line size                   128 bytes
    Max number of samplers per kernel             16
    Max size for 1D images from buffer            134217728 pixels
    Max 1D or 2D image array size                 8192 images
    Base address alignment for 2D image buffers   256 bytes
    Pitch alignment for 2D image buffers          256 pixels
    Max 2D image size                             16384x16384 pixels
    Max 3D image size                             16384x16384x8192 pixels
    Max number of read image args                 128
    Max number of write image args                8
    Max number of read/write image args           64
  Max number of pipe args                         16
  Max active pipe reservations                    16
  Max pipe packet size                            3636461568 (3.387GiB)
  Local memory size                               65536 (64KiB)
  Local memory size per CU (AMD)                  65536 (64KiB)
  Local memory banks (AMD)                        32
  Max constant buffer size                        3636461568 (3.387GiB)
  Preferred constant buffer size (AMD)            16384 (16KiB)
  Queue properties (on host)
  Queue properties (on device)
    Out-of-order execution                        Yes
    Preferred size                                262144 (256KiB)
    Max size                                      8388608 (8MiB)
  Max queues on device                            1
  Max events on device                            1024
  Number of P2P devices (AMD)                     0
  Profiling timer offset since Epoch (AMD)        0ns (Thu Jan  1 01:00:00 1970)
  Execution capabilities
    Thread trace supported (AMD)                  No
    Number of async queues (AMD)                  8
    Max real-time compute queues (AMD)            8
    Max real-time compute units (AMD)             6
  printf() buffer size                            4194304 (4MiB)
  Built-in kernels                                (n/a)
  Device Extensions                               cl_khr_fp64 cl_khr_global_int32_base_atomics cl_khr_global_int32_extended_atomics cl_khr_local_int32_base_atomics cl_khr_local_int32_extended_atomics cl_khr_int64_base_atomics cl_khr_int64_extended_atomics cl_khr_3d_image_writes cl_khr_byte_addressable_store cl_khr_fp16 cl_khr_gl_sharing cl_amd_device_attribute_query cl_amd_media_ops cl_amd_media_ops2 cl_khr_image2d_from_buffer cl_khr_subgroups cl_khr_depth_images cl_amd_copy_buffer_p2p cl_amd_assembly_program
NULL platform behavior
  clGetPlatformInfo(NULL, CL_PLATFORM_NAME, ...)  AMD Accelerated Parallel Processing
  clGetDeviceIDs(NULL, CL_DEVICE_TYPE_ALL, ...)   Success [AMD]
  clCreateContext(NULL, ...) [default]            Success [AMD]
  clCreateContextFromType(NULL, CL_DEVICE_TYPE_DEFAULT)  Success (1)
    Device Name                                   gfx1034
  clCreateContextFromType(NULL, CL_DEVICE_TYPE_GPU)  Success (1)
    Device Name                                   gfx1034
  clCreateContextFromType(NULL, CL_DEVICE_TYPE_CUSTOM)  No devices found in platform
  clCreateContextFromType(NULL, CL_DEVICE_TYPE_ALL)  Success (1)
    Device Name                                   gfx1034
ICD loader properties
  ICD loader Name                                 OpenCL ICD Loader
  ICD loader Vendor                               OCL Icd free software
  ICD loader Version                              2.3.2
  ICD loader Profile                              OpenCL 3.0
i had to install amdgpu-install 7.1 to get it to function with the latest 24.04.4 lts kernel, however on amd homepage the graphics card results supported only for 24.04.3 lts
Radeon™ Pro Software for Enterprise on Ubuntu 24.04.3 Installer
Revision Number
25.Q3
File Size
Release Date
2025-07-17
Post by muziqaz »
Stop downloading and installing amdgpu. All you need for folding is: viewtopic.php?t=43222. Nothing else. The driver for the card comes with the kernel already
FAH Omega tester
nada391
Post by nada391 »
alright, will rmember ur advice,
however, last time i tried, wiht uninstalling amdgpu completely,
and installing 6.4.3 according to the guide , you linked, it failed nontheless (sorry to report)
also the updated guide with 7.0.1 did not do the trick.
maybe there is something with the card not properly supported (it seem all talk about rocm nowadays and the card certainly not in the list)
thanks!
nada391
Post by nada391 »
when using the guid you proposed and inserting version number 6.4.3 the card is properly recognized in fah-webview, but listed as not supported?
under clinfo the card is listed as function?
https://ibb.co/C5TXjzbn
https://ibb.co/p6d8MpHy
nada391
Post by nada391 »
thanks, the card supported again after heeding your advice,
and upgrading sources.list rocm from 6.4.3 to 7.0.1,
however there are still error?
WU41:Attempting to create OpenCL context:
08:55:01:I1:WU41: Configuring platform OpenCL
08:55:06:I1:WU41:Caught signal SIGABRT(6)
08:55:06:I1:WU41:WARNING:Unexpected exit
08:55:06:E :WU41:Core returned EARLY_UNIT_END (123)
08:55:06:E :WU41:Run did not produce any results. Dumping WU
08:55:06:I1:WU41:Sending dump report
08:55:07:I1:WU41:Dumped
maybe the error is because i booted the computer in "CSM" instead of "UEFI" mode?
EDIt: when updating the rocm driver from 6.4.3 to 7.0.1 clinfo now suddenly reports error like here
clinfo
  Platform Version                                OpenCL 2.1 AMD-APP (3662.0)
  Device Name                                     gfx1034
  Driver Version                                  3662.0 (HSA1.1,LC)
  Device Board Name (AMD)                         AMD Radeon Pro W6400
  Max compute units                               6
  SIMD width (AMD)                                32
Memory access fault by GPU node-1 (Agent handle: 0x5c8ade1e0420) on address 0x766a31566000. Reason: Page not present or supervisor privilege.
Aborted (core dumped)
Post by muziqaz »
Clinfo is no longer viable app to check the condition of OpenCL status
All my PCs clinfo reports no opencl platform or device, yet I'm folding fine
Also, make sure you don't have mesa-icd package, which takes over and breaks FAH functionality
FAH Omega tester
nada391
Post by nada391 »
have no idea what is going on,
the card is failing to fold across the board (24.04 , 22.04, win11 25h2) when previously it was folding just fine.
maybe the newer driver are causing this, since there seem to be o push to socalled "rocm" driver , but this card is not listed as compatible (only 7700 and above if not mistaken)
https://rocm.docs.amd.com/projects/inst ... ments.html
Post by muziqaz »
Stop reading AMD nonsensical documentation :D
I told you that I have equivalent card folding fine.
Be specific what is failing and on which projects
FAH Omega tester
nada391
Post by nada391 »
sorry but i cant tell what is failing , since the card is always stalling at 0 % and there are not proper error messages / warning present , although the folding lander does often show a orange bar with "warning" , but then if i click into the log and select warning or error, there is nothing present.
projects can§t tell you neither since dont keep track of those, am inscribed for project huntingtones.
Post by muziqaz »
When GPU stalls, check system journal logs for any events related to to the GPU.
Also, do you have Mesa installed?
Screenshot of the stalled WU log without any filters would be helpful as well
FAH Omega tester
nada391
Post by nada391 »
hello ,
thanks for all the help.
beginnening to suspect that the card may already have gone faulty,
or that the software folding is not fully compatible with the card itself any longer.
tried on another computer, also here getting error;
since seem to be the only one having such issues, may be have to write off the card project altogether and try something else.
error on fresh install of ubuntu 22.04 are like
19:15:35:I1:Logging into node account
19:15:43:I2:REQ4:< GET /api/websocket HTTP/1.1
19:16:07:I1:WU6:Caught signal SIGABRT(6)
19:16:07:I1:WU6:WARNING:Unexpected exit
19:16:07:E :WU6:Core returned EARLY_UNIT_END (123)
19:16:07:E :WU6:Run did not produce any results. Dumping WU
or
19:16:31:I1:WU7: Checkpoint write interval: 12500 steps (5%) [20 total]
19:16:31:I1:WU7: JSON viewer frame write interval: 2500 steps (1%) [100 total]
19:16:31:I1:WU7: XTC frame write interval: 5000 steps (2%) [50 total]
19:16:31:I1:WU7: TRR frame write interval: disabled
19:16:31:I1:WU7: Global context and integrator variables write interval: disabled
19:16:31:I1:WU7:There are 3 platforms available.
19:16:31:I1:WU7:Platform 0: Reference
19:16:31:I1:WU7:Platform 1: CPU
19:16:31:I1:WU7:Platform 2: OpenCL
19:16:31:I1:WU7: opencl-device 0 specified
19:17:43:I1:WU7:Attempting to create OpenCL context:
19:17:43:I1:WU7: Configuring platform OpenCL
19:17:47:I1:WU7:Caught signal SIGABRT(6)
19:17:47:I1:WU7:WARNING:Unexpected exit
19:17:48:E :WU7:Core returned EARLY_UNIT_END (123)
19:17:48:E :WU7:Run did not produce any results. Dumping WU
19:17:48:I1:Default:Added new work unit: cpus:0 gpus:gpu:03:00:00
nada391
Post by nada391 »
edit: i am wondering if this line still applies
(from your aoriginal guide ultima v8)
DO NOT download anything from 6.3 branch, unless you have $20k-200k+ AMD Instinct MI300A/X!!
have used v.6.4.3 , am at fault therefore?
Post by muziqaz »
nada391 wrote: Thu Feb 19, 2026 7:24 pm edit: i am wondering if this line still applies
No, this. That guide was done when AMD had a bit of the brainfart, which they fixed afterwards. 6.4.3+ is safe to use for your GPU, as I said, I have the latest release (7.2?) on my RDNA 2 GPU. Folding no problem
FAH Omega tester
