7900 XTX on Debian Trixie - "Failed to pin bo" error crashes GPU WUs
Vejeta
Post by Vejeta »
Hardware: AMD Ryzen 9 7900X + AMD RX 7900 XTX
OS: Debian Trixie (testing)
Kernel: 6.17.13+deb14-amd64 (also tried Liquorix 6.18.7)
ROCm: 6.4.3 from Debian repos
F@H: v8.5.5
GPU is detected and shows "supported: true". CPU WUs work fine.
GPU WUs start but crash after a few seconds with:
From dmesg:
amdgpu: Failed to pin bo. ret -1
amdgpu: Failed to map wptr bo to GART
From F@H log:
Error initializing context: clCreateCommandQueue (-6)
ERROR:125: Failed to create a GPU-enabled OpenMM Context.
Already tried:
- libstdc++ symlink fix
- Different kernels (Debian 6.17, Liquorix 6.18)
- Disabling KDE compositor
- HSA_OVERRIDE_GFX_VERSION=10.3.0
@muziqaz - I believe I have read that you have 7900 XTX working. What kernel/ROCm version do you use and what tips do you suggest?
Any suggestion is welcome
Re: 7900 XTX on Debian Trixie - "Failed to pin bo" error crashes GPU WUs
Post by muziqaz »
FAH Omega tester
Vejeta
Post by Vejeta »
Thanks musiqaz, basically I wasn't fully following your guide before.
Extended:
Problem: GPU detected as "supported: true" but WUs crashed after several minutes with:
Core returned BAD_WORK_UNIT (114)
The root cause was twofold: the conflict between Debian's ROCm packages and AMD's ROCm packages creating two OpenCL platforms, plus wrong GPU architecture detection (gfx1030 instead of gfx1100).
Fix
1. Add AMD ROCm repo (Trixie uses Sequoia/sqv for GPG verification):
echo 'Apt::Key::gpgvcommand "/usr/bin/gpgv";' | sudo tee /etc/apt/apt.conf.d/99rocm-gpgv
wget -qO - https://repo.radeon.com/rocm/rocm.gpg.key | sudo gpg --dearmor -o /etc/apt/keyrings/rocm.gpg
echo 'deb [arch=amd64 signed-by=/etc/apt/keyrings/rocm.gpg] https://repo.radeon.com/rocm/apt/6.4.3 noble main' | sudo tee /etc/apt/sources.list.d/rocm.list
sudo apt update
2. Install AMD ROCm and remove Debian's conflicting packages:
sudo apt install rocm-opencl-runtime ocl-icd-opencl-dev
sudo apt remove rocm-opencl-icd
3. Remove duplicate ICD:
sudo rm /etc/OpenCL/vendors/amdocl64.icd
# Keep only amdocl64_60403_128.icd from AMD
4. Remove any HSA overrides (this is something that I introduced, and only meaningful for my case, but to leave it documented):
sudo rm /etc/systemd/system/fah-client.service.d/amd-fix.conf
# Or remove any HSA_OVERRIDE_GFX_VERSION lines
I had [Service]
Environment="HSA_OVERRIDE_GFX_VERSION=10.3.0" here
5. Restart:
sudo systemctl daemon-reload
sudo systemctl restart fah-client
Now
clinfo | grep -E "Number of platforms|Device Name"
# Should show: 1 platform, gfx1100
After several years contributing with CPU, now I have for the first time a GPU that can contribute a good amount of Working Units.
