Switched Team
HandOverFist
Hardware configuration: X870E Tiachi - 9900X - (2) RTX 4080 (X3)
Switched Team
Post by HandOverFist »
Joined Alliance Francophone team this morning and entered the team #51. All looks good except when I search for my user name "Rollo" it shows me as being a member of Pande Lab. What is going on?
Re: Switched Team
Post by muziqaz »
HandOverFist wrote: Fri Jan 23, 2026 4:46 pm Joined Alliance Francophone team this morning and entered the team #51. All looks good except when I search for my user name "Rollo" it shows me as being a member of Pande Lab. What is going on?
Patience grasshopper.
Your nickname will always be shown the old team, and after some time, when servers update, you will show up on the new team too
FAH Omega tester
Re: Switched Team
Usernames are not unique or registered. The name Rollo has been used on a total of 5 different teams including the Pande Lab team. So any points earned and credited to a specific username and team will remain with team.
The API that looks up your stats through the client initially only looked up by username and passkey which will remain unique. The API is a bit sticky and it can take a bit before it will show a different team.
You can use the web apps located here - https://apps.foldingathome.org - to check recent WUs returned and see which team they are credited to. Note that if you changed the team in the middle of processing a WU you will just get base points.
HandOverFist
Re: Switched Team
I'll wait a bit longer then. I was confused because I have never been a part of Pande Lab. Been folding all morning and just assumed enough time had passed to update.
Re: Switched Team
Post by calxalot »
Make sure you are using
https://v8-5.foldingathome.org
The old web control did not correctly send account updates to clients. You would have to relaunch a client for it to pick up, for example, a team change.
HandOverFist
Re: Switched Team
Got it...thanks to all!
nada391
Re: Switched Team
Post by nada391 »
hello , would likely prefer to switch from team "Banano" to something more promising ;
do i need an invitation or how is a change effectuated?
thanks.
Re: Switched Team
Post by muziqaz »
nada391 wrote: Fri Jan 30, 2026 4:09 pm hello , would likely prefer to switch from team "Banano" to something more promising ;
thanks.
Enter teams number in your settings and you are good to go
FAH Omega tester
nada391
Re: Switched Team
Post by nada391 »
thanks, can i also create "self-made"team ?
looked through the list here and found hard of familiar
https://folding.extremeoverclocking.com/team_list.php
asked otherwise: is there a list where all teams are shown from those to be selected?
Re: Switched Team
Post by muziqaz »
nada391 wrote: Fri Jan 30, 2026 4:46 pm thanks, can i also create "self-made"team ?
You can do whatever you like :)
FAH Omega tester
nada391
Re: Switched Team
Post by nada391 »
thanks, found the tool here
https://stats.foldingathome.org/team
what about the list with all the team currently active/on display?
Re: Switched Team
Post by muziqaz »
nada391 wrote: Fri Jan 30, 2026 4:58 pm thanks, found the tool here
You have it in your own post. Or use extremeOC website
FAH Omega tester
Re: Switched Team
Whatever team you want or create your own, as far as the F@h consortium is concerned you can select any team just by entering its number. All credits for completed WUs remain with the username, team, etc that they were folded under.
Some teams have rewards, F@h is not involved in those. If you want those rewards you have to follow the team's directions as outlined on their website or other support channels. To say it another way, F@h only awards points, they do not give any other awards or get involved in how teams do any rewards they give out based on those points.
