Project 15216 (RCG 0,7,0)
EL_HAM
Post by EL_HAM »
Code User Team Credit Assigned Credited
Ok HayesK_ALL_18SjyNbF8VdXaNAFCVfG4rAHUyvtdmoFvX 32 1,353,800 2025-10-27 19:00:59 2025-10-27 21:04:08
Failed [My Username] 238272 0 2025-12-18 11:49:57 2025-12-18 11:54:55
Failed Dramatize 37726 0 2025-12-18 11:51:23 2025-12-18 11:54:55
Failed Scorpuk 35947 0 2025-12-18 11:54:08 2025-12-18 11:54:55
Failed Flaschie 37651 0 2025-12-18 12:04:06 2025-12-18 12:14:56
Failed dmandrell 35933 0 2025-12-18 12:27:15 2025-12-18 12:35:03
Another zero percent progress, 43 seconds, and immediately failed.
The first successful attempt was almost 2 months ago, probably doesn't count.
The latter two users also finished WU with a 99.xx % ratio, around 10k and 56k WU in total (update: added two more, pretty much similar story)
This is the second failure I had on the same day, after 17 days went smoothly, previous topic:
viewtopic.php?t=43410
EL_HAM
Re: Project 15216 (RCG 0,7,0)
Post by EL_HAM »
Another note: after the previous post, I got WU from project 18245 without issues for the 32nd time over the last 17 days before getting the WU in this topic.
Post by muziqaz »
Thanks
These failing projects are from the same researcher
FAH Omega tester
EL_HAM
Post by EL_HAM »
muziqaz wrote: Thu Dec 18, 2025 12:13 pm Thanks
I see, now I think I remember something about it. I'll post yet another bad WU in the next post (project already posted on the same day, but now with new RCG, probably an attempted fix but failed).
Post by muziqaz »
I emailed researcher about this
FAH Omega tester
EL_HAM
Post by EL_HAM »
I added the next 2 users.
