Project: 15209 (Run 4, Clone 0, Gen 0)
Mactin
Post by Mactin »
As I write this WU (p15209-r4-c0-g0) has failled 5 times right at start.
I think it might be genuinely bad.
User Team CPUID Credit Assigned Returned Credited Days Code
mip456 251999 8B33BECC8A3F8B93 0 2025-12-17 23:30:04 2025-12-17 23:30:30 2025-12-17 23:35:08 0 Failed
Martin_r7-8700f+RTX5060Ti 96377 9E7A8041BC2A57C4 0 2025-12-18 00:07:28 2025-12-18 00:08:25 2025-12-18 00:14:54 0.001 Failed
Neo-52 240890 4E70CB45270A98FC 0 2025-12-18 00:20:19 2025-12-18 00:20:55 2025-12-18 00:25:17 0 Failed
mame63 86565 E2741AACDEB484E6 0 2025-12-18 00:30:10 2025-12-18 00:30:48 2025-12-18 00:35:04 0 Failed
DeputyKovacs 32 B591222F1CA188E2 0 2025-12-18 00:32:11 2025-12-18 00:33:16 2025-12-18 00:35:04 0.001 Failed
BobWilliams757
Ryzen 2400G APU
32 GB DDR4-3200
MSI GTX 1660 Super Gaming X
Re: Project: 15209 (Run 4, Clone 0, Gen 0)
Post by BobWilliams757 »
That's the way the system works. At this point the researcher should get a notification of the failures, and it should quit being assigned.
Then the researcher can take a look and try to figure out why it failed.
Fold them if you get them!
Post by muziqaz »
Thanks for the report
FAH Omega tester
