Weird "exception: bad allocation" behaviour
Schrödinger's cat
Hardware configuration: NVIDIA RTX 4080 Super
20 x Raspberry Pi 5 Model B 2GB RAM
Post by Schrödinger's cat »
My GPU has had a least a couple of these problems:
04:35:08:WU00:FS00:0x27:Completed 0 out of 250000 steps (0%)
04:35:13:WU00:FS00:0x27:Checkpoint completed at step 0
04:35:24:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
04:35:48:WU00:FS00:0x27:Completed 2500 out of 250000 steps (1%)
04:36:08:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
04:36:26:WU00:FS00:0x27:Completed 5000 out of 250000 steps (2%)
04:36:46:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
04:37:01:WU00:FS00:0x27:Completed 7500 out of 250000 steps (3%)
04:37:35:WU00:FS00:0x27:Completed 10000 out of 250000 steps (4%)
04:37:56:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
04:38:09:WU00:FS00:0x27:Completed 12500 out of 250000 steps (5%)
04:38:16:WU00:FS00:0x27:Checkpoint completed at step 12500
04:38:50:WU00:FS00:0x27:Completed 15000 out of 250000 steps (6%)
04:39:24:WU00:FS00:0x27:Completed 17500 out of 250000 steps (7%)
04:39:40:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
04:39:58:WU00:FS00:0x27:Completed 20000 out of 250000 steps (8%)
04:40:14:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
04:40:32:WU00:FS00:0x27:Completed 22500 out of 250000 steps (9%)
04:40:48:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
04:41:06:WU00:FS00:0x27:Completed 25000 out of 250000 steps (10%)
04:41:14:WU00:FS00:0x27:Checkpoint completed at step 25000
04:41:34:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
04:41:48:WU00:FS00:0x27:Completed 27500 out of 250000 steps (11%)
04:42:10:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
04:42:23:WU00:FS00:0x27:Completed 30000 out of 250000 steps (12%)
04:42:57:WU00:FS00:0x27:Completed 32500 out of 250000 steps (13%)
04:43:32:WU00:FS00:0x27:Completed 35000 out of 250000 steps (14%)
04:44:06:WU00:FS00:0x27:Completed 37500 out of 250000 steps (15%)
04:44:13:WU00:FS00:0x27:Checkpoint completed at step 37500
04:44:48:WU00:FS00:0x27:Completed 40000 out of 250000 steps (16%)
04:45:22:WU00:FS00:0x27:Completed 42500 out of 250000 steps (17%)
04:45:39:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
04:45:57:WU00:FS00:0x27:Completed 45000 out of 250000 steps (18%)
04:46:14:ERROR:std::exception: bad allocation
04:46:21:ERROR:WU00:FS00:std::exception: bad allocation
04:46:23:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
04:46:30:WU00:FS00:0x27:Completed 47500 out of 250000 steps (19%)
Note that the problem just disappeared after 19%.
What I find confusing is that folding wasn't restarted after the bad allocation exception. Does anyone understand what's going on? Could it be related to RAM, as Folding@home data is saved to a RAM disk.
Re: Weird "exception: bad allocation" behaviour
Post by muziqaz »
RAM disk?
Please use conventional storage devices for FAH.
FAH Omega tester
Schrödinger's cat
muziqaz wrote: Wed Dec 17, 2025 8:33 am RAM disk?
I've been using a RAM disk for years without any issues.
The only thing that has changed is my GPU, which can produce viewerFrame.json files that are bigger than 32MB, for which I increased the size of the RAM disk, and Dynamic Memory Allocation, which only uses as much RAM as the data on the disk requires, at any time. The RAM disk data is saved to my SSD before rebooting or shutting down.
I have only discovered the error twice, and it appears to be random.
Post by muziqaz »
Schrödinger's cat wrote: Wed Dec 17, 2025 1:17 pm
Years or decades, it doesn't matter. You are still using volatile medium as your storage in scientific application, which requires total stability. The fact that you had to increase RAM disk size because of fah visualisation tells me you are running it at bleeding edge, of "just about ok".
FAH Omega tester
Schrödinger's cat
muziqaz wrote: Wed Dec 17, 2025 4:49 pm The fact that you had to increase RAM disk size because of fah visualisation tells me you are running it at bleeding edge, of "just about ok".
Hardly. I've seen viewerFrame.json files of 11 and 32 KB too.
PaulTV
Hardware configuration: Fedora Linux w/ v8.5.6
Ryzen 9800X3D / RTX 4090
Ryzen 9800X3D / RTX 5070 Ti
Ryzen 5600 / RTX 3070 Ti
Post by PaulTV »
I see the bad allocation messages frequently, but only on jobs for project 18261. Which may or may not be related. To be sure I double checked my SSD health, and it is 100% fine.
Post by muziqaz »
PaulTV wrote: Thu Dec 18, 2025 9:53 am I see the bad allocation messages frequently, but only on jobs for project 18261. Which may or may not be related. To be sure I double checked my SSD health, and it is 100% fine.
18261 requires 10GB of free RAM to get a request for it. Once received, if free RAM dips below required, you might get issues. This also reminds me, page file allocation is also important. Anyone who has it restricted to some specific value might run into issues
FAH Omega tester
PaulTV
Post by PaulTV »
muziqaz wrote: Thu Dec 18, 2025 10:59 am
I see those messages (also) at times when I'm peacefully asleep, and nothing else is running on the machine. Windows 11, 32 GB, 4 TB hard disk with plenty of free space and no special swap config. As only jobs for this project give those messages, and I don't see other strange behaviour, I don't expect it to be a hardware issue (like bad memory). It might be a glitch somewhere, and bad allocation messages are on my to ignore list... But given this thread was started because of those bad allocation messages, I chipped in :)
Post by muziqaz »
Oh, this is v7 client. I think more and more you will start seeing random things stop behaving like normal, since the client is no longer actively developed and supported. Infrastructure is being fine tuned for v8 client, and if things work on v7, they work, but if they don't there will not going to be any effort put in to fix it.
FAH Omega tester
Schrödinger's cat
I can confirm that only 18261 work units cause this, and do so once every work unit:
Project: 18261 (Run 155, Clone 2, Gen 22) is currently running and creating 31.7MB viewerFrame.json files, and using 11GB of RAM.
I've also seen a work unit use more than 15GB of RAM when first starting. I'm unsure if that was an 18261 work unit.
Last edited by Schrödinger's cat on Sun Dec 21, 2025 12:26 pm, edited 1 time in total.
Post by muziqaz »
Schrödinger's cat wrote: Sat Dec 20, 2025 3:48 pm I can confirm that only 18261 work units cause this, and do so every time:
Yes, when WUs are starting they peak RAM usage. Then, when finishing a WU, they kinda come close to the peak.
v8.5.5 curbs viewerFrame.json file sizes, too. This is to prevent memory leak in the client
FAH Omega tester
This usually means the there's not enough system RAM and/or virtual memory available.
It could also be memory leaks from the client which affect biggest projects like 18261.
Those leaks are fixed in v8.5 clients.
Schrödinger's cat
toTOW wrote: Mon Dec 22, 2025 6:27 pm
I believe the problem is project 18261. it happens every time with that project (just once and doesn't require the client to restart). But doesn't happen with 18260, 18262 and 18263.
And, a lack of memory isn't the problem, as the error often occurs between 15% and 20%, long after the previous job has been cleaned up (freeing up RAM), and before the work folder is even close to half full (15-20 of 100 frames data).
BobWilliams757
Ryzen 2400G APU
32 GB DDR4-3200
MSI GTX 1660 Super Gaming X
Post by BobWilliams757 »
Forgot about this thread, and have confirmed the same error. I finally caught the last one and watched when it tossed the error, and there was plenty of memory left to use if it was needed.
I noticed the trend of it being 18261 for me back before this thread. I didn't get many of those projects but did happen to catch the last one I had and watched for any memory/system weirdness.
ETA: Is this still running or have assignments changed? I haven't had any of these work units since the end of November.
Fold them if you get them!
I though p18261 wouldn't assign to clients <8.5 ... I might be mixing project numbers.
