Set folding to run at specific hours/days
Tropical Snowman
Hello there,
is there a way to schedule Folding to run only during specific hours and days? For example, to take advantage of lower electricity rates, or to warm up during winter nights or avoid too much heat during summer.
In my case, the reason would be electricity rates and I'd like to set Folding to run from 23:00 (11 pm) to 16:00 (4 pm) next day; and full day on Sundays.
Thanks
Thanks
Re: Set folding to run at specific hours/days
There's nothing built into the client that does that. I think you could use automation features built into your OS together with command line commands to pause & resume folding on a schedule, but I haven't attempted it myself.
Mxyzptlk
- Hardware configuration: Lots... Look at my website: www.mxyzptlk.us
If you are running 7.6.21, you can us this to do that. But nothing for V8...
https://chromewebstore.google.com/detai ... ahoe?pli=1
Tropical Snowman
Mmmh, so nobody has ever requested that feature? Should I request it for the new release?
How did you assume that no one requested that feature?Tropical Snowman wrote: ↑Sun Dec 14, 2025 7:13 pm Mmmh, so nobody has ever requested that feature? Should I request it for the new release?
It has been a requested feature to be built into the client since the v7 days. But it is so far down the priority list for the one paid developer that I doubt it will ever be included. However the API for the v7 client was published, various people did create add-ons or scripts to do scheduling. The API for v8 has not been explicitly posted, but the client and web control are open source. I vaguely recall seeing mention that someone had created an alternate control for v7 that included scheduling.
Some people are using whatever native scheduling exists on their OS with either fahctl or lufah.
Allow scheduling folding at certain times
https://github.com/FoldingAtHome/fah-we ... /issues/53
Mxyzptlk
The feature is built into BOINC, no reason it shouldn't be in F@H. With the high cost of energy and time of use metering, I really don't understand why its not. Lack of the feature is literally preventing further people from actively folding.
appepi
- Hardware configuration: HP Z600 (5) HP Z800 (3) HP Z440 (3) HP Z4G4 (3) ASUS Turbo GTX 1060, 1070, 1080, RTX 2060 (3) Dell GTX 1080 NVIDIA P1000 (2) K1200
This is one of a number of problems/ challenges with 8.4.9 that has led me to stay with 7.6.21 and use the scheduler in the Lar Systems app - see viewtopic.php?p=370490#p370490. Time of use electricity charging is increasingly common, and "Folding while I am using the computer anyway" seems to be decreasingly common, so it is surely time that scheduling was seen as a high priority.
Here in sunny AU the uptake of rooftop solar is such that oversupply of solar power at times has resulted in upcoming plans offering three "free" hours in the middle of the day, intended to help stabilise the overall system during the transition away from coal. This of course is handy for some folk and not so handy for others, but will certainly increase the variation in the costs of folding at different times of day for anyone who has to buy their electricity here. Most loads for most people are not so easy to adjust, but folding-only use is entirely discretionary and although none of my CPU's could fold anything in 3 hours, the 6 GPUs I usually run can do so. I already run the more efficient ones (RTX 2060s) for 9 "off peak" hours from 10pm to 7 am, and three others (2x GTX 1080, 1x GTX1070) for a single WU during the "off peak" hours, to stay within my notional Folding budget. The Lar Systems scheduler switches to "Finish and Stop" when the scheduled time ends (rather than "Pause") so occasionally I have to manually pause ill-behaved WUs, but luckily my current supply contract has a "shoulder" rate (=off peak +22%) from 7am to the start of "Peak" rates (=off peak +119%) at 2pm so a few hours of over-run don't matter much. The contract also replaces "peak" rates with "shoulder" rates on weekends, and I have to deal with that - if I want to- manually. Obviously this is not full automation of scheduling, but it works well enough for me.
I note that a programmed change from "Fold" status to either "Finish up and Stop" or "Pause" should be conditional, both for the good of science and the good of points. Obviously it is not good for anyone to Pause a job that is one minute away from completion, and not good for the Donor continue one (like a horrible project I complained about) that wanted to run for 14 more hours and even then would only award my 2060s with 60%-75% of their usual PPD. If part of the client setup were to be a relative electricity-rate profile, then it would be possible for Finish"/"Pause" decision to be made to be contingent on the Donor's choice of a cutoff on a suitable cost/benefit function based Scheduler times, and on predicted completion time and Cost/PPD with/without Pause. After all, the client IS running on a computer, and they are generally believed to be able to perform simple calculations.
Tropical Snowman
Well, that was a question. Seems like many people agree it should be implemented.muziqaz wrote: ↑Sun Dec 14, 2025 7:19 pmHow did you assume that no one requested that feature?Tropical Snowman wrote: ↑Sun Dec 14, 2025 7:13 pm Mmmh, so nobody has ever requested that feature? Should I request it for the new release?![]()
Tropical Snowman
Could you please provide an example? So that I copy it for my system. I'm on Windows 11, wouldn't know how to do it. I'm kind of a "casual" user, not a programmer or anything like that. Just like helping science. I'm okay with some cost even, but if I can keep the bill on the lower side that's certainly better.
No, some people agree, not "many".Tropical Snowman wrote: ↑Thu Dec 18, 2025 12:00 amWell, that was a question. Seems like many people agree it should be implemented.muziqaz wrote: ↑Sun Dec 14, 2025 7:19 pmHow did you assume that no one requested that feature?Tropical Snowman wrote: ↑Sun Dec 14, 2025 7:13 pm Mmmh, so nobody has ever requested that feature? Should I request it for the new release?![]()
prcowley
- Hardware configuration: Op Sys: Linux Ubuntu Studio 25.04
Kernel: 6.14.0-34-generic (64-bit)
Processor: AMD Ryzen 7 7800X3D 8-Core Processor
Mem: 32 GB
GPU: NVIDIA GeForce RTX 4080 SUPER/PCIe/SSE2 - Location: Gisborne, New Zealand
There is a utility program called fahctl (https://github.com/FoldingAtHome/fah-client-bastet) which is command line program that lets you start (fold) & pause and finish
Using crontab you could set up a start time "fahctl fold" and a stop time "fahctl pause"
I don't see any reason why this would not work, but I have not tried it myself.
Pete Cowley, Gisborne, New Zealand. The first city to see the light of the new day.
Install python from command shell.Tropical Snowman wrote: ↑Thu Dec 18, 2025 12:04 amCould you please provide an example? So that I copy it for my system. I'm on Windows 11, wouldn't know how to do it. I'm kind of a "casual" user, not a programmer or anything like that. Just like helping science. I'm okay with some cost even, but if I can keep the bill on the lower side that's certainly better.
This should offer to install python from the MS app store.
Note that lufah requires python 3.9 or later.
python --version
pip install pipx
pipx ensurepath
pipx install lufah
The following was created by ChatGPT5 and has not been tested.
I am generally not a Windows user.
Create XML task definition files.
You will need to modify these examples for your needs.
It might be easiest to ask AI to create or modify these windows task manager xml files
lufah-fold-9pm.xml
<?xml version="1.0" encoding="UTF-16"?>
<Task version="1.4"
xmlns="http://schemas.microsoft.com/windows/2004/02/mit/task">
<Triggers>
<CalendarTrigger>
<StartBoundary>2025-12-17T21:00:00</StartBoundary>
<ScheduleByDay>
<DaysInterval>1</DaysInterval>
</ScheduleByDay>
</CalendarTrigger>
</Triggers>
<Principals>
<Principal id="Author">
<LogonType>InteractiveToken</LogonType>
<RunLevel>LeastPrivilege</RunLevel>
</Principal>
</Principals>
<Settings>
<WakeToRun>true</WakeToRun>
<StartWhenAvailable>true</StartWhenAvailable>
<MultipleInstancesPolicy>IgnoreNew</MultipleInstancesPolicy>
<Enabled>true</Enabled>
</Settings>
<Actions Context="Author">
<Exec>
<Command>lufah</Command>
<Arguments>fold</Arguments>
</Exec>
</Actions>
</Task>
<Task version="1.4"
<Triggers>
<CalendarTrigger>
<StartBoundary>2025-12-18T08:00:00</StartBoundary>
<ScheduleByDay>
</ScheduleByDay>
</CalendarTrigger>
</Triggers>
<Principals>
</Principal>
</Principals>
<Settings>
</Settings>
<Exec>
<Arguments>finish</Arguments>
</Exec>
</Actions>
</Task>
schtasks /create /tn "Lufah Fold (9pm)" /xml lufah-fold-9pm.xml /f
schtasks /create /tn "Lufah Finish (8am)" /xml lufah-finish-8am.xml /f
but these tasks cannot wake system to run without using the Task Manager GUI to modify them.
Example to pause at 2pm
schtasks /create ^
/sc daily ^
/st 14:00 ^
/tn "Lufah Pause (2pm)" ^
/tr "lufah pause" ^
/f
schtasks /query /tn "Lufah Pause (2pm)" /v /fo list
schtasks /create ^
/sc weekly ^
/d MON,TUE,WED,THU,FRI,SAT ^
/st 14:00 ^
/tr "lufah pause" ^
/f
