19020, core 0x22, rx7900xtx
anonymous defaulteam
Hardware configuration: [rx7900xtx/5950x/64gb]
[rtx5060/5500/32gb]
Post by anonymous defaulteam »
Project 19020 seems to fail on my radeon setup. Is it my hardware? Do I need to report it here? What info to attach?
It looks like it doesn't opencl (old core???)? other projects fold nicely (at least 0x24 and 0x27)
Am sorry if confusing I'm tired and heading to bed now.
21:55:13:I1:WU40:DOWNLOAD 9% 1.63MiB of 17.40MiB
21:55:14:I1:WU40:DOWNLOAD 100% 17.40MiB of 17.40MiB
21:55:14:I1:OUT18:< HTTP/1.1 200 HTTP_OK
21:55:14:I1:WU40:Received WU P19020 R13 C12 G10
21:55:14:I1:Loaded cores/openmm-core-22/fahcore-22-linux-64bit-release-0.0.20/FahCore_22
21:55:14:I3:Running FahCore: /var/lib/fah-client/cores/openmm-core-22/fahcore-22-linux-64bit-release-0.0.20/FahCore_22 -dir iPNtC2tGfHVz3suMs7fClEP7ojvX_73g2Pgu3aaiyKM -suffix 01 -version 8.4.9 -lifeline 1177 -gpu-platform cuda -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
21:55:14:I3:WU40:Started FahCore on PID 7556
21:55:14:I1:WU40:*********************** Log Started 2025-12-09T21:55:14Z ***********************
21:55:14:I1:WU40:*************************** Core22 Folding@home Core ***************************
21:55:14:I1:WU40:       Core: Core22
21:55:14:I1:WU40:       Type: 0x22
21:55:14:I1:WU40:    Version: 0.0.20
21:55:14:I1:WU40:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
21:55:14:I1:WU40:  Copyright: 2020 foldingathome.org
21:55:14:I1:WU40:   Homepage: https://foldingathome.org/
21:55:14:I1:WU40:       Date: Jan 20 2022
21:55:14:I1:WU40:       Time: 00:57:52
21:55:14:I1:WU40:   Revision: 3f211b8a4346514edbff34e3cb1c0e0ec951373c
21:55:14:I1:WU40:     Branch: HEAD
21:55:14:I1:WU40:   Compiler: GNU 9.4.0
21:55:14:I1:WU40:    Options: -faligned-new -std=c++11 -fsigned-char -ffunction-sections
21:55:14:I1:WU40:             -fdata-sections -O3 -funroll-loops -fno-pie
21:55:14:I1:WU40:             -DOPENMM_VERSION="\"7.7.0\""
21:55:14:I1:WU40:   Platform: linux 5.11.0-1025-azure
21:55:14:I1:WU40:       Bits: 64
21:55:14:I1:WU40:       Mode: Release
21:55:14:I1:WU40:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
21:55:14:I1:WU40:             <peastman@stanford.edu>
21:55:14:I1:WU40:       Args: -dir iPNtC2tGfHVz3suMs7fClEP7ojvX_73g2Pgu3aaiyKM -suffix 01
21:55:14:I1:WU40:             -version 8.4.9 -lifeline 1177 -gpu-platform cuda -gpu-vendor amd
21:55:14:I1:WU40:             -opencl-platform 0 -opencl-device 0 -gpu 0
21:55:14:I1:WU40:************************************ libFAH ************************************
21:55:14:I1:WU40:       Time: 00:57:22
21:55:14:I1:WU40:   Revision: 9f4ad694e75c2350d4bb6b8b5b769ba27e483a2f
21:55:14:I1:WU40:************************************ CBang *************************************
21:55:14:I1:WU40:       Time: 00:57:00
21:55:14:I1:WU40:   Revision: ab023d155b446906d55b0f6c9a1eedeea04f7a1a
21:55:14:I1:WU40:             -fdata-sections -O3 -funroll-loops -fno-pie -fPIC
21:55:14:I1:WU40:************************************ System ************************************
21:55:14:I1:WU40:        CPU: AMD Ryzen 9 5950X 16-Core Processor
21:55:14:I1:WU40:     CPU ID: AuthenticAMD Family 25 Model 33 Stepping 2
21:55:14:I1:WU40:       CPUs: 32
21:55:14:I1:WU40:     Memory: 62.71GiB
21:55:14:I1:WU40:Free Memory: 57.04GiB
21:55:14:I1:WU40:    Threads: POSIX_THREADS
21:55:14:I1:WU40: OS Version: 6.12
21:55:14:I1:WU40:Has Battery: false
21:55:14:I1:WU40: On Battery: false
21:55:14:I1:WU40: UTC Offset: 2
21:55:14:I1:WU40:        PID: 7556
21:55:14:I1:WU40:        CWD: /var/lib/fah-client/work
21:55:14:I1:WU40:************************************ OpenMM ************************************
21:55:14:I1:WU40:    Version: 7.7.0
21:55:14:I1:WU40:********************************************************************************
21:55:14:I1:WU40:Project: 19020 (Run 13, Clone 12, Gen 10)
21:55:14:I1:WU40:Reading tar file core.xml
21:55:14:I1:WU40:Reading tar file integrator.xml
21:55:14:I1:WU40:Reading tar file state.xml
21:55:15:I1:WU40:Reading tar file system.xml
21:55:15:I1:WU40:Digital signatures verified
21:55:15:I1:WU40:Folding@home GPU Core22 Folding@home Core
21:55:15:I1:WU40:Version 0.0.20
21:55:15:I1:WU40:  Checkpoint write interval: 100000 steps (5%) [20 total]
21:55:15:I1:WU40:  JSON viewer frame write interval: 20000 steps (1%) [100 total]
21:55:15:I1:WU40:  XTC frame write interval: 25000 steps (1.2%) [80 total]
21:55:15:I1:WU40:  Global context and integrator variables write interval: disabled
21:55:15:I1:WU40:There are 2 platforms available.
21:55:15:I1:WU40:Platform 0: Reference
21:55:15:I1:WU40:Platform 1: CPU
21:55:15:I1:WU40:opencl-device was set but OpenCL platform could not be found.
21:55:15:I1:WU40:ERROR:126: Neither CUDA nor OpenCL is available.
21:55:15:I1:WU40:Saving result file ../logfile_01.txt
21:55:15:I1:WU40:Saving result file science.log
21:55:15:I1:WU40:Folding@home Core Shutdown: BAD_WORK_UNIT
[91m21:55:15:E :WU40:Core returned BAD_WORK_UNIT (114)[0m
21:55:15:I1:Default:Added new work unit: cpus:0 gpus:gpu:08:00:00
21:55:15:I1:WU40:Uploading WU results
21:55:15:I1:WU41:Requesting WU assignment for user Anonymous team 0
21:55:15:I1:WU39:Caught signal SIGINT(2) on PID 7525
21:55:15:I1:WU39:Exiting, please wait. . .
21:55:15:I1:OUT19:> POST https://ds03.scs.illinois.edu/api/results HTTP/1.1
21:55:15:I1:OUT20:> POST https://assign5.foldingathome.org/api/assign HTTP/1.1
21:55:16:I1:OUT20:< HTTP/1.1 200 HTTP_OK
21:55:16:I1:WU41:Received WU assignment fyxnQ05z6vL-syITlSeR4xOuAwLacIahToYif6FtNhM
21:55:16:I1:WU41:Downloading WU
21:55:16:I1:WU39:Folding@home Core Shutdown: INTERRUPTED
21:55:16:I1:OUT19:< HTTP/1.1 200 HTTP_OK
21:55:16:I1:WU40:Credited
Re: 19020, core 0x22, rx7900xtx
Post by muziqaz »
viewtopic.php?t=42789
Recommend doing this to all the cores you have on your system(s), except core26/27/28. Even if core24 is working fine, do the trick mentioned in that thread
FAH Omega tester
[rtx5060/5500/32gb]
Well that was a fairly straightforward fix. Had only 22, 24 and 27 on this, and nothing but 27 on my other (rtx 5060) system. I'm curious to know if it's by design or whether I have messed up something during install?
Thanks for the help!
Post by muziqaz »
anonymous defaulteam wrote: Fri Dec 12, 2025 9:17 pm Well that was a fairly straightforward fix. Had only 22, 24 and 27 on this, and nothing but 27 on my other (rtx 5060) system. I'm curious to know if it's by design or whether I have messed up something during install?
By design. You can copy your core22 and core24 to other PC, keeping the same folder structure, and then do ln -s magic there
FAH Omega tester
