Installing on Raspberry Pi
koffy
Hardware configuration: 2 windows PC's and a Raspberry Pi 5
Post by koffy »
Hello all,
I just got a new Raspberry Pi and want to install folding on it but I can't seem to download the client, this is what I tried:
wget https://foldingathome.org/start-folding ... _arm64.deb
Thanks in advance for any help.
Re: Installing on Raspberry Pi
Post by muziqaz »
Have you tried installing Linux on the pi?
Have you tried switching it off and on again?
Have you tried again?
How did you try to install it?
Did you try using apt?
Did you use sudo in front of the apt?
Did you add ./ In front of the installation file after sudo apt install?
Did you point sudo apt install to the right location of the installation file?
Have you checked the error messages?
Have you told us what went wrong exactly?
In a minute I will become a new large language model with all this guessing.
I can go on and on until you tell us more information what is going wrong :)
Help us to help you
FAH Omega tester
koffy
Post by koffy »
Thanks for the reply, sorry to the lack of info.
I found the proper download link, works now: https://download.foldingathome.org/rele ... _arm64.deb
Post by muziqaz »
koffy wrote: Sun Dec 07, 2025 1:32 pm Thanks for the reply, sorry to the lack of info.
Hm, they are the same files
FAH Omega tester
Same file name, but the first full link given in the OP - https://foldingathome.org/start-folding ... _arm64.deb - goes to a page that doesn't exist. The download links on the Start Folding page points to download.foldingathome.org locations for the files.
Post by muziqaz »
Joe_H wrote: Sun Dec 07, 2025 3:25 pm Same file name, but the first full link given in the OP - https://foldingathome.org/start-folding ... _arm64.deb - goes to a page that doesn't exist. The download links on the Start Folding page points to download.foldingathome.org locations for the files.
This is the link in https://foldingathome.org/start-folding/
Where is that other link coming from?
Oh, unless this link is given when browser reports the OS type. Hm, however, I never had issues downloading it from linux on x86 or even ARM pihole
FAH Omega tester
Zfort
Hardware configuration: Asus PCI-E GeForce RTX 5060 8GB DDR7
Post by Zfort »
Yeah, I’ve run into something similar before. Folding@home can be a bit unpredictable sometimes, especially with certain work units or server-side issues.
Usually what helps is restarting the client or just letting it sit for a while — a lot of the time it fixes itself once new work units come in. Also worth checking logs to see if it’s a specific error repeating.
If it keeps happening, I’d try updating the client or switching slots (CPU/GPU) to see if one behaves better.
into tech, AI Development, and anything with a decent engine
