The client is not picking up any WU and I've tried setting the cpus active from 1 to 9
This happened a week ago. I removed FAH, reinstalled and it was working. I had to leave and set the client to finish the current WU. It did and since then, It does not download any WU.
00:06:46:I1: Compiler: GNU Apple LLVM 14.0.0 (clang-1400.0.29.202)
00:06:46:I1: Options: -std=c++17 -fsigned-char -stdlib=libc++ -O3 -funroll-loops -fno-pie
00:06:46:I1: -arch x86_64 -arch arm64 -mmacosx-version-min=10.13
00:06:46:I1: Platform: darwin 21.6.0
00:06:46:I1: Bits: 64
00:06:46:I1: Mode: Release
00:06:46:I1: Config: /Library/Application Support/FAHClient/config.xml
00:06:46:I1:****************************** CBang ******************************
00:06:46:I1: Version: 1.7.2
00:06:46:I1: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
00:06:46:I1: Org: Cauldron Development
00:06:46:I1: Copyright: Cauldron Development, 2003-2024
00:06:46:I1: Homepage: https://cauldrondevelopment.com/
00:06:46:I1: License: LGPL-2.1-or-later
00:06:46:I1: Date: Nov 20 2024
00:06:46:I1: Time: 08:59:26
00:06:46:I1: Revision: 443c54e909eb8d8994405a18fb328b5b05a623a5
00:06:46:I1: Branch: master
00:06:46:I1: -arch x86_64 -arch arm64 -mmacosx-version-min=10.13 -fPIC
00:06:46:I1:***************************** System ******************************
00:06:46:I1: CPU: Apple M4
00:06:46:I1: CPU ID: Apple Family 8 Model 0 Stepping 0
00:06:46:I1: CPUs: 10
00:06:46:I1: Memory: 24.00GiB
00:06:46:I1:Free Memory: 20.34GiB
00:06:46:I1: OS Version: 26.1
00:06:46:I1:Has Battery: false
00:06:46:I1: On Battery: false
00:06:46:I1: Hostname: Mac-mini-2.local
00:06:46:I1: UTC Offset: -7
00:06:46:I1: PID: 331
00:06:46:I1: CWD: /Library/Application Support/FAHClient
00:06:46:I1: Exec: /usr/local/bin/fah-client
00:06:46:I1:*******************************************************************
00:06:46:I2:<config>
00:06:46:I2: <!-- Project Settings -->
00:06:46:I2: <cause v='COVID_19'/>
00:06:46:I2:
00:06:46:I2: <!-- User Information -->
00:06:46:I2: <passkey v='*****'/>
00:06:46:I2: <team v='163473'/>
00:06:46:I2: <user v='TowerofBoomhower'/>
00:06:46:I2:</config>
00:06:46:I1:Opening Database
00:06:47:I1:F@H ID = E07u0FyfFQnXsboqD0DjcKNkzB2hsmFy2Qm95KUVB3M
00:06:47:I3:Loading default resource group
00:06:47:I1:Listening for HTTP on 127.0.0.1:7396
00:06:47:I3:Loaded 0 wus.
00:06:47:I1:Default:Added new work unit: cpus:1 gpus:
00:06:47:W :CON1:DNS lookup failed for api.foldingathome.org
00:06:47:E :OUT1:Failed response: CONNECT
00:06:47:I1:WU14:Requesting WU assignment for user MacnPC team 163473
00:06:47:W :CON2:DNS lookup failed for assign1.foldingathome.org
00:06:47:E :OUT2:Failed response: CONNECT
00:06:47:I1:WU14:Retry #1 in 2 secs
00:06:50:I1:WU14:Requesting WU assignment for user MacnPC team 163473
00:06:50:W :CON3:DNS lookup failed for assign2.foldingathome.org
00:06:50:E :OUT3:Failed response: CONNECT
00:06:50:I1:WU14:Retry #2 in 4 secs
The log has this repeating cycle, retrys are increasing by 1:
19:20:51:I1:WU14:Requesting WU assignment for user MacnPC team 163473
19:20:52:I1:OUT135:> POST https://assign1.foldingathome.org/api/assign HTTP/1.1
19:20:52:I1:OUT135:< HTTP/1.1 503 HTTP_SERVICE_UNAVAILABLE
19:20:52:E :OUT135:HTTP_SERVICE_UNAVAILABLE: {"error":"No appropriate assignment"}
19:20:52:I1:WU14:Retry #79 in 8 mins 32 secs
Thank you for any help with this.
Bill
"No appropriate assignment"?
daiko
- Hardware configuration: Mac Studio M1 Max
Mac Mini M4 Pro
M2 Macbook Air
Folding since 2005 - Location: Atlantic County, NJ
Re: "No appropriate assignment"?
Bill,
Seeing this line in your log:
It looks like you only have 1 cpu assigned for FAH. You’ll need at least 2 to get a work unit.
The M4 should give you good performance. I see about 600K PPD with 8 cores.
You’ll need to adjust settings in the web client and save the new config.
I think I found a workaround. After logging in, even though the client is trying to get WUs, I clicked pause all, waited a few seconds, clicked Fold All. Now it's downloading and processing a WU. There seems to be an issue with getting the WU when cpu setting at 1 cpu. Maybe. I upped it to 4, it started downloading. I tried backing it down to 1 and it's still working, but settled on 2 cpus. It's running at 104,000ppd
What are your thoughts?
Thanks.
Thanks.
Thoughts are you don't play with CPU thread count every 5 minutes256304 wrote: ↑Tue Nov 18, 2025 10:18 pm I think I found a workaround. After logging in, even though the client is trying to get WUs, I clicked pause all, waited a few seconds, clicked Fold All. Now it's downloading and processing a WU. There seems to be an issue with getting the WU when cpu setting at 1 cpu. Maybe. I upped it to 4, it started downloading. I tried backing it down to 1 and it's still working, but settled on 2 cpus. It's running at 104,000ppd
Thanks.
Set it to 3 as a minimum and leave it at that.
CPU:1 will not get you any work
CPU:2 will very very rarely get any work
CPU:3 will get you work
Thanks! Sage advice, musiqaz
What's your rig and temperatures?
I bet! Thanks for the help.
B
B
