after installing Mint on my machine last week, I wanted to rejoin the folding effort, and installed FAH. When I used windows, the GPU was being utilized just fine, but now it is shown as not supported.
Here's the log output:
08:01:54:I1: Version: 8.5.3
08:01:54:I1: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
08:01:54:I1: Org: foldingathome.org
08:01:54:I1: Copyright: 2023-2025, foldingathome.org
08:01:54:I1: Homepage: https://foldingathome.org/
08:01:54:I1: License: GPL-3.0-or-later
08:01:54:I1: URL: https://v8-5.foldingathome.org/
08:01:54:I1: Date: Oct 26 2025
08:01:54:I1: Time: 16:06:17
08:01:54:I1: Revision: d0e84611b66e3c0eb4181eee2919b88e76856d2e
08:01:54:I1: Branch: master
08:01:54:I1: Compiler: GNU 8.3.0
08:01:54:I1: Options: -Wsuggest-override -faligned-new -std=c++17 -fsigned-char -O3 -fPIC
08:01:54:I1: Platform: linux 4.19.0-27-cloud-amd64
08:01:54:I1: Bits: 64
08:01:54:I1: Mode: Release
08:01:54:I1: Args: --config=/etc/fah-client/config.xml
08:01:54:I1: --log=/var/log/fah-client/log.txt
08:01:54:I1: --log-rotate-dir=/var/log/fah-client/
08:01:54:I1: Config: /etc/fah-client/config.xml
08:01:54:I1:****************************** CBang ******************************
08:01:54:I1: Version: 1.7.2
08:01:54:I1: Org: Cauldron Development
08:01:54:I1: Copyright: Cauldron Development, 2003-2025
08:01:54:I1: Homepage: https://cauldrondevelopment.com/
08:01:54:I1: License: LGPL-2.1-or-later
08:01:54:I1: Time: 16:05:59
08:01:54:I1: Revision: c3054d2c63798253549404d5c0bf61df8088d454
08:01:54:I1:***************************** System ******************************
08:01:54:I1: CPU: AMD Ryzen 7 5700X3D 8-Core Processor
08:01:54:I1: CPU ID: AuthenticAMD Family 25 Model 33 Stepping 2
08:01:54:I1: CPUs: 16
08:01:54:I1: Memory: 31.25GiB
08:01:54:I1:Free Memory: 18.88GiB
08:01:54:I1: OS Version: 6.14
08:01:54:I1:Has Battery: false
08:01:54:I1: On Battery: false
08:01:54:I1: Hostname: Gaming-Desktop
08:01:54:I1: UTC Offset: 1
08:01:54:I1: PID: 23425
08:01:54:I1: CWD: /var/lib/fah-client
08:01:54:I1: Exec: /usr/bin/fah-client
08:01:54:I1:*******************************************************************
08:01:54:I2:<config/>
08:01:54:I1:Opening Database
08:01:54:I1:Generating RSA key.............................................................++++-....++++-
08:01:54:I1:F@H ID = ###
08:01:54:I3:Loading default resource group
08:01:54:I2:Listening for HTTP on 127.0.0.1:7396
08:01:54:I3:Loaded 0 wus.
08:01:54:I2:OUT1:> GET /gpus HTTP/1.1
08:01:57:I2:OUT1:< HTTP/1.1 200 HTTP_OK
08:01:57:I3:gpus = {
08:01:57:I3: "gpu:09:00:00": {"vendor": 4098, "device": 29615, "type": "amd", "supported": false, "description": "Navi 21 [Radeon RX 6900 XT]"}
08:01:57:I3:}
08:02:04:I2:REQ2:< GET / HTTP/1.1
08:02:04:I1:REQ2:> HTTP/1.1 307 HTTP_TEMPORARY_REDIRECT
08:02:05:I2:REQ3:< GET /api/websocket HTTP/1.1Code: Select all
System:
Kernel: 6.14.0-35-generic arch: x86_64 bits: 64 compiler: gcc v: 13.3.0 clocksource: tsc
Desktop: Cinnamon v: 6.4.8 tk: GTK v: 3.24.41 wm: Muffin v: 6.4.1 vt: 7 dm: LightDM v: 1.30.0
Distro: Linux Mint 22.2 Zara base: Ubuntu 24.04 noble
Machine:
Type: Desktop System: ASUS product: N/A v: N/A serial: <superuser required>
Mobo: ASUSTeK model: ROG STRIX B550-F GAMING v: Rev X.0x serial: <superuser required>
part-nu: SKU uuid: <superuser required> UEFI: American Megatrends v: 3405 date: 12/13/2023
CPU:
Info: 8-core model: AMD Ryzen 7 5700X3D bits: 64 type: MT MCP smt: enabled arch: Zen 3+ rev: 2
cache: L1: 512 KiB L2: 4 MiB L3: 96 MiB
Speed (MHz): avg: 2982 high: 3850 min/max: 550/4151 boost: enabled cores: 1: 3850 2: 3749
3: 3726 4: 3809 5: 3652 6: 3370 7: 3384 8: 1750 9: 3364 10: 1750 11: 3747 12: 1750 13: 3207
14: 1750 15: 3117 16: 1750 bogomips: 96003
Flags: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3
Graphics:
Device-1: AMD Navi 21 [Radeon RX 6900 XT] vendor: Tul / PowerColor driver: amdgpu v: kernel
arch: RDNA-2 pcie: speed: 16 GT/s lanes: 16 ports: active: DP-1,DP-2 off: DP-3
empty: HDMI-A-1,Writeback-1 bus-ID: 09:00.0 chip-ID: 1002:73af class-ID: 0300
Display: x11 server: X.Org v: 21.1.11 with: Xwayland v: 23.2.6 driver: X: loaded: amdgpu
unloaded: fbdev,modesetting,radeon,vesa dri: radeonsi gpu: amdgpu display-ID: :0 screens: 1
Screen-1: 0 s-res: 4480x1592 s-dpi: 96 s-size: 1185x421mm (46.65x16.57")
s-diag: 1258mm (49.51")
API: EGL v: 1.5 hw: drv: amd radeonsi platforms: device: 0 drv: radeonsi device: 1 drv: swrast
gbm: drv: kms_swrast surfaceless: drv: radeonsi x11: drv: radeonsi inactive: wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 25.0.7-0ubuntu0.24.04.2 glx-v: 1.4
direct-render: yes renderer: AMD Radeon RX 6900 XT (radeonsi navi21 LLVM 20.1.2 DRM 3.61
6.14.0-35-generic) device-ID: 1002:73af
Audio:
Network:
Device-1: Intel Ethernet I225-V vendor: ASUSTeK driver: igc v: kernel pcie: speed: 5 GT/s
lanes: 1 port: N/A bus-ID: 06:00.0 chip-ID: 8086:15f3 class-ID: 0200
IF: enp6s0 state: up speed: 2500 Mbps duplex: full mac: <filter>
Bluetooth:
RAID:
Drives:
Partition:
Swap:
ID-1: swap-1 type: file size: 2 GiB used: 0 KiB (0.0%) priority: -2 file: /swapfile
USB:
Sensors:
System Temperatures: cpu: 38.2 C mobo: N/A gpu: amdgpu temp: 29.0 C mem: 28.0 C
Fan Speeds (rpm): N/A gpu: amdgpu fan: 0
Repos:
Packages: 2305 pm: dpkg pkgs: 2284 pm: flatpak pkgs: 21
No active apt repos in: /etc/apt/sources.list
Active apt repos in: /etc/apt/sources.list.d/alessandro-strada-ppa-noble.list
1: deb [signed-by=/etc/apt/keyrings/alessandro-strada-ppa-noble.gpg] https: //ppa.launchpadcontent.net/alessandro-strada/ppa/ubuntu noble main
Active apt repos in: /etc/apt/sources.list.d/official-package-repositories.list
1: deb https: //ftp-stud.hs-esslingen.de/pub/Mirrors/packages.linuxmint.com zara main upstream import backport
2: deb http: //ftp.uni-mainz.de/ubuntu noble main restricted universe multiverse
3: deb http: //ftp.uni-mainz.de/ubuntu noble-updates main restricted universe multiverse
4: deb http: //ftp.uni-mainz.de/ubuntu noble-backports main restricted universe multiverse
5: deb http: //security.ubuntu.com/ubuntu/ noble-security main restricted universe multiverse
Info:
Memory: total: 32 GiB available: 31.25 GiB used: 5.52 GiB (17.7%)
Processes: 424 Power: uptime: 1h 25m states: freeze,mem,disk suspend: deep wakeups: 0
hibernate: platform Init: systemd v: 255 target: graphical (5) default: graphical
Compilers: gcc: 13.3.0 Client: Cinnamon v: 6.4.8 inxi: 3.3.34
I have tried restarting FAH with
sudo systemctl restart fah-client
