A new Beta release is available v8.5.3 - https://foldingathome.org/beta
Bug reports for the client - https://github.com/FoldingAtHome/fah-cl ... tet/issues
Bug reports for the web control - https://github.com/FoldingAtHome/fah-we ... tet/issues
v8.4 Installation Guide - https://foldingathome.org/v8-4-client-guide/
Some new features may not be covered in the v8.4 Installation Guide, will post a new link if it gets updated.
Change log since previous Beta releases:
v8.5.3
Fix for websocket connection when web-root is enabled. @kbernhagen
Ignore failed core exits when shutting down. #391
Removed browser check in macOS installer. @kbernhagen
Listen to udev events on Linux and rescan when new GPU is added. #394
v8.5.2
Fix unit complete logic, re:#387
Poll for GPU render device instead of canGraphical. #338 @marcosfrm
Search for GPU compute libs under various paths. re:cbang/#181
Support abbreviated IP ranges like '169.254/16'.
Prevent rapid core restart by adding min delay. re:#362
Don't adjust WU CPU counts while a new WU is downloading.
Test cores after download. re:#357
If a GPU is enabled but not yet detected, wait.
Close all sockets in core subprocesses. re:#361
Record correct WU status after restart. re:#352
v8.5.1
Better error handling and size limits for vis file loading. #385 #376
Correct and simplify sd-bus canGraphical detection. #338
Reopen Nameserver connection on write failure to fix macOS issue. #337
v8.5
Small improvements to Windows shutdown handling.
Added option and core parameters for HIP.
v8.4.9
Recommend nvidia-opencl-icd package on Debian install. #293
Attempt graceful shutdown of client in Windows installer. #290
v8.4.8
Delay Windows shutdown until F@H has shutdown gracefully. #290
Fix crashing on Windows. re: #278
Use all DNS servers. #304
v8.4.7
Pause group after 5 consecutive lost WUs. #305
Ensure WU is saved to DB in case shutdown Windows kills the process. #290
v8.4.6
Attempt more graceful shutdown in Windows.
Increase clock skew detection threshold from 15s to 5m.
Fix call to open Web Control URL on startup.
Require polkitd-pkla on Debian.
Handle CORE_RESTART return code correctly.
Fix data dir permissions in Windows.
v8.4.5
Don't allow invalid machine name option. #282
Track WU end state.
Clear WU retry count after WU has run successfully for some time.
Set WU final WU progress correctly.
v8.4.4
Acquire client DB lock on startup. #269
Added fahctl command line client control script. #119
Added package dependency on libexpat. #266
Ignore exit code of killed or crashed cores.
Delay next WU after failure.
Log error if core does not produce any log output.
v8.4.3
Start Linux client after DNS service. (Marcos Mello)
v8.4.2
Fixed DNS bug. #257
Reduced ETA updates.
Prevent negative ETA.
v8.4.1
Log machine and group pause, fold, finish changes.
v8.4.0
Don't add client install path to PATH when running cores on Windows.
Added disable CUDA option.
Added system HTTP proxy support. No config necessary.
Automatically set machine from account settings.
v8.3.18
Windows installer fixes.
v8.3.17
Fixes for account (un)linking and node changes.
Fix for repeated "No active" exception.
Public Beta Release v 8.5.3
Re: Current Public Beta Release v 8.5.3
Note that web control has its own change log.
https://github.com/FoldingAtHome/fah-we ... ANGELOG.md
