Work units dumped when PC shutdown or reboot
Tropical Snowman
Post by Tropical Snowman »
Hello there, I'm on Windows 11 and Folding always dumps work units when pc reboots or shutdown normally. Weirdly enough, if there's a sudden power loss, WUs are not lost and start again from the last checkpoint.
Windows gives me the brief warning "This app is preventing shutdown", showing that Folding would need some more time - I guess.
Exiting or pausing FAH before shutdown avoids the problem altogether, and that's how I've been doing.
I wonder:
  • Is it an expected behaviour?
  • Can I fix it?
Windows 11, Ryzen 7 7700, 32gb DDR5 ram, AMD RX6700.
Here's the log:
11:01:31:I1:WU651:Checkpoint completed at step 350000
11:03:16:E :WU642:Core returned UNKNOWN_ENUM (1073807364)
11:03:16:E :WU642:Core exited with an unknown error code 1073807364 which probably indicates that it crashed. Dumping WU
11:03:16:E :WU651:Core returned UNKNOWN_ENUM (1073807364)
11:03:16:E :WU651:Core exited with an unknown error code 1073807364 which probably indicates that it crashed. Dumping WU
Next log:
*********************** Log Started 2025-10-28T11:04:12Z ***********************
11:04:12:I1:*********************** Folding@home Client ***********************
11:04:12:I1:    Version: 8.4.9
11:04:12:I1:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
11:04:12:I1:        Org: foldingathome.org
11:04:12:I1:  Copyright: 2023-2024, foldingathome.org
11:04:12:I1:   Homepage: https://foldingathome.org/
11:04:12:I1:    License: GPL-3.0-or-later
11:04:12:I1:        URL: https://v8-4.foldingathome.org/
11:04:12:I1:       Date: Nov 20 2024
11:04:12:I1:       Time: 14:47:46
11:04:12:I1:   Revision: 360fe71b1bd05bb89814bfb97b73a5bda84802d6
11:04:12:I1:     Branch: master
11:04:12:I1:   Compiler: Visual C++
11:04:12:I1:    Options: $( /TP $) /std:c++14 /nologo /EHa /wd4297 /wd4103 /O2
11:04:12:I1:             /Zc:throwingNew /MT
11:04:12:I1:   Platform: win32 10
11:04:12:I1:       Bits: 64
11:04:12:I1:       Mode: Release
11:04:12:I1:     Config: C:\ProgramData\FAHClient\config.xml
11:04:12:I1:****************************** CBang ******************************
11:04:12:I1:    Version: 1.7.2
11:04:12:I1:        Org: Cauldron Development
11:04:12:I1:  Copyright: Cauldron Development, 2003-2024
11:04:12:I1:   Homepage: https://cauldrondevelopment.com/
11:04:12:I1:    License: LGPL-2.1-or-later
11:04:12:I1:       Time: 09:04:40
11:04:12:I1:   Revision: 443c54e909eb8d8994405a18fb328b5b05a623a5
11:04:12:I1:***************************** System ******************************
11:04:12:I1:        CPU: AMD Ryzen 7 7700 8-Core Processor
11:04:12:I1:     CPU ID: AuthenticAMD Family 25 Model 97 Stepping 2
11:04:12:I1:       CPUs: 16
11:04:12:I1:     Memory: 31.11GiB
11:04:12:I1:Free Memory: 25.44GiB
11:04:12:I1: OS Version: 6.2
11:04:12:I1:Has Battery: false
11:04:12:I1: On Battery: false
11:04:12:I1:   Hostname: DESKTOP-FQSDIPN
11:04:12:I1: UTC Offset: 1
11:04:12:I1:        PID: 14800
11:04:12:I1:        CWD: C:\ProgramData\FAHClient
11:04:12:I1:       Exec: C:\Program Files\FAHClient\FAHClient.exe
11:04:12:I1:*******************************************************************
11:04:12:I2:<config>
11:04:12:I2:  <!-- Resource Settings -->
11:04:12:I2:  <cpus v='12'/>
11:04:12:I2:</config>
11:04:12:I1:Opening Database
11:04:12:I1:F@H ID = n6pyMf_OevKnMWzGu-TKYiRXwMtHX6KUw8UZC8Z7h4c
11:04:12:I3:Loading default resource group
11:04:12:I3:Loading GPU resource group
11:04:12:I1:Listening for HTTP on 127.0.0.1:7396
11:04:12:I3:WU651:Loading work unit 651 with ID MIKBCFvANVFofpDnhLgwxU7pnSffqdmjgOGcaYOhs6k
11:04:12:I3:WU642:Loading work unit 642 with ID fHS35O-8ev5SQDX1AzxvY_riXK7IEAchTwLGwb-kWSE
11:04:12:I3:Loaded 2 wus.
11:04:12:I1:Started Windows systray control
11:04:12:I3:gpus = {
11:04:12:I3:  "gpu:03:00:00": {
11:04:12:I3:    "vendor": 4098,
11:04:12:I3:    "type": "amd",
11:04:12:I3:    "description": "gfx1031",
11:04:12:I3:    "opencl": {"platform": 0, "device": 1, "compute": "2.0", "driver": "3652.0"},
11:04:12:I3:    "device": 29663,
11:04:12:I3:    "supported": true
11:04:12:I3:  },
11:04:12:I3:  "gpu:18:00:00": {
11:04:12:I3:    "description": "gfx1036",
11:04:12:I3:    "opencl": {"platform": 0, "device": 0, "compute": "2.0", "driver": "3652.0"},
11:04:12:I3:    "device": 5710,
11:04:12:I3:  }
11:04:12:I3:}
11:04:12:I1:Default:Added new work unit: cpus:15 gpus:
11:04:12:I1:GPU:Added new work unit: cpus:0 gpus:gpu:03:00:00
11:04:12:I1:WU642:Sending dump report
11:04:12:I1:WU653:Requesting WU assignment for user acwvfqvlj2ui4vcpalbdq5trcfsdtnqpwu5ypuip63uueh4zkvt2h34augfii team 1066107
11:04:12:I1:WU652:Requesting WU assignment for user acwvfqvlj2ui4vcpalbdq5trcfsdtnqpwu5ypuip63uueh4zkvt2h34augfii team 1066107
11:04:12:I1:WU651:Sending dump report
11:04:12:I1:OUT1:> GET https://api.foldingathome.org/machine/n6pyMf_OevKnMWzGu-TKYiRXwMtHX6KUw8UZC8Z7h4c HTTP/1.1
11:04:12:E :OUT1:Failed response: EOF
11:04:12:I1:OUT3:> POST https://assign1.foldingathome.org/api/assign HTTP/1.1
11:04:12:E :OUT3:Failed response: EOF
11:04:12:I1:WU653:Retry #1 in 2 secs
11:04:12:I1:OUT4:> POST https://assign2.foldingathome.org/api/assign HTTP/1.1
11:04:12:E :OUT4:Failed response: EOF
11:04:12:I1:WU652:Retry #1 in 2 secs
11:04:12:I1:OUT5:> POST https://highland4.seas.upenn.edu/api/results HTTP/1.1
11:04:12:E :OUT5:Failed response: EOF
11:04:12:I1:WU651:Retry #1 in 2 secs
11:04:12:I1:OUT2:> POST https://vav23.fah.temple.edu/api/results HTTP/1.1
11:04:12:E :OUT2:Failed response: EOF
11:04:12:I1:WU642:Retry #1 in 2 secs
11:04:14:I1:WU653:Requesting WU assignment for user acwvfqvlj2ui4vcpalbdq5trcfsdtnqpwu5ypuip63uueh4zkvt2h34augfii team 1066107
11:04:14:I1:WU652:Requesting WU assignment for user acwvfqvlj2ui4vcpalbdq5trcfsdtnqpwu5ypuip63uueh4zkvt2h34augfii team 1066107
11:04:14:I1:WU651:Sending dump report
11:04:14:I1:OUT8:> POST https://highland4.seas.upenn.edu/api/results HTTP/1.1
11:04:14:E :OUT8:Failed response: EOF
11:04:14:I1:WU651:Retry #2 in 4 secs
11:04:14:I1:OUT7:> POST https://assign4.foldingathome.org/api/assign HTTP/1.1
11:04:14:E :OUT7:Failed response: EOF
11:04:14:I1:WU652:Retry #2 in 4 secs
11:04:14:I1:OUT6:> POST https://assign3.foldingathome.org/api/assign HTTP/1.1
11:04:14:E :OUT6:Failed response: EOF
11:04:14:I1:WU653:Retry #2 in 4 secs
11:04:14:I1:WU642:Sending dump report
11:04:14:I1:OUT9:> POST https://vav23.fah.temple.edu/api/results HTTP/1.1
11:04:14:E :OUT9:Failed response: EOF
11:04:14:I1:WU642:Retry #2 in 4 secs
11:04:18:I1:WU651:Sending dump report
11:04:18:I1:WU653:Requesting WU assignment for user acwvfqvlj2ui4vcpalbdq5trcfsdtnqpwu5ypuip63uueh4zkvt2h34augfii team 1066107
11:04:18:I1:WU652:Requesting WU assignment for user acwvfqvlj2ui4vcpalbdq5trcfsdtnqpwu5ypuip63uueh4zkvt2h34augfii team 1066107
11:04:18:I1:OUT10:> POST https://highland4.seas.upenn.edu/api/results HTTP/1.1
11:04:18:E :OUT10:Failed response: EOF
11:04:18:I1:WU651:Retry #3 in 8 secs
11:04:18:I1:OUT11:> POST https://assign5.foldingathome.org/api/assign HTTP/1.1
11:04:18:E :OUT11:Failed response: EOF
11:04:18:I1:WU653:Retry #3 in 8 secs
11:04:18:I1:OUT12:> POST https://assign6.foldingathome.org/api/assign HTTP/1.1
11:04:18:E :OUT12:Failed response: EOF
11:04:18:I1:WU652:Retry #3 in 8 secs
11:04:18:I1:WU642:Sending dump report
11:04:18:I1:OUT13:> POST https://vav23.fah.temple.edu/api/results HTTP/1.1
11:04:18:E :OUT13:Failed response: EOF
11:04:18:I1:WU642:Retry #3 in 8 secs
11:04:26:I1:WU651:Sending dump report
11:04:26:I1:WU652:Requesting WU assignment for user acwvfqvlj2ui4vcpalbdq5trcfsdtnqpwu5ypuip63uueh4zkvt2h34augfii team 1066107
11:04:26:I1:WU653:Requesting WU assignment for user acwvfqvlj2ui4vcpalbdq5trcfsdtnqpwu5ypuip63uueh4zkvt2h34augfii team 1066107
11:04:26:I1:WU642:Sending dump report
11:04:26:I1:OUT14:> POST https://highland4.seas.upenn.edu/api/results HTTP/1.1
11:04:26:I1:OUT15:> POST https://assign1.foldingathome.org/api/assign HTTP/1.1
11:04:26:I1:OUT16:> POST https://assign2.foldingathome.org/api/assign HTTP/1.1
11:04:26:I1:OUT17:> POST https://vav23.fah.temple.edu/api/results HTTP/1.1
11:04:27:I1:OUT15:< HTTP/1.1 200 HTTP_OK
11:04:27:I1:WU652:Received WU assignment TgZqbnTZ6DgP8j-yNqIEVWeo0OsX_ZNvj72w7Despwg
11:04:27:I1:WU652:Downloading WU
11:04:27:I1:OUT16:< HTTP/1.1 200 HTTP_OK
11:04:27:I1:WU653:Received WU assignment zCIbSKKNOtTIwJC_grpXUvMefgC2C5rqgIi4TLIy7tE
11:04:27:I1:WU653:Downloading WU
11:04:27:I1:OUT19:> GET https://api.foldingathome.org/machine/n6pyMf_OevKnMWzGu-TKYiRXwMtHX6KUw8UZC8Z7h4c HTTP/1.1
11:04:27:I1:OUT17:< HTTP/1.1 200 HTTP_OK
11:04:27:I1:WU642:Dumped
11:04:27:I1:OUT18:> POST https://ds01.scs.illinois.edu/api/assign HTTP/1.1
11:04:27:I1:OUT20:> POST https://highland1.seas.upenn.edu/api/assign HTTP/1.1
11:04:28:I1:OUT19:< HTTP/1.1 200 HTTP_OK
11:04:28:I1:OUT21:> GET wss://node1.foldingathome.org/ws/client HTTP/1.1
11:04:29:I1:OUT21:< HTTP/1.1 101 HTTP_SWITCHING_PROTOCOLS
11:04:29:I1:Logging into node account
11:04:47:I1:OUT18:< HTTP/1.1 200 HTTP_OK
11:04:47:I1:WU652:Received WU P19227 R9909 C8 G4
11:04:47:I1:Loaded cores/fahcore-a8-win-64bit-avx2_256-0.0.12/FahCore_a8.exe
11:04:47:I3:Running FahCore: C:\ProgramData\FAHClient\cores/fahcore-a8-win-64bit-avx2_256-0.0.12/FahCore_a8.exe -dir TgZqbnTZ6DgP8j-yNqIEVWeo0OsX_ZNvj72w7Despwg -suffix 01 -version 8.4.9 -lifeline 14800 -np 15
11:04:47:I3:WU652:Started FahCore on PID 9976
11:04:47:I1:WU652:*********************** Log Started 2025-10-28T11:04:47Z ***********************
11:04:47:I1:WU652:************************** Gromacs Folding@home Core ***************************
Thank you for you attention.
Re: Work units dumped when PC shutdown or reboot
Post by muziqaz »
Yes, this is a bug, and it has been fixed in the latest alpha.
Before that, it is advised to pause before rebooting the system.
Linux client doesn't have this issue.
FAH Omega tester
Tropical Snowman
Okay, thanks. I'll go on pausing before shutting down. Thanks.
