Completed WU Stuck on Sending
geokilla
Hardware configuration: Intel Core i5-10600KF @ 4.9Ghz @ 1.25V
MSI Z490 Gaming Edge Wi-Fi BIOS v17
XPG D50 32GB DDR4-3200 16-19-9-36 2T (Samsung M-Die)
XPG S11 Pro 1TB and Western Digital WD140EDFZ 14TB
EVGA RTX 3060 XC
Corsair RM650x
Phantek P360A with Noctua Exhaust Fans
Post by geokilla »
My GPU finished this WU yesterday and it's still stuck on sending. This is for WU 12129 (26, 79, 13). Log is as follows:
*********************** Log Started 2025-10-02T13:22:03Z ***********************
13:22:03:WU01:FS01:Sending unit results: id:01 state:SEND error:NO_ERROR project:12129 run:26 clone:79 gen:13 core:0x24 unit:0x0d0000004f0000001a000000612f0000
13:22:03:WU01:FS01:Uploading 250.72MiB to 128.174.73.74
13:22:03:WU01:FS01:Connecting to 128.174.73.74:8080
13:22:24:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
13:22:24:WU01:FS01:Connecting to 128.174.73.74:80
13:22:46:WARNING:WU01:FS01:Exception: Failed to send results to work server: Failed to connect to 128.174.73.74:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
13:22:46:WU01:FS01:Trying to send results to collection server
13:22:46:WU01:FS01:Uploading 250.72MiB to 129.32.209.207
13:22:46:WU01:FS01:Connecting to 129.32.209.207:8080
13:22:46:ERROR:WU01:FS01:Exception: Transfer failed
13:22:46:WU01:FS01:Sending unit results: id:01 state:SEND error:NO_ERROR project:12129 run:26 clone:79 gen:13 core:0x24 unit:0x0d0000004f0000001a000000612f0000
13:22:46:WU01:FS01:Uploading 250.72MiB to 128.174.73.74
13:22:46:WU01:FS01:Connecting to 128.174.73.74:8080
13:23:07:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
13:23:07:WU01:FS01:Connecting to 128.174.73.74:80
13:23:29:WARNING:WU01:FS01:Exception: Failed to send results to work server: Failed to connect to 128.174.73.74:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
13:23:29:WU01:FS01:Trying to send results to collection server
13:23:29:WU01:FS01:Uploading 250.72MiB to 129.32.209.207
13:23:29:WU01:FS01:Connecting to 129.32.209.207:8080
13:23:29:ERROR:WU01:FS01:Exception: Transfer failed
13:23:46:WU01:FS01:Sending unit results: id:01 state:SEND error:NO_ERROR project:12129 run:26 clone:79 gen:13 core:0x24 unit:0x0d0000004f0000001a000000612f0000
13:23:46:WU01:FS01:Uploading 250.72MiB to 128.174.73.74
13:23:46:WU01:FS01:Connecting to 128.174.73.74:8080
13:24:08:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
13:24:08:WU01:FS01:Connecting to 128.174.73.74:80
13:24:29:WARNING:WU01:FS01:Exception: Failed to send results to work server: Failed to connect to 128.174.73.74:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
13:24:29:WU01:FS01:Trying to send results to collection server
13:24:29:WU01:FS01:Uploading 250.72MiB to 129.32.209.207
13:24:29:WU01:FS01:Connecting to 129.32.209.207:8080
13:24:29:ERROR:WU01:FS01:Exception: Transfer failed
13:25:24:WU01:FS01:Sending unit results: id:01 state:SEND error:NO_ERROR project:12129 run:26 clone:79 gen:13 core:0x24 unit:0x0d0000004f0000001a000000612f0000
13:25:24:WU01:FS01:Uploading 250.72MiB to 128.174.73.74
13:25:24:WU01:FS01:Connecting to 128.174.73.74:8080
13:25:45:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
13:25:45:WU01:FS01:Connecting to 128.174.73.74:80
13:25:48:WU01:FS01:Upload 0.02%
13:26:18:WU01:FS01:Upload 0.07%
13:26:18:WARNING:WU01:FS01:Exception: Failed to send results to work server: Transfer failed
13:26:18:WU01:FS01:Trying to send results to collection server
13:26:18:WU01:FS01:Uploading 250.72MiB to 129.32.209.207
13:26:18:WU01:FS01:Connecting to 129.32.209.207:8080
13:26:18:ERROR:WU01:FS01:Exception: Transfer failed
13:28:01:WU01:FS01:Sending unit results: id:01 state:SEND error:NO_ERROR project:12129 run:26 clone:79 gen:13 core:0x24 unit:0x0d0000004f0000001a000000612f0000
13:28:01:WU01:FS01:Uploading 250.72MiB to 128.174.73.74
13:28:01:WU01:FS01:Connecting to 128.174.73.74:8080
13:28:22:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
13:28:22:WU01:FS01:Connecting to 128.174.73.74:80
13:28:43:WARNING:WU01:FS01:Exception: Failed to send results to work server: Failed to connect to 128.174.73.74:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
13:28:43:WU01:FS01:Trying to send results to collection server
13:28:43:WU01:FS01:Uploading 250.72MiB to 129.32.209.207
13:28:43:WU01:FS01:Connecting to 129.32.209.207:8080
13:28:43:ERROR:WU01:FS01:Exception: Transfer failed
13:32:15:WU01:FS01:Sending unit results: id:01 state:SEND error:NO_ERROR project:12129 run:26 clone:79 gen:13 core:0x24 unit:0x0d0000004f0000001a000000612f0000
13:32:15:WU01:FS01:Uploading 250.72MiB to 128.174.73.74
13:32:15:WU01:FS01:Connecting to 128.174.73.74:8080
13:32:36:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
13:32:36:WU01:FS01:Connecting to 128.174.73.74:80
13:32:57:WARNING:WU01:FS01:Exception: Failed to send results to work server: Failed to connect to 128.174.73.74:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
13:32:57:WU01:FS01:Trying to send results to collection server
13:32:57:WU01:FS01:Uploading 250.72MiB to 129.32.209.207
13:32:57:WU01:FS01:Connecting to 129.32.209.207:8080
13:32:58:ERROR:WU01:FS01:Exception: Transfer failed
13:39:07:WU01:FS01:Sending unit results: id:01 state:SEND error:NO_ERROR project:12129 run:26 clone:79 gen:13 core:0x24 unit:0x0d0000004f0000001a000000612f0000
13:39:07:WU01:FS01:Uploading 250.72MiB to 128.174.73.74
13:39:07:WU01:FS01:Connecting to 128.174.73.74:8080
13:39:28:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
13:39:28:WU01:FS01:Connecting to 128.174.73.74:80
13:39:49:WARNING:WU01:FS01:Exception: Failed to send results to work server: Failed to connect to 128.174.73.74:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
13:39:49:WU01:FS01:Trying to send results to collection server
13:39:49:WU01:FS01:Uploading 250.72MiB to 129.32.209.207
13:39:49:WU01:FS01:Connecting to 129.32.209.207:8080
13:39:49:ERROR:WU01:FS01:Exception: Transfer failed
13:50:12:WU01:FS01:Sending unit results: id:01 state:SEND error:NO_ERROR project:12129 run:26 clone:79 gen:13 core:0x24 unit:0x0d0000004f0000001a000000612f0000
13:50:12:WU01:FS01:Uploading 250.72MiB to 128.174.73.74
13:50:12:WU01:FS01:Connecting to 128.174.73.74:8080
13:50:42:WU01:FS01:Upload 0.07%
13:50:42:WARNING:WU01:FS01:Exception: Failed to send results to work server: Transfer failed
13:50:42:WU01:FS01:Trying to send results to collection server
13:50:42:WU01:FS01:Uploading 250.72MiB to 129.32.209.207
13:50:42:WU01:FS01:Connecting to 129.32.209.207:8080
13:50:43:ERROR:WU01:FS01:Exception: Transfer failed
14:08:09:WU01:FS01:Sending unit results: id:01 state:SEND error:NO_ERROR project:12129 run:26 clone:79 gen:13 core:0x24 unit:0x0d0000004f0000001a000000612f0000
14:08:09:WU01:FS01:Uploading 250.72MiB to 128.174.73.74
14:08:09:WU01:FS01:Connecting to 128.174.73.74:8080
14:08:30:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
14:08:30:WU01:FS01:Connecting to 128.174.73.74:80
14:08:51:WARNING:WU01:FS01:Exception: Failed to send results to work server: Failed to connect to 128.174.73.74:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
14:08:51:WU01:FS01:Trying to send results to collection server
14:08:51:WU01:FS01:Uploading 250.72MiB to 129.32.209.207
14:08:51:WU01:FS01:Connecting to 129.32.209.207:8080
14:08:51:ERROR:WU01:FS01:Exception: Transfer failed
14:37:11:WU01:FS01:Sending unit results: id:01 state:SEND error:NO_ERROR project:12129 run:26 clone:79 gen:13 core:0x24 unit:0x0d0000004f0000001a000000612f0000
14:37:11:WU01:FS01:Uploading 250.72MiB to 128.174.73.74
14:37:11:WU01:FS01:Connecting to 128.174.73.74:8080
14:37:41:WU01:FS01:Upload 0.07%
14:37:41:WARNING:WU01:FS01:Exception: Failed to send results to work server: Transfer failed
14:37:41:WU01:FS01:Trying to send results to collection server
14:37:41:WU01:FS01:Uploading 250.72MiB to 129.32.209.207
14:37:41:WU01:FS01:Connecting to 129.32.209.207:8080
14:37:42:ERROR:WU01:FS01:Exception: Transfer failed
15:24:10:WU01:FS01:Sending unit results: id:01 state:SEND error:NO_ERROR project:12129 run:26 clone:79 gen:13 core:0x24 unit:0x0d0000004f0000001a000000612f0000
15:24:10:WU01:FS01:Uploading 250.72MiB to 128.174.73.74
15:24:10:WU01:FS01:Connecting to 128.174.73.74:8080
15:24:40:WU01:FS01:Upload 0.07%
15:24:40:WARNING:WU01:FS01:Exception: Failed to send results to work server: Transfer failed
15:24:40:WU01:FS01:Trying to send results to collection server
15:24:40:WU01:FS01:Uploading 250.72MiB to 129.32.209.207
15:24:40:WU01:FS01:Connecting to 129.32.209.207:8080
15:24:40:ERROR:WU01:FS01:Exception: Transfer failed
All my other completed WU are sending normally.
ASUS TUF RTX 3070 OC
Corsair RM650x
Re: Completed WU Stuck on Sending
Post by muziqaz »
Servers have been broken for past several days. Some are still broken
FAH Omega tester
geokilla
EVGA RTX 3060 XC
Corsair RM650x
Post by geokilla »
muziqaz wrote: Thu Oct 02, 2025 3:50 pm Servers have been broken for past several days. Some are still broken
Not possible to send it to another server? At this rate, it's going to expire.
Corsair RM650x
Post by muziqaz »
geokilla wrote: Thu Oct 02, 2025 10:27 pm
If it was possible, it would have been sent by now
FAH Omega tester
Collection Servers are defined for the WU at the time it is created and downloaded by a client. So if they aren't defined or are not working they can't be added later for an upload.
In your case the log clearly shows the WU first attempting to be uploaded to the WS, 128.174.73.74, then to a CS, 129.32.209.207.
The WU has uploaded at some point, there is a credit report in the stats database:
Hi geokilla (team 54196), Your WU (P12129 R26 C79 G13) was added to the stats database on Thu, 02 Oct 2025 04:54:58 GMT for 643005 points of credit.
geokilla
EVGA RTX 3060 XC
Corsair RM650x
Post by geokilla »
Joe_H wrote: Thu Oct 02, 2025 10:36 pmThe WU has uploaded at some point, there is a credit report in the stats database:
That's interesting. Wonder why it's still sitting on my computer as attempting to send then.
Corsair RM650x
The ACK that the WU was received may have been dropped. It could have happened anywhere between the server and your client. ACK packets for HTTP and HTTPS connections are sometimes deprioritized by routers. In a browser you might just reload a page that didn't fully load for example. The client just tries to upload again until it gets an ACK, occasionally you will see where on a later upload the message back would be that it had already been uploaded before.
