WU stuck on "Shutting Down" after pc restart
Chamomile
Hardware configuration: CPU: Intel Core i5-6600K
GPU: Inno3D NVIDIA GeForce GTX 1060 6Gb
Post by Chamomile »
Hello, :)
Yesterday, after installing F@H after a long time, I started some WUs and then restarted my computer and I didn't think of pausing the folding process before doing so.
After restarting the pc, I started F@H and clicked on "Fold All", and new WUs were started on both CPU and GPU, with the old ones remaining stuck on "Shutting Down" as a status. Useless to say that I wasn't able to reset the status and make the WUs "workable" anymore. :(
Did anyone have the same issue, and how did you solve it?
OS: Windows 11 Pro 23H2 Build 22635.2841
F@H Version: 8.4.9
Logs:
*********************** Log Started 2025-09-06T17:00:42Z ***********************
17:00:42:I1:*********************** Folding@home Client ***********************
17:00:42:I1:    Version: 8.4.9
17:00:42:I1:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
17:00:42:I1:        Org: foldingathome.org
17:00:42:I1:  Copyright: 2023-2024, foldingathome.org
17:00:42:I1:   Homepage: https://foldingathome.org/
17:00:42:I1:    License: GPL-3.0-or-later
17:00:42:I1:        URL: https://v8-4.foldingathome.org/
17:00:42:I1:       Date: Nov 20 2024
17:00:42:I1:       Time: 14:47:46
17:00:42:I1:   Revision: 360fe71b1bd05bb89814bfb97b73a5bda84802d6
17:00:42:I1:     Branch: master
17:00:42:I1:   Compiler: Visual C++
17:00:42:I1:    Options: $( /TP $) /std:c++14 /nologo /EHa /wd4297 /wd4103 /O2
17:00:42:I1:             /Zc:throwingNew /MT
17:00:42:I1:   Platform: win32 10
17:00:42:I1:       Bits: 64
17:00:42:I1:       Mode: Release
17:00:42:I1:       Args: --open-web-control
17:00:42:I1:****************************** CBang ******************************
17:00:42:I1:    Version: 1.7.2
17:00:42:I1:        Org: Cauldron Development
17:00:42:I1:  Copyright: Cauldron Development, 2003-2024
17:00:42:I1:   Homepage: https://cauldrondevelopment.com/
17:00:42:I1:    License: LGPL-2.1-or-later
17:00:42:I1:       Time: 09:04:40
17:00:42:I1:   Revision: 443c54e909eb8d8994405a18fb328b5b05a623a5
17:00:42:I1:***************************** System ******************************
17:00:42:I1:        CPU: Intel(R) Core(TM) i5-6600K CPU @ 3.50GHz
17:00:42:I1:     CPU ID: GenuineIntel Family 6 Model 94 Stepping 3
17:00:42:I1:       CPUs: 4
17:00:42:I1:     Memory: 15.96GiB
17:00:42:I1:Free Memory: 8.74GiB
17:00:42:I1: OS Version: 6.2
17:00:42:I1:Has Battery: false
17:00:42:I1: On Battery: false
17:00:42:I1:   Hostname: [REDACTED]
17:00:42:I1: UTC Offset: 2
17:00:42:I1:        PID: 12324
17:00:42:I1:        CWD: C:\ProgramData\FAHClient
17:00:42:I1:       Exec: F:\Program Files\FAHClient\FAHClient.exe
17:00:42:I1:*******************************************************************
17:00:42:I2:<config/>
17:00:42:I1:Opening Database
17:00:42:I1:Generating RSA key......................++++-.....................++++-
17:00:43:I1:F@H ID = eugjPDff8FaGS_c0D6Gl7UuglzK-WZhOUgAWe4NeQyo
17:00:43:I3:Loading default resource group
17:00:43:I1:Listening for HTTP on 127.0.0.1:7396
17:00:43:I3:Loaded 0 wus.
17:00:43:I1:Started Windows systray control
17:00:43:I1:OUT1:> GET https://api.foldingathome.org/gpus HTTP/1.1
17:00:44:I1:OUT1:< HTTP/1.1 200 HTTP_OK
17:00:44:I3:gpus = {
17:00:44:I3:  "gpu:03:00:00": {
17:00:44:I3:    "vendor": 4318,
17:00:44:I3:    "type": "nvidia",
17:00:44:I3:    "description": "NVIDIA GeForce GTX 1060 6GB",
17:00:44:I3:    "uuid": "c23eb846-5331-7fb1-3992-1c44bbddefb1",
17:00:44:I3:    "opencl": {"platform": 0, "device": 0, "compute": "3.0", "driver": "580.97"},
17:00:44:I3:    "cuda": {"platform": 0, "device": 0, "compute": "6.1", "driver": "13.0"},
17:00:44:I3:    "device": 7171,
17:00:44:I3:    "supported": true
17:00:44:I3:  }
17:00:44:I3:}
17:15:07:I1:OUT3:> PUT https://api.foldingathome.org/machine/eugjPDff8FaGS_c0D6Gl7UuglzK-WZhOUgAWe4NeQyo HTTP/1.1
17:15:08:I1:OUT3:< HTTP/1.1 200 HTTP_OK
17:15:08:I1:Account linked
17:15:08:I1:OUT4:> GET https://api.foldingathome.org/machine/eugjPDff8FaGS_c0D6Gl7UuglzK-WZhOUgAWe4NeQyo HTTP/1.1
17:15:08:I1:OUT4:< HTTP/1.1 200 HTTP_OK
17:15:09:I1:OUT5:> GET wss://node1.foldingathome.org/ws/client HTTP/1.1
17:15:09:I1:OUT5:< HTTP/1.1 101 HTTP_SWITCHING_PROTOCOLS
17:15:09:I1:Logging into node account
17:16:48:I1:Machine state fold
17:16:48:I1:Default:Added new work unit: cpus:3 gpus:
17:16:48:I1:WU1:Requesting WU assignment for user Chamomile team 1067061
17:16:48:I1:OUT6:> POST https://assign1.foldingathome.org/api/assign HTTP/1.1
17:16:48:I1:OUT6:< HTTP/1.1 200 HTTP_OK
17:16:48:I1:WU1:Received WU assignment TaVhzuljzgqFDcoma5hqFI0vtTNbpeD7DAn_eoqxPEo
17:16:48:I1:WU1:Downloading WU
17:16:49:I1:OUT7:> POST https://vav22.fah.temple.edu/api/assign HTTP/1.1
17:16:50:I1:OUT7:< HTTP/1.1 200 HTTP_OK
17:16:50:I1:WU1:Received WU P16959 R15 C71 G475
17:16:50:I1:Downloading https://cores2.foldingathome.org/fahcore-a8-win-64bit-avx2_256-0.0.12.tar.bz2.crt
17:16:50:I1:OUT8:> GET https://cores2.foldingathome.org/fahcore-a8-win-64bit-avx2_256-0.0.12.tar.bz2.crt HTTP/1.1
17:16:51:I1:OUT8:< HTTP/1.1 200 OK
17:16:51:I1:Downloading https://cores2.foldingathome.org/fahcore-a8-win-64bit-avx2_256-0.0.12.tar.bz2.sig
17:16:51:I1:OUT9:> GET https://cores2.foldingathome.org/fahcore-a8-win-64bit-avx2_256-0.0.12.tar.bz2.sig HTTP/1.1
17:16:51:I1:OUT9:< HTTP/1.1 200 OK
17:16:51:I1:OUT10:> GET https://cores2.foldingathome.org/fahcore-a8-win-64bit-avx2_256-0.0.12.tar.bz2 HTTP/1.1
17:16:54:I1:OUT10:< HTTP/1.1 200 OK
17:16:54:I1:Core signature valid
17:16:54:I1:Extracting cores/fahcore-a8-win-64bit-avx2_256-0.0.12/libfftw3f-3.dll
17:16:54:I1:Extracting cores/fahcore-a8-win-64bit-avx2_256-0.0.12/FahCore_a8
17:16:54:I1:Extracting cores/fahcore-a8-win-64bit-avx2_256-0.0.12/vcomp140.dll
17:16:54:I3:Running FahCore: C:\ProgramData\FAHClient\cores/fahcore-a8-win-64bit-avx2_256-0.0.12/FahCore_a8.exe -dir TaVhzuljzgqFDcoma5hqFI0vtTNbpeD7DAn_eoqxPEo -suffix 01 -version 8.4.9 -lifeline 12324 -np 3
17:16:55:I3:WU1:Started FahCore on PID 17028
17:16:55:I1:WU1:*********************** Log Started 2025-09-06T17:16:55Z ***********************
17:16:55:I1:WU1:************************** Gromacs Folding@home Core ***************************
17:16:55:I1:WU1:       Core: Gromacs
17:16:55:I1:WU1:       Type: 0xa8
17:16:55:I1:WU1:    Version: 0.0.12
17:16:55:I1:WU1:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
17:16:55:I1:WU1:  Copyright: 2020 foldingathome.org
17:16:55:I1:WU1:   Homepage: https://foldingathome.org/
17:16:55:I1:WU1:       Date: Jan 16 2021
17:16:55:I1:WU1:       Time: 12:29:40
17:16:55:I1:WU1:   Revision: c5816759c404e4b65f9f364c3d1ef554a67c4225
17:16:55:I1:WU1:     Branch: master
17:16:55:I1:WU1:   Compiler: Visual C++ 2019 16.7
17:16:55:I1:WU1:    Options: /TP /std:c++14 /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
17:16:55:I1:WU1:   Platform: win32 10
17:16:55:I1:WU1:       Bits: 64
17:16:55:I1:WU1:       Mode: Release
17:16:55:I1:WU1:       SIMD: avx2_256
17:16:55:I1:WU1:     OpenMP: ON
17:16:55:I1:WU1:       CUDA: OFF
17:16:55:I1:WU1:       Args: -dir TaVhzuljzgqFDcoma5hqFI0vtTNbpeD7DAn_eoqxPEo -suffix 01
17:16:55:I1:WU1:             -version 8.4.9 -lifeline 12324 -np 3
17:16:55:I1:WU1:************************************ libFAH ************************************
17:16:55:I1:WU1:       Time: 11:24:13
17:16:55:I1:WU1:************************************ CBang *************************************
17:16:55:I1:WU1:       Time: 11:23:53
17:16:55:I1:WU1:************************************ System ************************************
17:16:55:I1:WU1:        CPU: Intel(R) Core(TM) i5-6600K CPU @ 3.50GHz
17:16:55:I1:WU1:     CPU ID: GenuineIntel Family 6 Model 94 Stepping 3
17:16:55:I1:WU1:       CPUs: 4
17:16:55:I1:WU1:     Memory: 15.96GiB
17:16:55:I1:WU1:Free Memory: 8.09GiB
17:16:55:I1:WU1:    Threads: WINDOWS_THREADS
17:16:55:I1:WU1: OS Version: 6.2
17:16:55:I1:WU1:Has Battery: false
17:16:55:I1:WU1: On Battery: false
17:16:55:I1:WU1: UTC Offset: 2
17:16:55:I1:WU1:        PID: 17028
17:16:55:I1:WU1:        CWD: C:\ProgramData\FAHClient\work
17:16:55:I1:WU1:********************************************************************************
17:16:55:I1:WU1:Project: 16959 (Run 15, Clone 71, Gen 475)
17:16:55:I1:WU1:Unit: 0x00000000000000000000000000000000
17:16:55:I1:WU1:Reading tar file core.xml
17:16:55:I1:WU1:Reading tar file frame475.tpr
17:16:55:I1:WU1:Digital signatures verified
17:16:55:I1:WU1:Calling: mdrun -c frame475.gro -s frame475.tpr -x frame475.xtc -cpt 5 -nt 3 -ntmpi 1
17:16:55:I1:WU1:Steps: first=1187500000 total=1190000000
17:16:55:I1:WU1:Completed 1 out of 2500000 steps (0%)
17:21:36:I1:Default:Added new work unit: cpus:0 gpus:gpu:03:00:00
17:21:36:I1:WU2:Requesting WU assignment for user Chamomile team 1067061
17:21:36:I1:OUT12:> POST https://assign2.foldingathome.org/api/assign HTTP/1.1
17:21:37:I1:OUT12:< HTTP/1.1 200 HTTP_OK
17:21:37:I1:WU2:Received WU assignment nymc7H4XeoNrSJgQU2Z8Tf7DK0nxLaFIvHr3q-0cJvk
17:21:37:I1:WU2:Downloading WU
17:21:37:I1:WU1:WARNING:Console control signal 1 on PID 17028
17:21:37:I1:WU1:Exiting, please wait. . .
17:21:37:I1:OUT13:> POST https://ds01.scs.illinois.edu/api/assign HTTP/1.1
17:21:38:I1:WU1:Core returned INTERRUPTED (102)
17:21:38:I3:Running FahCore: C:\ProgramData\FAHClient\cores/fahcore-a8-win-64bit-avx2_256-0.0.12/FahCore_a8.exe -dir TaVhzuljzgqFDcoma5hqFI0vtTNbpeD7DAn_eoqxPEo -suffix 01 -version 8.4.9 -lifeline 12324 -np 2
17:21:38:I3:WU1:Started FahCore on PID 19412
17:21:38:I1:WU1:*********************** Log Started 2025-09-06T17:21:38Z ***********************
17:21:38:I1:WU1:************************** Gromacs Folding@home Core ***************************
17:21:38:I1:WU1:       Core: Gromacs
17:21:38:I1:WU1:       Type: 0xa8
17:21:38:I1:WU1:    Version: 0.0.12
17:21:38:I1:WU1:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
17:21:38:I1:WU1:  Copyright: 2020 foldingathome.org
17:21:38:I1:WU1:   Homepage: https://foldingathome.org/
17:21:38:I1:WU1:       Date: Jan 16 2021
17:21:38:I1:WU1:       Time: 12:29:40
17:21:38:I1:WU1:   Revision: c5816759c404e4b65f9f364c3d1ef554a67c4225
17:21:38:I1:WU1:     Branch: master
17:21:38:I1:WU1:   Compiler: Visual C++ 2019 16.7
17:21:38:I1:WU1:    Options: /TP /std:c++14 /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
17:21:38:I1:WU1:   Platform: win32 10
17:21:38:I1:WU1:       Bits: 64
17:21:38:I1:WU1:       Mode: Release
17:21:38:I1:WU1:       SIMD: avx2_256
17:21:38:I1:WU1:     OpenMP: ON
17:21:38:I1:WU1:       CUDA: OFF
17:21:38:I1:WU1:       Args: -dir TaVhzuljzgqFDcoma5hqFI0vtTNbpeD7DAn_eoqxPEo -suffix 01
17:21:38:I1:WU1:             -version 8.4.9 -lifeline 12324 -np 2
17:21:38:I1:WU1:************************************ libFAH ************************************
17:21:38:I1:WU1:       Time: 11:24:13
17:21:38:I1:WU1:************************************ CBang *************************************
17:21:38:I1:WU1:       Time: 11:23:53
17:21:38:I1:WU1:************************************ System ************************************
17:21:38:I1:WU1:        CPU: Intel(R) Core(TM) i5-6600K CPU @ 3.50GHz
17:21:38:I1:WU1:     CPU ID: GenuineIntel Family 6 Model 94 Stepping 3
17:21:38:I1:WU1:       CPUs: 4
17:21:38:I1:WU1:     Memory: 15.96GiB
17:21:38:I1:WU1:Free Memory: 8.19GiB
17:21:38:I1:WU1:    Threads: WINDOWS_THREADS
17:21:38:I1:WU1: OS Version: 6.2
17:21:38:I1:WU1:Has Battery: false
17:21:38:I1:WU1: On Battery: false
17:21:38:I1:WU1: UTC Offset: 2
17:21:38:I1:WU1:        PID: 19412
17:21:38:I1:WU1:        CWD: C:\ProgramData\FAHClient\work
17:21:38:I1:WU1:********************************************************************************
17:21:38:I1:WU1:Project: 16959 (Run 15, Clone 71, Gen 475)
17:21:38:I1:WU1:Unit: 0x00000000000000000000000000000000
17:21:38:I1:WU1:Digital signatures verified
17:21:38:I1:WU1:Calling: mdrun -c frame475.gro -s frame475.tpr -x frame475.xtc -cpi state.cpt -cpt 5 -nt 2 -ntmpi 1
17:21:38:I1:WU1:Steps: first=1187500000 total=1190000000
17:21:38:I1:WU1:Completed 18502 out of 2500000 steps (0%)
17:21:45:I1:OUT13:< HTTP/1.1 200 HTTP_OK
17:21:45:I1:WU2:Received WU P12131 R4335 C0 G0
17:21:45:I1:Downloading https://cores2.foldingathome.org/openmm-core-23/windows-10-64bit/release/fahcore-23-windows-10-64bit-release-8.0.3.tar.bz2.crt
17:21:45:I1:OUT14:> GET https://cores2.foldingathome.org/openmm-core-23/windows-10-64bit/release/fahcore-23-windows-10-64bit-release-8.0.3.tar.bz2.crt HTTP/1.1
17:21:46:I1:OUT14:< HTTP/1.1 200 OK
17:21:46:I1:Downloading https://cores2.foldingathome.org/openmm-core-23/windows-10-64bit/release/fahcore-23-windows-10-64bit-release-8.0.3.tar.bz2.sig
17:21:46:I1:OUT15:> GET https://cores2.foldingathome.org/openmm-core-23/windows-10-64bit/release/fahcore-23-windows-10-64bit-release-8.0.3.tar.bz2.sig HTTP/1.1
17:21:46:I1:OUT15:< HTTP/1.1 200 OK
17:21:46:I1:OUT16:> GET https://cores2.foldingathome.org/openmm-core-23/windows-10-64bit/release/fahcore-23-windows-10-64bit-release-8.0.3.tar.bz2 HTTP/1.1
17:22:33:I1:OUT16:< HTTP/1.1 200 OK
17:22:34:I1:Core signature valid
17:22:34:I1:Extracting cores/openmm-core-23/windows-10-64bit/release/fahcore-23-windows-10-64bit-release-8.0.3/FahCore_23.exe
17:22:34:I1:Extracting cores/openmm-core-23/windows-10-64bit/release/fahcore-23-windows-10-64bit-release-8.0.3/OpenMM.dll
17:22:34:I1:Extracting cores/openmm-core-23/windows-10-64bit/release/fahcore-23-windows-10-64bit-release-8.0.3/OpenMMAmoeba.dll
17:22:34:I1:Extracting cores/openmm-core-23/windows-10-64bit/release/fahcore-23-windows-10-64bit-release-8.0.3/OpenMMAmoebaCUDA.dll
17:22:34:I1:Extracting cores/openmm-core-23/windows-10-64bit/release/fahcore-23-windows-10-64bit-release-8.0.3/OpenMMAmoebaOpenCL.dll
17:22:34:I1:Extracting cores/openmm-core-23/windows-10-64bit/release/fahcore-23-windows-10-64bit-release-8.0.3/OpenMMAmoebaReference.dll
17:22:34:I1:Extracting cores/openmm-core-23/windows-10-64bit/release/fahcore-23-windows-10-64bit-release-8.0.3/OpenMMCPU.dll
17:22:35:I1:Extracting cores/openmm-core-23/windows-10-64bit/release/fahcore-23-windows-10-64bit-release-8.0.3/OpenMMCUDA.dll
17:22:35:I1:Extracting cores/openmm-core-23/windows-10-64bit/release/fahcore-23-windows-10-64bit-release-8.0.3/OpenMMCudaCompiler.dll
17:22:35:I1:Extracting cores/openmm-core-23/windows-10-64bit/release/fahcore-23-windows-10-64bit-release-8.0.3/OpenMMDrude.dll
17:22:35:I1:Extracting cores/openmm-core-23/windows-10-64bit/release/fahcore-23-windows-10-64bit-release-8.0.3/OpenMMDrudeCUDA.dll
17:22:35:I1:Extracting cores/openmm-core-23/windows-10-64bit/release/fahcore-23-windows-10-64bit-release-8.0.3/OpenMMDrudeOpenCL.dll
17:22:35:I1:Extracting cores/openmm-core-23/windows-10-64bit/release/fahcore-23-windows-10-64bit-release-8.0.3/OpenMMDrudeReference.dll
17:22:35:I1:Extracting cores/openmm-core-23/windows-10-64bit/release/fahcore-23-windows-10-64bit-release-8.0.3/OpenMMOpenCL.dll
17:22:35:I1:Extracting cores/openmm-core-23/windows-10-64bit/release/fahcore-23-windows-10-64bit-release-8.0.3/OpenMMPME.dll
17:22:35:I1:Extracting cores/openmm-core-23/windows-10-64bit/release/fahcore-23-windows-10-64bit-release-8.0.3/OpenMMRPMD.dll
17:22:35:I1:Extracting cores/openmm-core-23/windows-10-64bit/release/fahcore-23-windows-10-64bit-release-8.0.3/OpenMMRPMDCUDA.dll
17:22:35:I1:Extracting cores/openmm-core-23/windows-10-64bit/release/fahcore-23-windows-10-64bit-release-8.0.3/OpenMMRPMDOpenCL.dll
17:22:35:I1:Extracting cores/openmm-core-23/windows-10-64bit/release/fahcore-23-windows-10-64bit-release-8.0.3/OpenMMRPMDReference.dll
17:22:35:I1:Extracting cores/openmm-core-23/windows-10-64bit/release/fahcore-23-windows-10-64bit-release-8.0.3/core-meta.json
17:22:35:I1:Extracting cores/openmm-core-23/windows-10-64bit/release/fahcore-23-windows-10-64bit-release-8.0.3/cufft64_10.dll
17:22:46:I1:Extracting cores/openmm-core-23/windows-10-64bit/release/fahcore-23-windows-10-64bit-release-8.0.3/libcrypto-1_1-x64.dll
17:22:46:I1:Extracting cores/openmm-core-23/windows-10-64bit/release/fahcore-23-windows-10-64bit-release-8.0.3/libssl-1_1-x64.dll
17:22:46:I1:Extracting cores/openmm-core-23/windows-10-64bit/release/fahcore-23-windows-10-64bit-release-8.0.3/msvcp140.dll
17:22:46:I1:Extracting cores/openmm-core-23/windows-10-64bit/release/fahcore-23-windows-10-64bit-release-8.0.3/msvcp140_1.dll
17:22:46:I1:Extracting cores/openmm-core-23/windows-10-64bit/release/fahcore-23-windows-10-64bit-release-8.0.3/msvcp140_2.dll
17:22:46:I1:Extracting cores/openmm-core-23/windows-10-64bit/release/fahcore-23-windows-10-64bit-release-8.0.3/msvcp140_atomic_wait.dll
17:22:46:I1:Extracting cores/openmm-core-23/windows-10-64bit/release/fahcore-23-windows-10-64bit-release-8.0.3/msvcp140_codecvt_ids.dll
17:22:46:I1:Extracting cores/openmm-core-23/windows-10-64bit/release/fahcore-23-windows-10-64bit-release-8.0.3/nvrtc-builtins64_112.dll
17:22:46:I1:Extracting cores/openmm-core-23/windows-10-64bit/release/fahcore-23-windows-10-64bit-release-8.0.3/nvrtc64_112_0.dll
17:22:48:I1:Extracting cores/openmm-core-23/windows-10-64bit/release/fahcore-23-windows-10-64bit-release-8.0.3/vcruntime140.dll
17:22:48:I1:Extracting cores/openmm-core-23/windows-10-64bit/release/fahcore-23-windows-10-64bit-release-8.0.3/vcruntime140_1.dll
17:22:48:I3:Running FahCore: C:\ProgramData\FAHClient\cores/openmm-core-23/windows-10-64bit/release/fahcore-23-windows-10-64bit-release-8.0.3/FahCore_23.exe -dir nymc7H4XeoNrSJgQU2Z8Tf7DK0nxLaFIvHr3q-0cJvk -suffix 01 -version 8.4.9 -lifeline 12324 -gpu-uuid c23eb846-5331-7fb1-3992-1c44bbddefb1 -gpu-platform cuda -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-platform 0 -cuda-device 0 -gpu 0
17:22:48:I3:WU2:Started FahCore on PID 9872
17:22:48:I1:WU2:*********************** Log Started 2025-09-06T17:22:48Z ***********************
17:22:48:I1:WU2:*************************** Core23 Folding@home Core ***************************
17:22:48:I1:WU2:       Core: Core23
17:22:48:I1:WU2:       Type: 0x23
17:22:48:I1:WU2:    Version: 8.0.3
17:22:48:I1:WU2:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
17:22:48:I1:WU2:  Copyright: 2022 foldingathome.org
17:22:48:I1:WU2:   Homepage: https://foldingathome.org/
17:22:48:I1:WU2:       Date: Aug 3 2023
17:22:48:I1:WU2:       Time: 08:39:06
17:22:48:I1:WU2:   Compiler: Visual C++
17:22:48:I1:WU2:    Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
17:22:48:I1:WU2:             -DOPENMM_VERSION="\"8.0.0\""
17:22:48:I1:WU2:   Platform: win32 10
17:22:48:I1:WU2:       Bits: 64
17:22:48:I1:WU2:       Mode: Release
17:22:48:I1:WU2:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
17:22:48:I1:WU2:             <peastman@stanford.edu>
17:22:48:I1:WU2:       Args: -dir nymc7H4XeoNrSJgQU2Z8Tf7DK0nxLaFIvHr3q-0cJvk -suffix 01
17:22:48:I1:WU2:             -version 8.4.9 -lifeline 12324 -gpu-uuid
17:22:48:I1:WU2:             c23eb846-5331-7fb1-3992-1c44bbddefb1 -gpu-platform cuda -gpu-vendor
17:22:48:I1:WU2:             nvidia -opencl-platform 0 -opencl-device 0 -cuda-platform 0
17:22:48:I1:WU2:             -cuda-device 0 -gpu 0
17:22:48:I1:WU2:************************************ libFAH ************************************
17:22:48:I1:WU2:       Time: 08:37:55
17:22:48:I1:WU2:************************************ CBang *************************************
17:22:48:I1:WU2:    Version: 1.7.2
17:22:48:I1:WU2:        Org: Cauldron Development LLC
17:22:48:I1:WU2:  Copyright: Cauldron Development LLC, 2003-2023
17:22:48:I1:WU2:   Homepage: https://cauldrondevelopment.com/
17:22:48:I1:WU2:    License: GPL 2+
17:22:48:I1:WU2:       Time: 08:37:14
17:22:48:I1:WU2:************************************ System ************************************
17:22:48:I1:WU2:        CPU: Intel(R) Core(TM) i5-6600K CPU @ 3.50GHz
17:22:48:I1:WU2:     CPU ID: GenuineIntel Family 6 Model 94 Stepping 3
17:22:48:I1:WU2:       CPUs: 4
17:22:48:I1:WU2:     Memory: 15.96GiB
17:22:48:I1:WU2:Free Memory: 7.97GiB
17:22:48:I1:WU2:    Threads: WINDOWS_THREADS
17:22:48:I1:WU2: OS Version: 6.2
17:22:48:I1:WU2:Has Battery: false
17:22:48:I1:WU2: On Battery: false
17:22:48:I1:WU2: UTC Offset: 2
17:22:48:I1:WU2:        PID: 9872
17:22:48:I1:WU2:        CWD: C:\ProgramData\FAHClient\work
17:22:48:I1:WU2:       Exec: C:\ProgramData\FAHClient\cores\openmm-core-23\windows-10-64bit\release\fahcore-23-windows-10-64bit-release-8.0.3\FahCore_23.exe
17:22:48:I1:WU2:************************************ OpenMM ************************************
17:22:48:I1:WU2:    Version: 8.0.0
17:22:48:I1:WU2:********************************************************************************
17:22:48:I1:WU2:Project: 12131 (Run 4335, Clone 0, Gen 0)
17:22:48:I1:WU2:Reading tar file core.xml
17:22:48:I1:WU2:Reading tar file integrator.xml
17:22:48:I1:WU2:Reading tar file state.xml
17:22:48:I1:WU2:Reading tar file system.xml
17:22:49:I1:WU2:Digital signatures verified
17:22:49:I1:WU2:Folding@home GPU Core23 Folding@home Core
17:22:49:I1:WU2:Version 8.0.3
17:22:49:I1:WU2:  Checkpoint write interval: 125000 steps (5%) [20 total]
17:22:49:I1:WU2:  JSON viewer frame write interval: 25000 steps (1%) [100 total]
17:22:49:I1:WU2:  XTC frame write interval: 50000 steps (2%) [50 total]
17:22:49:I1:WU2:  Global context and integrator variables write interval: disabled
17:22:49:I1:WU2:There are 4 platforms available.
17:22:49:I1:WU2:Platform 0: Reference
17:22:49:I1:WU2:Platform 1: CPU
17:22:49:I1:WU2:Platform 2: OpenCL
17:22:49:I1:WU2:  opencl-device 0 specified
17:22:49:I1:WU2:Platform 3: CUDA
17:22:49:I1:WU2:  cuda-device 0 specified
17:22:58:I1:WU2:Attempting to create CUDA context:
17:22:58:I1:WU2:  Configuring platform CUDA
17:23:07:I1:WU2:  Using CUDA on CUDA Platform and gpu 0
17:23:07:I1:WU2:  GPU info: Platform: CUDA
17:23:07:I1:WU2:  GPU info: PlatformIndex: 0
17:23:07:I1:WU2:  GPU info: Device: NVIDIA GeForce GTX 1060 6GB
17:23:07:I1:WU2:  GPU info: DeviceIndex: 0
17:23:07:I1:WU2:  GPU info: Vendor: 0x10de
17:23:07:I1:WU2:  GPU info: PCI: 03:00:00
17:23:07:I1:WU2:  GPU info: Compute: 6.1
17:23:07:I1:WU2:  GPU info: Driver: 13.0
17:23:07:I1:WU2:  GPU info: GPU: true
17:23:07:I1:WU2:Completed 0 out of 2500000 steps (0%)
17:23:09:I1:WU2:Checkpoint completed at step 0
17:24:10:I1:WU1:Completed 25000 out of 2500000 steps (1%)
17:25:36:I1:WU2:Completed 25000 out of 2500000 steps (1%)
17:28:19:I1:WU2:Completed 50000 out of 2500000 steps (2%)
17:30:59:I1:WU2:Completed 75000 out of 2500000 steps (3%)
17:33:25:I1:WU2:Completed 100000 out of 2500000 steps (4%)
17:34:07:I1:WU1:Completed 50000 out of 2500000 steps (2%)
17:35:56:I1:WU2:Completed 125000 out of 2500000 steps (5%)
17:35:59:I1:WU2:Checkpoint completed at step 125000
17:38:26:I1:WU2:Completed 150000 out of 2500000 steps (6%)
17:40:55:I1:WU2:Completed 175000 out of 2500000 steps (7%)
17:43:24:I1:WU2:Completed 200000 out of 2500000 steps (8%)
17:44:03:I1:WU1:Completed 75000 out of 2500000 steps (3%)
17:44:22:E :WU2:Core returned UNKNOWN_ENUM (1073807364)
17:44:22:E :WU2:Core exited with an unknown error code 1073807364 which probably indicates that it crashed. Dumping WU
17:44:22:E :WU1:Core returned UNKNOWN_ENUM (1073807364)
17:44:22:E :WU1:Core exited with an unknown error code 1073807364 which probably indicates that it crashed. Dumping WU
17:44:22:I1:WU2:Sending dump report
17:44:22:I1:WU1:Sending dump report
17:44:22:I1:OUT18:> POST https://vav22.fah.temple.edu/api/results HTTP/1.1
17:44:22:I1:OUT17:> POST https://ds01.scs.illinois.edu/api/results HTTP/1.1
17:44:23:I1:OUT17:< HTTP/1.1 200 HTTP_OK
17:44:23:I1:WU2:Dumped
17:44:23:I1:OUT18:< HTTP/1.1 200 HTTP_OK
17:44:23:I1:WU1:Dumped
Image Intel Core i5 6600K
Image Inno3D NVIDIA GeForce GTX 1060 6Gb
Re: WU stuck on "Shutting Down" after pc restart
Post by muziqaz »
You need to pause folding before restarting or shutting down your PC with Windows. Linux does not have this issue. There is something broken the way Windows shuts the PCs down. We are aware of this, still no fix available.
Old WUs will disappear eventually when they expire
FAH Omega tester
