15404 Bad WU
sboyette
Hardware configuration: Ryzen 8600G + RX 9060XT
Ryzen 7640HS
15404 Bad WU
Post by sboyette »
Earlier today I got a bad GPU WU from project 15404. I don't know how to look up a WU ID with the v8 tooling, but in the WU info page I can see the other users that it's been passed to in the past week or so:
Code	User			Team	Credit	Assigned		Credited
Failed	aafypymy5ydzb...	1066107	0	2025-08-23 06:39:32	2025-08-23 10:54:54
Failed	Geroya			236988	0	2025-08-23 07:01:17	2025-08-23 10:54:58
Failed	760w5aocziq6		234980	0	2025-08-23 07:47:39	2025-08-23 10:55:05
Failed	DM3001			257944	0	2025-08-23 09:06:57	2025-08-23 10:55:12
Failed	0d20ynbpvn7r		234980	0	2025-08-23 09:54:11	2025-08-23 10:55:13
Failed	Geralt			223518	0	2025-09-02 20:32:07	2025-09-02 21:43:17
Failed	atreyu_audiomedics	240890	0	2025-09-02 21:47:05	2025-09-02 22:13:16
Failed	au6zoav25a4b		234980	0	2025-09-02 22:07:16	2025-09-02 22:13:16
Failed	Ajonymous		250966	0	2025-09-02 22:08:38	2025-09-02 23:53:11
Failed	JackyRC			31403	0	2025-09-02 23:50:10	2025-09-02 23:53:11
Failed	Shawn_Boyette		1061841	0	2025-09-04 18:00:58	2025-09-04 19:03:09
Failed	au6zoav25a4b		234980	0	2025-09-04 19:18:51	2025-09-04 19:23:13
...which, while irritating, should point to which WU it actually is. Thought it was worth reporting, since it's clearly problematic. On my machine at least, before it was declared bad it went through 4 restarts, each with the message "Velocities are running away", followed by some numbers -- sorry that I didn't think to copy the exact message down while I still had the log easily accessible.
Re: 15404 Bad WU
sboyette wrote: Thu Sep 04, 2025 8:39 pm I don't know how to look up a WU ID with the v8 tooling, but in the WU info page I can see the other users that it's been passed to in the past week or so:
On the Work Units display in the v8 web control the "i" icon at the right shows the WU ID information at the bottom before showing the stats/credit information. In the left column it states the Project number, and in the right column it lists the RCG or Run, Clone, Gen.
sboyette
Ryzen 7640HS
Re: 15404 Bad WU
Post by sboyette »
Joe_H wrote: Thu Sep 04, 2025 8:49 pm On the Work Units display in the v8 web control the "i" icon at the right shows the WU ID information at the bottom before showing the stats/credit information. In the left column it states the Project number, and in the right column it lists the RCG or Run, Clone, Gen.
Thank you!
Re: 15404 Bad WU
Bad WU has been reported to the researcher.
