WU 18806 immediately went into 'Dump Wait' and the logs show this (slightly edited to remove lines from other WUs):
(searched for WU5)
09:18:56:I3:WU5:Loading work unit 5 with ID vfcEjHTIGQY-pNpc41COz3y2ITyx0s8NeqUekjHzSow
09:18:57:I1:WU5:Sending dump report
09:19:19:I1:WU5:Retry #1 in 2 secs
09:19:21:I1:WU5:Sending dump report
09:19:42:I1:WU5:Retry #2 in 4 secs
09:19:46:I1:WU5:Sending dump report
09:20:07:I1:WU5:Retry #3 in 8 secs
09:20:15:I1:WU5:Sending dump reportCode: Select all
09:19:19:I1:OUT2:> POST https://fahserver1.flatironinstitute.org/api/results HTTP/1.1
09:19:19:E :OUT2:Failed response: EOF
09:19:42:I1:OUT5:> POST https://fahserver1.flatironinstitute.org/api/results HTTP/1.1
09:19:42:E :OUT5:Failed response: EOF
09:20:07:I1:OUT6:> POST https://fahserver1.flatironinstitute.org/api/results HTTP/1.1
09:20:07:E :OUT6:Failed response: EOF
09:20:36:I1:OUT7:> POST https://fahserver1.flatironinstitute.org/api/results HTTP/1.1
09:20:36:E :OUT7:Failed response: EOF
09:21:13:I1:OUT8:> POST https://fahserver1.flatironinstitute.org/api/results HTTP/1.1
09:21:13:E :OUT8:Failed response: EOF
09:22:06:I1:OUT9:> POST https://fahserver1.flatironinstitute.org/api/results HTTP/1.1
09:22:06:E :OUT9:Failed response: EOF
09:23:31:I1:OUT10:> POST https://fahserver1.flatironinstitute.org/api/results HTTP/1.1
09:23:31:E :OUT10:Failed response: EOF
09:26:00:I1:OUT11:> POST https://fahserver1.flatironinstitute.org/api/results HTTP/1.1
09:26:00:E :OUT11:Failed response: EOFCode: Select all
09:29:11:I3:WU5:Dumping vfcEjHTIGQY-pNpc41COz3y2ITyx0s8NeqUekjHzSow
09:29:14:I1:WU5:Sending dump report
09:29:35:I1:WU5:Retry #1 in 2 secs
09:29:37:I1:WU5:Sending dump report
09:29:58:I1:WU5:Retry #2 in 4 secs
09:30:02:I1:WU5:Sending dump reportAny help would be much appreciated!
EDIT: A new WU has been assigned, but 18806 is still trying and failing to dump.
